Originally Posted By: dabo72
which oil filter would you recommend on a 2017 5.3 silverado. Running valvoline 0w-20 and change oil every 5000. thx.
NAPA Gold 100255 or Wix WL10255 has the correct bypass pressure threshold (GM requires it) and its better than the AC-Delco lower quality oil filters.
You can also use the Fram Racing HP19, having a 4548-12 efficiency almost the same as the Wix-NAPAgold's, and better than AC-Delco, with very rugged construction.
Originally Posted By: Linctex
Originally Posted By: Rat407
One that has the 22psi by-pass setting as required by GM.
But is it truly a REQUIREMENT? Not any that I have heard of.
Yes, requirement for warranty engine claims.
https://www.corvetteforum.com/forums/att...f-pf64-pf48.pdf They could potentially deny warranty coverage if you have a problem.
Plus, during the winter especially, we all want to avoid bypass events, right?! Makes sense, and GM engineers are saying it, so just do it.
