Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
SUPREME C3-X SYNTHETIC 5W-30
by 21Rouge. 03/24/19 12:17 PM
Do you use your Pick Up like a truck or car?
by ZZman. 03/24/19 10:52 AM
My mom needs a new phone. Ideas?
by kpatter. 03/24/19 09:40 AM
2017 vw Jetta se vs 2017 Ford fusion se
by A1O. 03/24/19 09:39 AM
Fram Pro Synthetic #9688 **NEW** CUT OPEN
by 53' Stude. 03/24/19 08:26 AM
Wagner OEX vs Akebono ProACT
by Patrick0525. 03/24/19 08:12 AM
Plasti Diping my OEM rims question
by dblshock. 03/24/19 07:53 AM
"The new" Mobil 1 Racing Oil ?
by lawnguy. 03/24/19 06:32 AM
Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
94 registered members (14Accent, A1O, Astro14, andyd, 97K15004WD, 8 invisible), 2,428 guests, and 52 spiders.
Topics286,339
Posts4,906,722
Members67,599
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
ATF foaming up #4783070
06/10/18 01:33 PM
06/10/18 01:33 PM
TX
parshisa Offline OP
parshisa  Offline OP
TX
So i did drain and fill on my pilot in singature yesterday, drain 3.5qts and put the same amount back in. Drive the car, got it nice and hot, checked the level as per manual - right on the middle. This morning pulled the dipstick and the level was twice as it should be(?!). I went ahead and started the car, ran through the gears, shut it off and pulled the dipstick - foamy ATF on it ([censored]). Level read between the dots. Foaming was gone in a matter if seconds. Ok, drove the car for a few miles, deives just fine, checked the level again - slightly above min as it was yesterday and no singa of foaming.
My question is - what the heck was that???
Re: ATF foaming up [Re: parshisa] #4783077
06/10/18 01:43 PM
06/10/18 01:43 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
You should be checking the level with the engine running I believe. Should say so in the owners manual.
https://www.carcarekiosk.com/video/2016_Honda_Pilot_EX_3.5L_V6/transmission_fluid/check_fluid_level
Re: ATF foaming up [Re: parshisa] #4783080
06/10/18 01:45 PM
06/10/18 01:45 PM
Ajax,Ontario, Canada
Pelican Offline
Pelican  Offline
Probably the ATF coming out was warmer than the one going in and you may have overfilled it.
Re: ATF foaming up [Re: parshisa] #4783095
06/10/18 01:59 PM
06/10/18 01:59 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
Check it with the engine running and AT warm after driving. Owners manual is a good read. Ed
CX5 Touring 2.5L :-)
Re: ATF foaming up [Re: Eddie] #4783097
06/10/18 02:05 PM
06/10/18 02:05 PM
TX
parshisa Offline OP
parshisa  Offline OP
TX
Good one. But these transmissions are to be checked with engine off
Re: ATF foaming up [Re: parshisa] #4783101
06/10/18 02:13 PM
06/10/18 02:13 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
REALLY?
Re: ATF foaming up [Re: Eddie] #4783104
06/10/18 02:20 PM
06/10/18 02:20 PM
TX
parshisa Offline OP
parshisa  Offline OP
TX
Really
Re: ATF foaming up [Re: parshisa] #4783132
06/10/18 03:11 PM
06/10/18 03:11 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
Unlike most other cars, Honda automatic transmissions are checked with the car OFF
Honda uses a different design than other automatics out there. For one, they don't use planetary gears, but rather, something more like an automated manual, with gears like a manual but engaged by hydraulics.
Only recently has Honda begun using outside transmissions like ZF.
Re: ATF foaming up [Re: SatinSilver] #4783146
06/10/18 03:37 PM
06/10/18 03:37 PM
CA
The Critic Offline
The Critic  Offline
CA
You may want to try researching a bit harder, and using more reputable sources to provide information to others.
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Re: ATF foaming up [Re: Pelican] #4783165
06/10/18 03:59 PM
06/10/18 03:59 PM
TX
parshisa Offline OP
parshisa  Offline OP
TX
Fluid out was slightly warmer than fluid in. And amount if the fluid out and in are very close to te book number. So it wasnít overfilled for sure
Re: ATF foaming up [Re: parshisa] #4783254
06/10/18 06:12 PM
06/10/18 06:12 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Air in the system somewhere, possibly leak down when you drained it or incorrect fill level. Foaming = Air.
Re: ATF foaming up [Re: Trav] #4783261
06/10/18 06:19 PM
06/10/18 06:19 PM
TX
parshisa Offline OP
parshisa  Offline OP
TX
Iíve driven it for a good 15-20miles and checked again - level is spot on. And it was yesterday wheneve i changed it and drove for a couplenpf miles. Just weird and makes no sense. Any possible harm to the trans with that foaming event?
Re: ATF foaming up [Re: parshisa] #4783264
06/10/18 06:21 PM
06/10/18 06:21 PM
Trav Offline
Trav  Offline
No.
Re: ATF foaming up [Re: Trav] #4783267
06/10/18 06:22 PM
06/10/18 06:22 PM
TX
parshisa Offline OP
parshisa  Offline OP
TX
Any tips and tricks on how to avoid it in future?
Re: ATF foaming up [Re: parshisa] #4783270
06/10/18 06:25 PM
06/10/18 06:25 PM
Trav Offline
Trav  Offline
If its leaking down because the sump is empty when you drain it then probably not, the air got pushed out in a few seconds along with some fluid so it was not dry. Air goes to the top, the pickup was still drawing liquid.
Page 1 of 3 1 2 3
