Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
27 registered members (Amkeer, coopns, CB900F2, ctechbob, DaHen, 5 invisible), 798 guests, and 46 spiders.
Topics306,079
Posts5,286,979
Members71,596
GE Oven Issue? #4783372 06/10/18 08:47 PM
M
maverickfhs Offline OP
M
So I have this GE jgbp33beh3bb. For some reason, today when we tried to use Oven and used Pre-heat it's not doing anything.
Broil, stove, all controls and and lights, everything is working.
Does anyone know if it's possibly an igniter issue or something else? Thank you thumbsup
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: GE Oven Issue? [Re: maverickfhs] #4783383 06/10/18 08:57 PM
B
bullwinkle Offline
B
If it's gas & you don't see something glowing like a light bulb, the igniter is a good place to start. It should have 2, one for the broiler on top, and one for the oven burner down below. It is possible to switch them, I actually had to do mine on Thanksgiving Day a couple years ago to cook the turkey!
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: GE Oven Issue? [Re: bullwinkle] #4783387 06/10/18 09:00 PM
M
M
Thanks for the input. So you are saying oven one should be below in the tray area, is it? You are right, nothing is glowing like a heated rod in the oven area.
Because I can see an ignotor for the broil area in the top part, are they both interchangeable, if you know?
Re: GE Oven Issue? [Re: maverickfhs] #4783395 06/10/18 09:08 PM
K
Kansas_Ron Offline
K
2000 Chevy Prizm
2015 Honda Civic
2017 Hyundai Elantra
Re: GE Oven Issue? [Re: maverickfhs] #4783397 06/10/18 09:09 PM
B
bullwinkle Offline
B
They were on my GE gas range, and they were identical. They can be checked with an ohmmeter, they usually go open, sometimes there are burn marks & cracks visible. It's also a good idea to wear rubber gloves, they can be damaged by the oil on your skin (like a halogen bulb).
Re: GE Oven Issue? [Re: maverickfhs] #4783399 06/10/18 09:09 PM
M
M
Thanks all, I think it's the igniter and I'll go ahead and replace it.
Then see what happens smile
Re: GE Oven Issue? [Re: maverickfhs] #4783486 06/10/18 11:28 PM
J
Johnny2Bad Offline
J
There will also be an oven temperature sensor (which will disable the oven but not the broiler if failed).
Also the most common failure in these stoves (any modern stove) is the control panel (where you read oven temperatures, set the timer, etc). About a $350 part, typically. I repaired mine by replacing a failed relay, cost me $10. Same symptoms as you (everything worked except the oven). Frigidaire Gallery, but note that there are only about five manufacturers of ovens that sell into the North American 220~240V market, two are in South Korea, one is European.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: GE Oven Issue? [Re: maverickfhs] #4783630 06/11/18 08:17 AM
T
tcp71 Offline
T
Igniters are a somewhat regular replacement item for a gas stove. They also have a resistive circuit that controls the gas valve for th burner. If it doesn’t heat up and drop resistance in the circuit, the gas valve never opens. The lower one usually burns out first due to higher use.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: GE Oven Issue? [Re: tcp71] #4783632 06/11/18 08:19 AM
M
M
Thanks, do you think I should replace both or just the one which is broken?
Re: GE Oven Issue? [Re: maverickfhs] #4783945 06/11/18 01:47 PM
M
M
Did any of you buy OEM or went with aftermarket option?
Re: GE Oven Issue? [Re: maverickfhs] #4784089 06/11/18 05:02 PM
B
Balrog006 Offline
B
Another likely culprit is the exhaust fan, GE is made by Whirlpool. Their current slew of models across a bunch of platforms for the past couple years has had a large batch of bad ones. The control panel will start the oven but when it senses the exhaust not being removed from the unit it shuts down, all within a couple seconds, after a few cycles of this it just bypasses the cycle and won’t start.
I had mine replaced under warranty at just shy of the 1 year mark-the repair crew said they keep a box of them in the truck at all times.
19 Ridgeline RTL-E >1K factory fill, A01
08 CRV 275K+ VSyn w/ML, A01
04 JD L130 740H, Mobil S 5w30
13 JD 2032r 325H, JD Plus 50 ii 15w40
M1Delvac 5w40 in OPE
