United Airlines Boeing 757-200 Blows Tires at Newark
by john_pifer. 06/15/19 03:41 PM
15w40 or synthetic 10w30 for 115°f temps
by leroyd92. 06/15/19 03:29 PM
napa 10% code
by eljefino. 06/15/19 02:23 PM
Reading tire rim weights
by Patrick0525. 06/15/19 01:37 PM
Help, remove exhaust tip
by K20FA5. 06/15/19 01:03 PM
Chevron Delo 15/40- $11.87/gal shipped
by Audios. 06/15/19 12:30 PM
Napa wholesaler-lubricant
s
by Red91. 06/15/19 12:23 PM
Trying to Watch Chernobyl; Won’t Work
by john_pifer. 06/15/19 11:54 AM
4ft LED shop light
by Duffyjr. 06/15/19 10:28 AM
Genuine hardwood vs engineered or vinyl plank.
by pezzy669. 06/15/19 09:01 AM
Honda 15400-PLM-A02 filter after 1700 miles
by OS4A. 06/15/19 08:57 AM
Seafoam In Oil (Up To 300 Miles)
by ChrisD46. 06/15/19 08:48 AM
Otto Aviation "Celera 500L"
by Cujet. 06/15/19 08:32 AM
I found my new OPE Oil
by Lawn_Care. 06/15/19 07:18 AM
Young killed in major crash on I-95 in Florida
by Mr Nice. 06/15/19 06:48 AM
Bossladynakole, MerA, Krcj71980, quixotic, davidclinton
68405 Registered Users
79 registered members (AlienBug, atikovi, Boomer, 92saturnsl2, Ag76, bbhero, 11 invisible), 2,140 guests, and 16 spiders.
Topics290,235
Posts4,986,860
Members68,405
Most Online2,967
Mar 10th, 2019
How big, oil leak without dripping onto the ground #4783409
06/10/18 09:24 PM
06/10/18 09:24 PM
Toronto Canada
WobblyElvis Offline OP
Toronto Canada
I have an 06 GM ecotec engine that was leaking oil from the valve cover on the forward side of the engine. The engine became covered in a dirty oily mess but it never dripped onto the ground so I didn't repair it for years. Finally sealed in up and the oil consumption dropped by about .2QT a month or .2QTs per 1,400 miles. I find it hard to believe all this oil was just evaporating. Is this possible?
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4783414
06/10/18 09:31 PM
06/10/18 09:31 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
For leaks like that, look along the roads and highways, for that oily spot just after a bump in the road.
Those incipient drops get shaken off
e.g.
So quite probably the drops are getting shaken off at places like that.
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4783429
06/10/18 09:42 PM
06/10/18 09:42 PM
Toronto Canada
Toronto Canada
In this case the oil never made it to the oil pan. I know the engine is hot and there is a warm breeze from the radiator but seems like a lot of oil to evaporate.
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4783779
06/11/18 11:05 AM
06/11/18 11:05 AM
DELAWARE
Hootbro Offline
Hootbro  Offline
DELAWARE
Engine bays still have a lot of turbulent air in them at highway speeds. Any oil accumulation of any significance gets removed by such forces. Not a Scooby Doo mystery.
2019 Toyota Tacoma 3.5L (MileSyn 0W-20)
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
Re: How big, oil leak without dripping onto the ground [Re: Hootbro] #4783812
06/11/18 11:35 AM
06/11/18 11:35 AM
Texas
4WD Offline
4WD  Offline
Texas
Saw a video where a guy removed the hood seal closest to windshield claimed it cooled down his engine
Always figured what you just wrote and even at idle hot air is pushed out the bottom
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4783894
06/11/18 12:35 PM
06/11/18 12:35 PM
USA
crazy_raccoon Offline
USA
A little different but with the Toyota 2AZ-FE motors (practically all Toyota 4 cyl vehicles from like '00 to '10) had issues with the piston rings and clogged piston oil return holes that made the engines burn oil. The problem was there were no leaks and the oil ended up burning away in the combustion chamber. People were burning upwards to a qt. of oil every 600 miles or even less miles than that.
'07 Scion tc
- 103K miles
- Valvoline FS w/ML 0W-20 D1G2
- FRAM Ultra
'07 Honda Accord coupe 4cyl
- 138K miles
- Supertech FS 5W-20 D1G2
- FRAM TG
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4783901
06/11/18 12:41 PM
06/11/18 12:41 PM
Toronto Canada
Toronto Canada
So it is possible for .2 qts/month of motor oil to evaporate from a warm engine? This appears to be what was happening. Anyone know the evaporation rate of motor oil?
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4784650
06/12/18 08:22 AM
06/12/18 08:22 AM
WA
OilUzer Offline
OilUzer  Offline
WA
I had a car that leaked very little oil but never on the ground that I could see. Sometimes I found dead bees or other gunk kind of soaked in oil around the gasket ...
That oil did not "evaporate".
sand, dirt, etc. can also absorb some oil from underneath the engine not visible to you and fall off ...
Also some oil sludge/gunk maybe back in areas not visible ...
You are only focusing on evaporation!
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4784677
06/12/18 08:54 AM
06/12/18 08:54 AM
Toronto Canada
Toronto Canada
Oil must evaporate to some extent. If I was to oil a rusty piece of sheet metal that sat outside it wouldn't be wet/oily forever.
There is another explanation for my decreased oil consumption. When I repaired the valve cover gasket I also switched oil brands and consumption has been down since that event. I've used many different brands/types of oil but they all burned or disappeared at the same rate. I find it hard to believe that the oil type is responsible for the drop in oil consumption. This is why I'm asking about oil evaporating from the warm exterior of an engine.
Oil consumption has fallen from 1 qt/3,300 miles to a qt/4,500 miles. The engine has over 200,000 miles on it.
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4784689
06/12/18 09:10 AM
06/12/18 09:10 AM
Balearic Islands , Spain
FordCapriDriver Offline
My Escort leaks some oil, perhaps every 2 or 3 days i find a drop or two of oil on the ground.
Often i can see a small drop of oil that hasn't fallen yet on the bottom of the oil pan.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40
G40 Si-OAT coolant in both
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4784692
06/12/18 09:17 AM
06/12/18 09:17 AM
PimTac Offline
PimTac  Offline
Many of the newer vehicles have resin under shields installed so minor leaks would be caught by them instead of going directly to the ground. The heat from the engine plus air movement could help evaporate anything that is minor.
As your car has that many miles on it, a common place for oil leaks would be the rear main seal. Check that area for any leaks or seepage.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: How big, oil leak without dripping onto the ground [Re: PimTac] #4784831
06/12/18 12:11 PM
06/12/18 12:11 PM
Toronto Canada
Toronto Canada
There is no pan or tray under the engine and no other leaks. Oil has never made it down o the top of the pan. My money is on evaporation taking the lighter portions of the oil away.
Re: How big, oil leak without dripping onto the ground [Re: WobblyElvis] #4784844
06/12/18 12:24 PM
06/12/18 12:24 PM
Georgia
HammerHead0313 Offline
Georgia
Oil selection is more important than most think, especially in older high mile engines. I had a 1999 Dodge Ram with the 5.9 and it consumed 1 Quart of oil every 500 miles using full synthetic oil; swithed to a conventional oil and it cut my oil consumption by 50% using conventional oil.
2017 GMC 2500 HD, CC, 8' foot bed, 4x4, L96 6.0 Bone Stock
Amsoil SS
Amsoil Severe Gear
Amsoil ATF
