Guess your never too young to work on a chevy.
by rollinpete. 06/24/19 08:13 PM
Went to Jiffy Lube
by Stelth. 06/24/19 07:37 PM
safest way to remove bug residue
by NissanMaxima. 06/24/19 07:32 PM
22000 emails
by marine65. 06/24/19 06:31 PM
oil analysis to show fuel dilution
by jfairchild327. 06/24/19 06:00 PM
Mitsu 3000GT rear engine mount is tilted...
by tomcat27. 06/24/19 05:52 PM
Engine full of Fuel. What is best to do?
by LeoStrop. 06/24/19 05:50 PM
Seeking Advice Choosing Wheel Locks
by JerryBob. 06/24/19 05:19 PM
Non-stick pan
by Alfred_B. 06/24/19 05:04 PM
Had to ELIMINATE a raccoon
by Kjmack. 06/24/19 04:52 PM
Oil Consumption 6.0L AFM Unicorn?
by tahoe_hybrid. 06/24/19 04:27 PM
PP 5W-20, 3000mi, '14 Kia Soul
by tc1446. 06/24/19 03:07 PM
Cheap powerfull filter magnet
by loneryder. 06/24/19 01:50 PM
New road tire time
by UG_Passat. 06/24/19 01:46 PM
Royal Purple 75W90 vs. Store Brand Synthetic
by WondrousBread. 06/24/19 12:50 PM
Jeep Renegade MTF Alternatives?
by Sunnyinhollister. 06/24/19 12:28 PM
Havoline 0W20 VI higher than 5w30 and 10w30?
by Whammo. 06/24/19 12:10 PM
New toy...19 Jetta GLI Autobahn
by CincyDavid. 06/24/19 12:00 PM
PCV Valve Cleaning Replacement ?
by ChrisD46. 06/24/19 11:54 AM
ml98188, 84FSP, megavoyager, thaduke2003, Vitaliy
68474 Registered Users
128 registered members (77GrandPrix, 97K15004WD, 53' Stude, aba4430, 2010Civic, 13 invisible), 2,220 guests, and 30 spiders.
Topics290,916
Posts4,995,236
Members68,474
Most Online2,967
Mar 10th, 2019
GE Oven Issue? #4783372
06/10/18 08:47 PM
06/10/18 08:47 PM
MURICA
maverickfhs Offline OP
MURICA
So I have this GE jgbp33beh3bb. For some reason, today when we tried to use Oven and used Pre-heat it's not doing anything.
Broil, stove, all controls and and lights, everything is working.
Does anyone know if it's possibly an igniter issue or something else? Thank you thumbsup
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: GE Oven Issue? [Re: maverickfhs] #4783383
06/10/18 08:57 PM
06/10/18 08:57 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
If it's gas & you don't see something glowing like a light bulb, the igniter is a good place to start. It should have 2, one for the broiler on top, and one for the oven burner down below. It is possible to switch them, I actually had to do mine on Thanksgiving Day a couple years ago to cook the turkey!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: GE Oven Issue? [Re: bullwinkle] #4783387
06/10/18 09:00 PM
06/10/18 09:00 PM
MURICA
MURICA
Thanks for the input. So you are saying oven one should be below in the tray area, is it? You are right, nothing is glowing like a heated rod in the oven area.
Because I can see an ignotor for the broil area in the top part, are they both interchangeable, if you know?
Re: GE Oven Issue? [Re: maverickfhs] #4783395
06/10/18 09:08 PM
06/10/18 09:08 PM
Kansas, USA
Kansas_Ron Online content
Kansas_Ron  Online Content
Kansas, USA
2000 Chevy Prizm
2015 Honda Civic
2017 Hyundai Elantra
Re: GE Oven Issue? [Re: maverickfhs] #4783397
06/10/18 09:09 PM
06/10/18 09:09 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
They were on my GE gas range, and they were identical. They can be checked with an ohmmeter, they usually go open, sometimes there are burn marks & cracks visible. It's also a good idea to wear rubber gloves, they can be damaged by the oil on your skin (like a halogen bulb).
Re: GE Oven Issue? [Re: maverickfhs] #4783399
06/10/18 09:09 PM
06/10/18 09:09 PM
MURICA
MURICA
Thanks all, I think it's the igniter and I'll go ahead and replace it.
Then see what happens smile
Re: GE Oven Issue? [Re: maverickfhs] #4783486
06/10/18 11:28 PM
06/10/18 11:28 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
There will also be an oven temperature sensor (which will disable the oven but not the broiler if failed).
Also the most common failure in these stoves (any modern stove) is the control panel (where you read oven temperatures, set the timer, etc). About a $350 part, typically. I repaired mine by replacing a failed relay, cost me $10. Same symptoms as you (everything worked except the oven). Frigidaire Gallery, but note that there are only about five manufacturers of ovens that sell into the North American 220~240V market, two are in South Korea, one is European.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: GE Oven Issue? [Re: maverickfhs] #4783630
06/11/18 08:17 AM
06/11/18 08:17 AM
Alberta
tcp71 Offline
tcp71  Offline
Alberta
Igniters are a somewhat regular replacement item for a gas stove. They also have a resistive circuit that controls the gas valve for th burner. If it doesn’t heat up and drop resistance in the circuit, the gas valve never opens. The lower one usually burns out first due to higher use.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: mobil 0w40 (varies)
Re: GE Oven Issue? [Re: tcp71] #4783632
06/11/18 08:19 AM
06/11/18 08:19 AM
MURICA
MURICA
Thanks, do you think I should replace both or just the one which is broken?
Re: GE Oven Issue? [Re: maverickfhs] #4783945
06/11/18 01:47 PM
06/11/18 01:47 PM
MURICA
MURICA
Did any of you buy OEM or went with aftermarket option?
Re: GE Oven Issue? [Re: maverickfhs] #4784089
06/11/18 05:02 PM
06/11/18 05:02 PM
West Michigan
Balrog006 Offline
Balrog006  Offline
West Michigan
Another likely culprit is the exhaust fan, GE is made by Whirlpool. Their current slew of models across a bunch of platforms for the past couple years has had a large batch of bad ones. The control panel will start the oven but when it senses the exhaust not being removed from the unit it shuts down, all within a couple seconds, after a few cycles of this it just bypasses the cycle and won’t start.
I had mine replaced under warranty at just shy of the 1 year mark-the repair crew said they keep a box of them in the truck at all times.
19 Ridgeline RTL-E >1K factory fill, A01
08 CRV 275K+ VSyn w/ML, A01
04 JD L130 740H, Mobil S 5w30
13 JD 2032r 325H, JD Plus 50 ii 15w40
M1Delvac 5w40 in OPE
