wix 2019 sienna oil filter cartridge fitment
by s2krunner - 02/23/20 02:19 PM
Urban Carry G3
by Gebo - 02/23/20 02:16 PM
Denso Iridium TT's are great
by jayjr1105 - 02/23/20 01:46 PM
Girl Scout question
by ffhdriver - 02/23/20 01:36 PM
MTD Snowblower issues
by 97prizm - 02/23/20 01:19 PM
OBD scanner
by NH73 - 02/23/20 10:18 AM
Oil additive and effects on oil analysis results
by MoneyJohn - 02/23/20 09:48 AM
More 6.7 PSD engine repairs
by mattd - 02/23/20 09:10 AM
How to get sediment out of heater oil tank?
by BAJA_05 - 02/23/20 08:37 AM
Oil Prices in Europe
by BBDartCA - 02/23/20 08:08 AM
Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
Lucase483, Chaucha, UofA, Jeffrey78, Markovchain
70788 Registered Users
100 registered members (928, ammolab, 74Widebody, alchargo, 67ZL1, 11 invisible), 2,678 guests, and 16 spiders.
Topics301,834
Posts5,203,577
Members70,788
Back seat battery #4783587 06/11/18 05:57 AM
Duffyjr Offline OP
Are batteries lasting longer when they're located outside the engine bay away from the heat?
89 GMC Sierra Advanced 5w30/51036 Wix
08 Lucerne CX Advanced 5w30/1040 Gold
18 Toro Super Recycler T5 10w30
Re: Back seat battery [Re: Duffyjr] #4783595 06/11/18 06:16 AM
Char Baby Offline
Well, I am going to say, NO! When they're in the engine compartment, they are right in the way of cooling air coming into the engine bay. As were the batteries that are located in the trunk or backseat area, or even the wheel well of the car(Chrysler), don't seem to show any benefits for longevity. I think the battery placement is for weight balance.
Batteries that are in vehicles living in the HEAT BELT suffer from more earlier failures regardless of their location in the vehicle. Batteries not maintained also fail early regardless of the location in the vehicle.
This is just my opinion.
CB
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Back seat battery [Re: Duffyjr] #4783696 06/11/18 08:50 AM
L
Lolvoguy Offline
L
I'm gonna go with "yes".
As the temps are more stable and generally cooler when away from the heat of the engine bay.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Back seat battery [Re: Duffyjr] #4783707 06/11/18 09:01 AM
R
Ryan Offline
R
Id say the battery being out of the engine bay would be better for it, but Im sure the engineers dont care about the longevity of your battery. They are probably doing it because of less room under the hood.
Re: Back seat battery [Re: Char Baby] #4783781 06/11/18 10:08 AM
SeaJay Offline
CB
I thought batteries in today's cars were maintenance free? If not, I better start doing some maintaining, after I figure out what needs to be done.
Re: Back seat battery [Re: Duffyjr] #4783791 06/11/18 10:20 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
I agree with Ryan, heat is not the primary reason the battery is moved from the engine bay. Wherever the battery sits, corrosive vapors is a concern. Plus, the longer cables will reduce the power available for starting, unless the cables are thicker.
Re: Back seat battery [Re: Duffyjr] #4783795 06/11/18 10:22 AM
R
redbone3 Offline
R
I have owned cars with batteries in all locations. Cooler is better.
2014 Passat Wolfsburg, 1995 Miata.
Re: Back seat battery [Re: Duffyjr] #4783924 06/11/18 12:01 PM
R
Rand Offline
R
Can definitely help. Its somewhat known that batteries in the 2014+ cherokee live short lives.. due to excessive heat.
Many going before the 3 year mark... even in the years previous to having auto start/stop.
Re: Back seat battery [Re: Duffyjr] #4783947 06/11/18 12:47 PM
M
maxdustington Offline
M
Depends on the location. In Canada it might help stabilize the temp for cold starts if the battery is located inside, and less exposure of connections to a corrosive atmosphere. The resistance from the wiring might negate these advantages.
Have you ever seen industrial vehicles where the battery is just hanging off the side of the frame? I do not think it matters one way or the other.
99 Toyota Tercel CE 5EFE/C151
Re: Back seat battery [Re: Duffyjr] #4783986 06/11/18 01:59 PM
M
mjoekingz28 Offline
M
A battery mat to absorb shock, keeping the case clean, the water level proper if it has caps, and of course the terminals clean and corrosion free (and a light film of oil or grease if that's your thing) is all I think is needed in a regular car. Of course regular charging if it is rarely driven or a detached negative cable are good.
A Cobalt I had placed the battery in the spare tire tub/well low in the trunk. It has a vent hose for (hydrogen?) fumes- but dont AGMs solve that issue? I think that is a perfect location for a sporty car for the weight issues. Also, the battery is out of the way for more room in the engine bay and also, smokers and those careless can be safer not having it under the hood when doing work to the car.
As for do they last longer....I would guess they would with all things being equal. But if you treat your underhood battery like royalty then they would probably last equal in time. Its just with the battery inside it probably require alot less attention and that is good for the masses......like sealed non-greasable steering and suspension components.
Re: Back seat battery [Re: Duffyjr] #4788564 06/16/18 07:01 PM
E
ENGINEER60 Offline
E
YES they are.
Chevy cobalts can easily go 8 years or more on a battery because it is mounted in the trunk out of the temp extremes, vibration, and eposure to liquids dirt, and corrosives.
Re: Back seat battery [Re: Duffyjr] #4788605 06/16/18 07:53 PM
E
eljefino Offline
E
MIL's lesabre got 12+ years from the stock battery under the rear seat and wife's HHR was sold at year 10 (11?) with its OE trunk battery.
Re: Back seat battery [Re: Duffyjr] #4790714 06/19/18 06:05 AM
H
HYUNDAIFAN0001 Offline
H
If having 3 batteries (includes the original) in 18 years for my 2000 E320 Mercedes is any indication...the answer is yes...having a battery away from outside elements helps longevity.
Always taking care of my rides.
