16 F150 3.5EB ~8K VPB 15W40
by BeerCan - 09/19/19 07:55 AM
Old skool carburetor rebuilding.
by Chris142 - 09/19/19 07:50 AM
Construction - Vintage Warning
by MasterSolenoid - 09/19/19 06:55 AM
Toro 12-38
by supton - 09/19/19 06:36 AM
EV tuktuk batteries
by Superflan - 09/19/19 02:09 AM
Car engine issues
by Espada - 09/19/19 01:12 AM
2002 chevy tahoe 5.3 oil selection
by Zahndkile - 09/19/19 12:20 AM
Considering Solar
by mbacfp - 09/18/19 11:16 PM
2008 Duramax
by Firemedic15 - 09/18/19 11:02 PM
Fleetguard LF777 performance
by Pyrotechnic - 09/18/19 10:54 PM
Any Vacuum experts? :)
by maverickfhs - 09/18/19 09:50 PM
15 F150 Gear & Transfer Case Question
by BISCUT - 09/18/19 09:24 PM
Anyone buy/run used tires?
by addyguy - 09/18/19 08:15 PM
2019 Mazda CX-5 Diesel
by miden851 - 09/18/19 07:58 PM
Toyota 90915-YZZD1 Cut Open (Sludge?)
by ThirdeYe - 09/18/19 07:45 PM
Fram Core COR3614ACC Cut Open
by ThirdeYe - 09/18/19 07:35 PM
Never the cheap part that goes bad...
by Elkins45 - 09/18/19 07:34 PM
Denso First Time Fit 150-1009 Cut Open (2 filters)
by ThirdeYe - 09/18/19 07:31 PM
2008 CRV A/C compressor replacement
by nwjones18 - 09/18/19 07:27 PM
Fram Ultra XG4967 Cut Open
by ThirdeYe - 09/18/19 07:25 PM
JDubyah, 05SentraRed, TSpinner, bbrown, Firemedic15
69326 Registered Users
103 registered members (2015_PSD, 1978elcamino, ARCOgraphite, 4WD, 05SentraRed, 2004tdigls, 11 invisible), 1,541 guests, and 26 spiders.
Topics294,767
Posts5,066,162
Members69,326
Most Online3,532
Jul 30th, 2019
Carquest blue #4783202 06/10/18 04:49 PM
M
mjoekingz28 Offline OP
M
Hello all. I am filter shopping and am pretty much going to get an AC PF46e no matter what. But I am wondering what info is there on the CarQuest 85042.the external parts look very nice (can coating, plate, gasket). I just would like to know if there are cut aways, does Mann and Hummel/Wix make them, and whatever other pertinent info you may have.
I will now attempt to use, the search.
Edit: also flow rates could be interesting... AutoZone has the pf46e at 3 gallons per minute.
Just for reference, the wix51042 was rated at 9-11 gpm max per the Wix webpage.
I think flowrate makes a difference, much like in fuellies and engine aero filters.
Re: Carquest blue [Re: mjoekingz28] #4783212 06/10/18 05:20 PM
Z
ZeeOSix Offline
Z
Those flow rate specs don't mean anything useful unless they say what the oil viscosity and delta-p was at those flow rates. Just like saying a filter is "99% efficient" without saying at micron size - it doesn't give enough info.
Re: Carquest blue [Re: mjoekingz28] #4783243 06/10/18 05:56 PM
slacktide_bitog Offline
The CQ Blue is a reboxed Purolator P1, so stay away from it. They tear like any other modern Purolator
The AC Delco is a better filter than the CQ.
Re: Carquest blue [Re: mjoekingz28] #4783293 06/10/18 06:58 PM
SubieRubyRoo Offline
I don't remember seeing torn PureOnes... some boss and some of the base-level Puros sure but I don't think even car51 has found torn P1s... may be wrong but I feel I'd remember them.
There are plenty of good filters out there, plus even really good filters are less than $10, so why scrimp to save $3-4 for something that's keeping your engine in one piece?
Re: Carquest blue [Re: SubieRubyRoo] #4783308 06/10/18 07:15 PM
Z
ZeeOSix Offline
Z
PureOnes were in the mix. Google search the board for 'torn filter spreadsheet'.
Re: Carquest blue [Re: mjoekingz28] #4783314 06/10/18 07:27 PM
N
Nyogtha Offline
N
If you are lucky you will get a NOS Wix or Frampion CQ Blue from before the supplier was switched to Purolator. Unfortunately these aren't out on customer shelves where you can root through them yourself, you get luck of the draw on what the clerk gets off the shelves behind the store counter.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Carquest blue [Re: mjoekingz28] #4783317 06/10/18 07:30 PM
Z
ZeeOSix Offline
Z
Re: Carquest blue [Re: ZeeOSix] #4783359 06/10/18 08:34 PM
rollinpete Offline
Originally Posted By: ZeeOSix
Thanks for the link. smile
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 188k miles
03 Saturn Ion 2.2 L4 5spd 239k miles
PP, PPHM 50/50 5w30
Currently under the influence of oil shocked2
Re: Carquest blue [Re: mjoekingz28] #4783380 06/10/18 08:52 PM
L
Linctex Offline
L
Have you thought about trying some of the ones RockAuto sells?
It might be worth the gamble.
Re: Carquest blue [Re: Linctex] #4783567 06/11/18 05:39 AM
K
krismoriah72 Offline
K
Why do you want an E-Core? PF46 is easy to find at Advance Auto.
Re: Carquest blue [Re: mjoekingz28] #4783739 06/11/18 10:29 AM
M
M
I try to go with factory parts usually/always when possible.
I was simply considering a Wix and saw the CQ blue looked good- so I had considered trying something different. But then thinking and hearing your opinions....the PF has been fine for 2-3 oil changes in a row so far, and I hear the cage is even better for increased flow (which is important to me) and also GM and Champion seems to have really tried with the Ecore making a lot out of a little.....dependable, solid performance, and good/not as bad for Earth. I was just kind of concerned with hearing all these no oil pressure stories with the ACDelc which was fixed by switching to any other brand oil filter.
