Forums Migration
Please read this thread
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Full Synthetic for ATS V
by cadillactech - 07/12/20 11:33 AM
Gasoline engine oil in a diesel engine?
by LeslieX - 07/12/20 11:32 AM
Can I use IPA 70% to clean windshield?
by painfx - 07/12/20 09:47 AM
The Heat is on
by Snagglefoot - 07/12/20 07:39 AM
Working on your car
by CourierDriver - 07/12/20 07:35 AM
My last two cars were direct injection
by Railrust - 07/12/20 06:52 AM
High Flow Thermostats
by Nick1994 - 07/12/20 02:51 AM
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
97 Civic HX valve cover pics
by CARJ - 07/11/20 10:22 PM
Time to ditch Speedplays
by UG_Passat - 07/11/20 10:03 PM
Dale L Nuzum
by Dalenuzum - 07/11/20 10:02 PM
*BANG* (Garage Door Spring)
by ctechbob - 07/11/20 09:40 PM
TPMS Sensors
by 92saturnsl2 - 07/11/20 09:16 PM
cadillactech, ILoveOil111, quantalume, SUmeme22, DaveCaddell
71910 Registered Users
78 registered members (77Se7en, alarmguy, 92saturnsl2, apham8, avi1777, 2015_PSD, 9 invisible), 2,124 guests, and 23 spiders.
Topics307,760
Posts5,317,262
Members71,910
Carquest blue #4783202 06/10/18 04:49 PM
M
mjoekingz28 Offline OP
M
Hello all. I am filter shopping and am pretty much going to get an AC PF46e no matter what. But I am wondering what info is there on the CarQuest 85042.the external parts look very nice (can coating, plate, gasket). I just would like to know if there are cut aways, does Mann and Hummel/Wix make them, and whatever other pertinent info you may have.
I will now attempt to use, the search.
Edit: also flow rates could be interesting... AutoZone has the pf46e at 3 gallons per minute.
Just for reference, the wix51042 was rated at 9-11 gpm max per the Wix webpage.
I think flowrate makes a difference, much like in fuellies and engine aero filters.
Re: Carquest blue [Re: mjoekingz28] #4783212 06/10/18 05:20 PM
Z
ZeeOSix Offline
Z
Those flow rate specs don't mean anything useful unless they say what the oil viscosity and delta-p was at those flow rates. Just like saying a filter is "99% efficient" without saying at micron size - it doesn't give enough info.
Re: Carquest blue [Re: mjoekingz28] #4783243 06/10/18 05:56 PM
slacktide_bitog Offline
The CQ Blue is a reboxed Purolator P1, so stay away from it. They tear like any other modern Purolator
The AC Delco is a better filter than the CQ.
Re: Carquest blue [Re: mjoekingz28] #4783293 06/10/18 06:58 PM
SubieRubyRoo Offline
I don't remember seeing torn PureOnes... some boss and some of the base-level Puros sure but I don't think even car51 has found torn P1s... may be wrong but I feel I'd remember them.
There are plenty of good filters out there, plus even really good filters are less than $10, so why scrimp to save $3-4 for something that's keeping your engine in one piece?
De omnibus dubitandum.
Re: Carquest blue [Re: SubieRubyRoo] #4783308 06/10/18 07:15 PM
Z
ZeeOSix Offline
Z
PureOnes were in the mix. Google search the board for 'torn filter spreadsheet'.
Re: Carquest blue [Re: mjoekingz28] #4783314 06/10/18 07:27 PM
N
Nyogtha Offline
N
If you are lucky you will get a NOS Wix or Frampion CQ Blue from before the supplier was switched to Purolator. Unfortunately these aren't out on customer shelves where you can root through them yourself, you get luck of the draw on what the clerk gets off the shelves behind the store counter.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Carquest blue [Re: mjoekingz28] #4783317 06/10/18 07:30 PM
Z
ZeeOSix Offline
Z
Re: Carquest blue [Re: ZeeOSix] #4783359 06/10/18 08:34 PM
rollinpete Offline
Originally Posted By: ZeeOSix
Thanks for the link. smile
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 190k
SRGT 5w30
Whip City Wrencher
Currently under the influence of oil shocked2
Re: Carquest blue [Re: mjoekingz28] #4783380 06/10/18 08:52 PM
L
Linctex Offline
L
Have you thought about trying some of the ones RockAuto sells?
It might be worth the gamble.
Re: Carquest blue [Re: Linctex] #4783567 06/11/18 05:39 AM
K
krismoriah72 Offline
K
Why do you want an E-Core? PF46 is easy to find at Advance Auto.
Re: Carquest blue [Re: mjoekingz28] #4783739 06/11/18 10:29 AM
M
M
I try to go with factory parts usually/always when possible.
I was simply considering a Wix and saw the CQ blue looked good- so I had considered trying something different. But then thinking and hearing your opinions....the PF has been fine for 2-3 oil changes in a row so far, and I hear the cage is even better for increased flow (which is important to me) and also GM and Champion seems to have really tried with the Ecore making a lot out of a little.....dependable, solid performance, and good/not as bad for Earth. I was just kind of concerned with hearing all these no oil pressure stories with the ACDelc which was fixed by switching to any other brand oil filter.
