Forums Migration
Please read this thread
Latest Cannonball Record
by Burt - 07/13/20 01:40 PM
ATS V oil filter selection
by cadillactech - 07/13/20 12:39 PM
towing: hitch ball mount tapered seats
by zorobabel - 07/13/20 12:25 PM
Amsoil EaO 34
by Gebo - 07/13/20 12:20 PM
Superstar Racing Experience SRX
by SubLGT - 07/13/20 12:14 PM
Lack of Money or Lack of Priorities
by rob1715 - 07/13/20 12:09 PM
Are Home Routers Secure? NO!
by SubLGT - 07/13/20 11:55 AM
Honda Specialists?
by maverickfhs - 07/13/20 11:30 AM
US gasoline production continues to climb
by Snagglefoot - 07/13/20 11:22 AM
Favorite paint stripper product for wood?
by Ed_Flecko - 07/13/20 10:49 AM
are all full synthetic high mileage oils similar?
by apollo18 - 07/13/20 09:50 AM
Does Ford put a 5 cyl. in an F150?
by JohnG - 07/13/20 09:06 AM
Rotella T4 15W40 Vs Mobil Delvac 1300 Super
by SR5 - 07/13/20 08:05 AM
OCI for Bobcat MT85, Kubota diesel
by NormanBuntz - 07/13/20 08:04 AM
sad times in the Super Tech filtration world.
by Jarpin - 07/13/20 08:03 AM
Fire on Bonhomme Richard...
by mattwithcats - 07/13/20 07:44 AM
pool deck paint
by CincyDavid - 07/13/20 06:32 AM
DIY Injector cleaning - What cleaner?
by Spetz - 07/13/20 12:50 AM
viSCOTTsity, Revo, MuddyGeek, stepburns, JOLLY300
71924 Registered Users
110 registered members (53' Stude, 4WD, 750IX, 94astro, 77GrandPrix, Alfred_B, 14 invisible), 2,263 guests, and 22 spiders.
Topics307,802
Posts5,318,039
Members71,923
GE Oven Issue? #4783372 06/10/18 08:47 PM
M
maverickfhs Offline OP
M
So I have this GE jgbp33beh3bb. For some reason, today when we tried to use Oven and used Pre-heat it's not doing anything.
Broil, stove, all controls and and lights, everything is working.
Does anyone know if it's possibly an igniter issue or something else? Thank you thumbsup
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: GE Oven Issue? [Re: maverickfhs] #4783383 06/10/18 08:57 PM
B
bullwinkle Offline
B
If it's gas & you don't see something glowing like a light bulb, the igniter is a good place to start. It should have 2, one for the broiler on top, and one for the oven burner down below. It is possible to switch them, I actually had to do mine on Thanksgiving Day a couple years ago to cook the turkey!
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: GE Oven Issue? [Re: bullwinkle] #4783387 06/10/18 09:00 PM
M
M
Thanks for the input. So you are saying oven one should be below in the tray area, is it? You are right, nothing is glowing like a heated rod in the oven area.
Because I can see an ignotor for the broil area in the top part, are they both interchangeable, if you know?
Re: GE Oven Issue? [Re: maverickfhs] #4783395 06/10/18 09:08 PM
K
Kansas_Ron Offline
K
2000 Chevy Prizm
2015 Honda Civic
2017 Hyundai Elantra
Re: GE Oven Issue? [Re: maverickfhs] #4783397 06/10/18 09:09 PM
B
bullwinkle Offline
B
They were on my GE gas range, and they were identical. They can be checked with an ohmmeter, they usually go open, sometimes there are burn marks & cracks visible. It's also a good idea to wear rubber gloves, they can be damaged by the oil on your skin (like a halogen bulb).
Re: GE Oven Issue? [Re: maverickfhs] #4783399 06/10/18 09:09 PM
M
M
Thanks all, I think it's the igniter and I'll go ahead and replace it.
Then see what happens smile
Re: GE Oven Issue? [Re: maverickfhs] #4783486 06/10/18 11:28 PM
J
Johnny2Bad Offline
J
There will also be an oven temperature sensor (which will disable the oven but not the broiler if failed).
Also the most common failure in these stoves (any modern stove) is the control panel (where you read oven temperatures, set the timer, etc). About a $350 part, typically. I repaired mine by replacing a failed relay, cost me $10. Same symptoms as you (everything worked except the oven). Frigidaire Gallery, but note that there are only about five manufacturers of ovens that sell into the North American 220~240V market, two are in South Korea, one is European.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: GE Oven Issue? [Re: maverickfhs] #4783630 06/11/18 08:17 AM
T
tcp71 Offline
T
Igniters are a somewhat regular replacement item for a gas stove. They also have a resistive circuit that controls the gas valve for th burner. If it doesn’t heat up and drop resistance in the circuit, the gas valve never opens. The lower one usually burns out first due to higher use.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: GE Oven Issue? [Re: tcp71] #4783632 06/11/18 08:19 AM
M
M
Thanks, do you think I should replace both or just the one which is broken?
Re: GE Oven Issue? [Re: maverickfhs] #4783945 06/11/18 01:47 PM
M
M
Did any of you buy OEM or went with aftermarket option?
Re: GE Oven Issue? [Re: maverickfhs] #4784089 06/11/18 05:02 PM
B
Balrog006 Offline
B
Another likely culprit is the exhaust fan, GE is made by Whirlpool. Their current slew of models across a bunch of platforms for the past couple years has had a large batch of bad ones. The control panel will start the oven but when it senses the exhaust not being removed from the unit it shuts down, all within a couple seconds, after a few cycles of this it just bypasses the cycle and won’t start.
I had mine replaced under warranty at just shy of the 1 year mark-the repair crew said they keep a box of them in the truck at all times.
19 Ridgeline RTL-E >1K factory fill, A01
08 CRV 275K+ VSyn w/ML, A01
04 JD L130 740H, Mobil S 5w30
13 JD 2032r 325H, JD Plus 50 ii 15w40
M1Delvac 5w40 in OPE
