[Cut Open] Motorcraft FL500S - 5003 miles
by DuckRyder. 02/23/19 05:08 PM
Does Kia & Hundai use same motors?
by tc1446. 02/23/19 05:07 PM
Extreme fuel dilution
by BigShug681. 02/23/19 04:52 PM
Nine PH3600-size filters FS
by SubieRubyRoo. 02/23/19 04:45 PM
2003 Accord 2.4L Valve train pics
by WagonWheel. 02/23/19 04:24 PM
Leaky FL400s
by jongies3. 02/23/19 03:55 PM
Fram Ultra with Filter Mag pics
by ZZman. 02/23/19 03:39 PM
Which 0w20 meets VW 508.00?
by 53' Stude. 02/23/19 03:28 PM
RockAuto Injectors - Return / Weird
by StevieC. 02/23/19 02:23 PM
03 Nissan Maxima stalls uphill.
by LeakySeals. 02/23/19 01:47 PM
Delvac Rebate?
by 1JZ_E46. 02/23/19 01:23 PM
Oil recommendation for Audi turbo engine
by zorba02. 02/23/19 12:41 PM
Jeep Cherokee 2.4L oil consumption
by RedOak. 02/23/19 12:14 PM
2001 Grand Cherokee Rear Diff Lube
by Plimbob. 02/23/19 12:13 PM
2005 Forester Upper Radiator Hose
by HowAboutThis. 02/23/19 12:05 PM
2016 Civic 2.0. Strange driving habits. Which oil?
by DEEPfrom1. 02/23/19 12:03 PM
Mercedes OM617 3k Chevron Delo
by gonesurfing. 02/23/19 11:38 AM
snapy907, Barrett, Beez1204, vmasse, zorba02
67327 Registered Users
103 registered members (379KITTY, 2015_PSD, 2oldtommy, 01rangerxl, 10WSmuckers, 12 invisible), 1,883 guests, and 54 spiders.
Topics284,726
Posts4,875,851
Members67,327
Most Online2,548
Feb 16th, 2019
96 Grand Marquis using oil recently #4783360
06/10/18 07:34 PM
06/10/18 07:34 PM
Prospect, KY
spk2000 Offline OP
spk2000  Offline OP
Prospect, KY
My 96 GM has started using oilin the past 10-15,000 miles. It has 190,000 miles now. Probably a quart every 2,000 miles. I know some will say that's normal useage but it never used oil in past so why would it start using it. No oil leaks. Checked pcv valve and it was fine. I do normally use synthetic and lately has been 5w30 Castrol Edge but I use whatever is in stash. Any thoughts on why the sudden use of oil that did not exist in past.
96 Grand Marquis
01 Sable LS
02 Montero
Re: 96 Grand Marquis using oil recently [Re: spk2000] #4783366
06/10/18 07:44 PM
06/10/18 07:44 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Its only 22 yrs old. Its likely that the valve seals are hard and shrunk.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 96 Grand Marquis using oil recently [Re: spk2000] #4783369
06/10/18 07:45 PM
06/10/18 07:45 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Try some high mileage oil.
If you want the job done right......do it yourself.
Re: 96 Grand Marquis using oil recently [Re: spk2000] #4783373
06/10/18 07:47 PM
06/10/18 07:47 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Yeah, but looks can be deceiving.
Check all hoses & connections in the whole PCV system. A new PCV valve can't really hurt?
Re: 96 Grand Marquis using oil recently [Re: Chris142] #4783374
06/10/18 07:47 PM
06/10/18 07:47 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
That was my first thought .
But if it was me , I would not be too upser to add a quart at 2000 miles . And changing the oil when it was time to add the 2nd quart .
