Loc-n-lube
by rideon. 07/19/19 07:57 PM
Loc-n-lube
by rideon. 07/19/19 07:54 PM
Humidity thread follow-up... phew!
by 14Accent. 07/19/19 06:55 PM
NEW FEDERATED LF651F FILTER CUT OPEN
by 53' Stude. 07/19/19 06:39 PM
Brake Job @ 26K On My GLC43
by 2015_PSD. 07/19/19 06:25 PM
New Scanner Autel MK808BT
by another Todd. 07/19/19 06:20 PM
Does MMO= Mind over matter?
by csandste. 07/19/19 05:58 PM
So they do exist...Mahindra Roxor
by 01rangerxl. 07/19/19 05:42 PM
NEW ROTELLA RTO-177 FILTER CUT OPEN
by 53' Stude. 07/19/19 05:37 PM
NEW PRIME GUARD POF 6128
by 53' Stude. 07/19/19 05:26 PM
Hayward Pool Filter ????
by Oldtom. 07/19/19 04:27 PM
Constant pressure well system fluctuating
by LeakySeals. 07/19/19 04:22 PM
C&P XG3387A with filter mag - 6318 miles, 6 months
by shibby6600. 07/19/19 04:19 PM
Engine oil from natural gas??
by sloinker. 07/19/19 04:11 PM
Jeep for 16 year old
by stockrex. 07/19/19 03:51 PM
Mustache no beard?
by sloinker. 07/19/19 03:50 PM
GS430 Toyota WS transmission oil
by Shaz. 07/19/19 03:35 PM
ctwhitechin, gwandless, Philippe1988, ChiefDaBooty, JIMBO5658
68711 Registered Users
123 registered members (01rangerxl, 1WildPig, 1foxracing, 14Accent, 2015_PSD, 4WD, 13 invisible), 2,029 guests, and 30 spiders.
Topics292,110
Posts5,017,024
Members68,711
Most Online2,967
Mar 10th, 2019
Carquest blue #4783202
06/10/18 04:49 PM
06/10/18 04:49 PM
United States of America
mjoekingz28 Offline OP
Hello all. I am filter shopping and am pretty much going to get an AC PF46e no matter what. But I am wondering what info is there on the CarQuest 85042.the external parts look very nice (can coating, plate, gasket). I just would like to know if there are cut aways, does Mann and Hummel/Wix make them, and whatever other pertinent info you may have.
I will now attempt to use, the search.
Edit: also flow rates could be interesting... AutoZone has the pf46e at 3 gallons per minute.
Just for reference, the wix51042 was rated at 9-11 gpm max per the Wix webpage.
I think flowrate makes a difference, much like in fuellies and engine aero filters.
Re: Carquest blue [Re: mjoekingz28] #4783212
06/10/18 05:20 PM
06/10/18 05:20 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Those flow rate specs don't mean anything useful unless they say what the oil viscosity and delta-p was at those flow rates. Just like saying a filter is "99% efficient" without saying at micron size - it doesn't give enough info.
Re: Carquest blue [Re: mjoekingz28] #4783243
06/10/18 05:56 PM
06/10/18 05:56 PM
USA
slacktide_bitog Offline
USA
The CQ Blue is a reboxed Purolator P1, so stay away from it. They tear like any other modern Purolator
The AC Delco is a better filter than the CQ.
Re: Carquest blue [Re: mjoekingz28] #4783293
06/10/18 06:58 PM
06/10/18 06:58 PM
The land of USA-made Subies!
SubieRubyRoo Offline
I don't remember seeing torn PureOnes... some boss and some of the base-level Puros sure but I don't think even car51 has found torn P1s... may be wrong but I feel I'd remember them.
There are plenty of good filters out there, plus even really good filters are less than $10, so why scrimp to save $3-4 for something that's keeping your engine in one piece?
Re: Carquest blue [Re: SubieRubyRoo] #4783308
06/10/18 07:15 PM
06/10/18 07:15 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
PureOnes were in the mix. Google search the board for 'torn filter spreadsheet'.
Re: Carquest blue [Re: mjoekingz28] #4783314
06/10/18 07:27 PM
06/10/18 07:27 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
If you are lucky you will get a NOS Wix or Frampion CQ Blue from before the supplier was switched to Purolator. Unfortunately these aren't out on customer shelves where you can root through them yourself, you get luck of the draw on what the clerk gets off the shelves behind the store counter.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Carquest blue [Re: mjoekingz28] #4783317
06/10/18 07:30 PM
06/10/18 07:30 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Re: Carquest blue [Re: ZeeOSix] #4783359
06/10/18 08:34 PM
06/10/18 08:34 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
Originally Posted By: ZeeOSix
Thanks for the link. smile
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 188k miles
03 Saturn Ion 2.2 L4 5spd 239k miles
PP, PPHM 50/50 5w30
Currently under the influence of oil shocked2
Re: Carquest blue [Re: mjoekingz28] #4783380
06/10/18 08:52 PM
06/10/18 08:52 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Have you thought about trying some of the ones RockAuto sells?
It might be worth the gamble.
Re: Carquest blue [Re: Linctex] #4783567
06/11/18 05:39 AM
06/11/18 05:39 AM
wv
krismoriah72 Offline
wv
Why do you want an E-Core? PF46 is easy to find at Advance Auto.
Re: Carquest blue [Re: mjoekingz28] #4783739
06/11/18 10:29 AM
06/11/18 10:29 AM
I try to go with factory parts usually/always when possible.
I was simply considering a Wix and saw the CQ blue looked good- so I had considered trying something different. But then thinking and hearing your opinions....the PF has been fine for 2-3 oil changes in a row so far, and I hear the cage is even better for increased flow (which is important to me) and also GM and Champion seems to have really tried with the Ecore making a lot out of a little.....dependable, solid performance, and good/not as bad for Earth. I was just kind of concerned with hearing all these no oil pressure stories with the ACDelc which was fixed by switching to any other brand oil filter.
