Originally Posted By: ZeeOSix
Originally Posted By: Shannow
The drier will of course be harvesting humidity from the ambient air as well.
Would have been intetesting to weigh the wet towels before and after drying, then weigh the captured water to see how they compared.
Most definitely...next time it's raining and I have to do a load of towels I will try to take all three measurements...need to buy a set of fish scales
Originally Posted By: AZjeff
Interesting dryer Steve, didn't even know that existed. When we sold our old house the stacked front load washer/dryer stayed to my wife's delight. She fought the common mildew problem with that washer almost the entire time we owned it. Bought the most basic Samsung set, not an LED display anywhere, and she's a happy camper. Even at the cheap end it has moisture sensing and timed drying. Of course here the clothes you hung on the line first are dry by the time you get them up on the other end.
Does that have a normal vent or just a line draining the water?
That's the reason the plain drier has always stayed outside...don't want to add humidity in this area (especially the old house we moved out of.
This thing has three maintenance items (two the way we use it)
Water tank (if you don't run the water to the sink.
Drier lint trap (inside the thing)
Another lint trap on the air exhaust from the machine (so it sucks air somewhere, not sure where).
Can also up the humidity in the drum just before it stops for less creases...or have an "iron" setting which leaves them a bit damp to be ironed later.
