How much is an AC service where ya"all are?
by Chris142. 06/18/19 05:34 PM
Bosch D3300: reuse or trash it?
by NormanBuntz. 06/18/19 03:48 PM
Actual damage from fuel dilution?
by Deontologist. 06/18/19 02:58 PM
Retirement advice
by dja4260. 06/18/19 02:10 PM
Oil for DI
by Coastie05. 06/18/19 01:57 PM
Edge or Edge EP for friends Venza
by 53' Stude. 06/18/19 01:11 PM
Found a Premium Blue Restore VOA
by SubyRoo. 06/18/19 12:44 PM
Semi-Syn
by nicholas. 06/18/19 11:30 AM
Particle Count (PC) testing of used oil
by Talent_Keyhole. 06/18/19 11:25 AM
Added individually, coolant & water won't mix?
by Ed_Flecko. 06/18/19 11:15 AM
02 silverado diff fluid....
by Jcountry. 06/18/19 11:06 AM
Arteries
by CourierDriver. 06/18/19 10:17 AM
Remember the Officers
by CourierDriver. 06/18/19 10:02 AM
New TV
by WyrTwister. 06/18/19 08:45 AM
Best cheap filter?
by jayjr1105. 06/18/19 08:37 AM
BB Pistol- The Peacemaker
by CourierDriver. 06/18/19 06:33 AM
Zoro.com 20% off sale
by SubieRubyRoo. 06/18/19 06:24 AM
Why such a low temp thermostat?
by Chris142. 06/17/19 11:21 PM
chakir, 9J460, Petethedog, RenewableLubeBen, flattire101
68428 Registered Users
91 registered members (92saturnsl2, AdditiveOCD, ad244, 2015_PSD, 2oldtommy, 8 invisible), 2,209 guests, and 22 spiders.
Topics290,622
Posts4,989,789
Members68,428
Most Online2,967
Mar 10th, 2019
GE Oven Issue? #4783372
06/10/18 08:47 PM
06/10/18 08:47 PM
MURICA
maverickfhs Offline OP
MURICA
So I have this GE jgbp33beh3bb. For some reason, today when we tried to use Oven and used Pre-heat it's not doing anything.
Broil, stove, all controls and and lights, everything is working.
Does anyone know if it's possibly an igniter issue or something else? Thank you thumbsup
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: GE Oven Issue? [Re: maverickfhs] #4783383
06/10/18 08:57 PM
06/10/18 08:57 PM
Cincinnati, OH, USA
bullwinkle Online confused
bullwinkle  Online Confused
Cincinnati, OH, USA
If it's gas & you don't see something glowing like a light bulb, the igniter is a good place to start. It should have 2, one for the broiler on top, and one for the oven burner down below. It is possible to switch them, I actually had to do mine on Thanksgiving Day a couple years ago to cook the turkey!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: GE Oven Issue? [Re: bullwinkle] #4783387
06/10/18 09:00 PM
06/10/18 09:00 PM
MURICA
MURICA
Thanks for the input. So you are saying oven one should be below in the tray area, is it? You are right, nothing is glowing like a heated rod in the oven area.
Because I can see an ignotor for the broil area in the top part, are they both interchangeable, if you know?
Re: GE Oven Issue? [Re: maverickfhs] #4783395
06/10/18 09:08 PM
06/10/18 09:08 PM
Kansas, USA
Kansas_Ron Offline
Kansas_Ron  Offline
Kansas, USA
2000 Chevy Prizm
2015 Honda Civic
2017 Hyundai Elantra
Re: GE Oven Issue? [Re: maverickfhs] #4783397
06/10/18 09:09 PM
06/10/18 09:09 PM
Cincinnati, OH, USA
Cincinnati, OH, USA
They were on my GE gas range, and they were identical. They can be checked with an ohmmeter, they usually go open, sometimes there are burn marks & cracks visible. It's also a good idea to wear rubber gloves, they can be damaged by the oil on your skin (like a halogen bulb).
Re: GE Oven Issue? [Re: maverickfhs] #4783399
06/10/18 09:09 PM
06/10/18 09:09 PM
MURICA
MURICA
Thanks all, I think it's the igniter and I'll go ahead and replace it.
Then see what happens smile
Re: GE Oven Issue? [Re: maverickfhs] #4783486
06/10/18 11:28 PM
06/10/18 11:28 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
There will also be an oven temperature sensor (which will disable the oven but not the broiler if failed).
Also the most common failure in these stoves (any modern stove) is the control panel (where you read oven temperatures, set the timer, etc). About a $350 part, typically. I repaired mine by replacing a failed relay, cost me $10. Same symptoms as you (everything worked except the oven). Frigidaire Gallery, but note that there are only about five manufacturers of ovens that sell into the North American 220~240V market, two are in South Korea, one is European.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: GE Oven Issue? [Re: maverickfhs] #4783630
06/11/18 08:17 AM
06/11/18 08:17 AM
Alberta
tcp71 Offline
tcp71  Offline
Alberta
Igniters are a somewhat regular replacement item for a gas stove. They also have a resistive circuit that controls the gas valve for th burner. If it doesnít heat up and drop resistance in the circuit, the gas valve never opens. The lower one usually burns out first due to higher use.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: mobil 0w40 (varies)
Re: GE Oven Issue? [Re: tcp71] #4783632
06/11/18 08:19 AM
06/11/18 08:19 AM
MURICA
MURICA
Thanks, do you think I should replace both or just the one which is broken?
Re: GE Oven Issue? [Re: maverickfhs] #4783945
06/11/18 01:47 PM
06/11/18 01:47 PM
MURICA
MURICA
Did any of you buy OEM or went with aftermarket option?
Re: GE Oven Issue? [Re: maverickfhs] #4784089
06/11/18 05:02 PM
06/11/18 05:02 PM
West Michigan
Balrog006 Offline
Balrog006  Offline
West Michigan
Another likely culprit is the exhaust fan, GE is made by Whirlpool. Their current slew of models across a bunch of platforms for the past couple years has had a large batch of bad ones. The control panel will start the oven but when it senses the exhaust not being removed from the unit it shuts down, all within a couple seconds, after a few cycles of this it just bypasses the cycle and wonít start.
I had mine replaced under warranty at just shy of the 1 year mark-the repair crew said they keep a box of them in the truck at all times.
19 Ridgeline RTL-E >1K factory fill, A01
08 CRV 275K+ VSyn w/ML, A01
04 JD L130 740H, Mobil S 5w30
13 JD 2032r 325H, JD Plus 50 ii 15w40
M1Delvac 5w40 in OPE
