Need to pull the starter in this riding mower (about 2001). It spins but does not engage. I suspect the mouse nest nearby that was larger than a softball.
Anyway the starter bracket is bolted to the engine with two T-40 head bolts. The one on the right I can barely see much less get a torx tool into it. Thats todays's problem. The torx bolt on the left is off.
Ideas?
Ideas?