Wyr
God bless
Re: 96 Grand Marquis using oil recently [Re: spk2000] #4783483
06/10/18 10:17 PM
06/10/18 10:17 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
You could also find a thicker 5w-30, or go to a 10w-30 which would be fine in Kentucky's warm summer climate. I'd concur with the HM. Maybe shoot for a viscosity around 10.5-11.0 cSt at 100 deg C. If you're currently using a weaker 30 grade (ie 9.8-10.20...I'd bump it up. A quart at 2K miles is not too bad for that mileage.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: 96 Grand Marquis using oil recently [Re: spk2000] #4783521
06/11/18 12:36 AM
06/11/18 12:36 AM
Kuwait
Falcon_LS Offline
Falcon_LS  Offline
Kuwait
The OE PCV valve (Motorcraft EV-98-B) is only $6 or so, I would start there. Do you get any pinging?
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
03 Expedition SSV: XG2
05 Envoy: XG9837
06 XJ8L: C2C41611
07 SRX: XG8765
Re: 96 Grand Marquis using oil recently [Re: Linctex] #4783523
06/11/18 12:40 AM
06/11/18 12:40 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Yes, replace anyhow. I was getting "milkshake" in my F-150 in the winter some years back, despite no trip being shorter than 50 miles. PCV passed all the "tests." I replaced it, milkshake gone.
Plain, simple Garak.
Re: 96 Grand Marquis using oil recently [Re: spk2000] #4783551
06/11/18 03:48 AM
06/11/18 03:48 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Thoughts.....21 years old and 190000 miles.
One day long ago I did my routine of checking my oil, on my Ford 3.8, which I never had to add anything and was surprised it was one quart down. Ever since, I was adding a half quart every week or two and changing two spark plugs every month. Be glad it is still at a "normal" consumption level. The car was donated after a few months.
The "thinking" man's friend.
Re: 96 Grand Marquis using oil recently [Re: Garak] #4783586
06/11/18 05:56 AM
06/11/18 05:56 AM
Texas
wag123 Offline
wag123  Offline
Texas
+4
Replace the PCV valve.
Re: 96 Grand Marquis using oil recently [Re: spk2000] #4784095
06/11/18 04:06 PM
06/11/18 04:06 PM
Prospect, KY
spk2000 Offline OP
spk2000  Offline OP
Prospect, KY
I will replace the pvc valve
and yes I do get pinging under heavy acceleration or under load like climbing steep hill. Has done that for the past 100,000 miles. Premium fuel makes it run stronger and go away.
96 Grand Marquis
01 Sable LS
02 Montero
Re: 96 Grand Marquis using oil recently [Re: spk2000] #4784151
06/11/18 05:13 PM
06/11/18 05:13 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Sounds like too much spark advance . I used to set My little 2 barrel 289 to ping a tiny amount when I was getting on it hard .
Wyr
God bless
Re: 96 Grand Marquis using oil recently [Re: WyrTwister] #4784164
06/11/18 05:22 PM
06/11/18 05:22 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
The 4.6 does not have adjustable timing. Well it can with a tuner, but normally no you can't change it.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 96 Grand Marquis using oil recently [Re: spk2000] #4784476
06/12/18 12:25 AM
06/12/18 12:25 AM
Kuwait
Falcon_LS Offline
Falcon_LS  Offline
Kuwait
Yup, definitely replace that PCV valve. Sounds like oil is being sucked in through it, causing the engine to run leaner and hotter.
It wasn't until 2003 that these cars got knock sensors, a '96 does not have adjustable timing. That being said, although time and mileage is definitely a factor, unless it has been neglected, the likely hood of bad valve seals isn't all that common on post '95 engines with the updated seal material.
99 Explorer: H17W02
00 Pajero: XG9688
05 Envoy: XG9837
06 XJ8L: C2C41611
07 SRX: XG8765
Re: 96 Grand Marquis using oil recently [Re: spk2000] #4785170
06/12/18 05:55 PM
06/12/18 05:55 PM
Prospect, KY
spk2000 Offline OP
spk2000  Offline OP
Prospect, KY
Would I see oil leaking if the valve seals were bad? I see nothing leaking but it is going somewhere.
96 Grand Marquis
01 Sable LS
02 Montero
Moderated by  ekpolk
