RATS
by MrQuackers - 12/07/19 07:46 PM
113 registered members (64bawagon, 2004tdigls, alarmguy, 2015_PSD, 007, 69GTX, 7 invisible),
2,326
guests, and 54
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,438
Posts5,135,448
Members70,066
Most Online3,589 Nov 2nd, 2019
Exhaust Scavenging
#4782825
06/10/18 07:12 AM
Char Baby
OP
OP
Posts: 11,954 |
Yes, I've looked this up but, find too much mumble/jumble. Can someone explain in more simple terms of what exhaust scavenging is/dose...without writing a book? Or is there too much to detail in order to explain briefly?
Thanks,
CB
"Retired" -----------------------------------
'80 Firebird FORMULA V8/4bbl-purchased "NEW" '15 Nissan Altima 2.5 SV '15 Honda Civic 1.8 LX
Re: Exhaust Scavenging
[Re: Char Baby]
#4782846
06/10/18 07:27 AM
ragtoplvr
Posts: 1,448 |
Ever shut a faucet too fast and have water hammer? Enough energy in the inertia of the flowing water to shake the pipes.
Flowing exhaust has energy too. Using that energy to enhance the flow is able to pull more exhaust out a closing valve. or on an opening valve on an adjacent cylinder.
Rod
[Re: ragtoplvr]
#4782861
06/10/18 07:41 AM
Char Baby
OP
OP
Posts: 11,954 |
Rod
Perfect, thanks!
[Re: Char Baby]
#4783000
06/10/18 10:58 AM
BrocLuno
Posts: 6,216 |
That's an apt description, but in the case of exhaust, it's frequency dependent and usually does not start until north of 3,000 RPM ... It is tune-able like a Pipe Organ tubes. Hence the search for the right length and size of collector tube and extension. It does not generate HP per se, but helps achieve more air flow and that helps with the HP. There is a YT vid on Engine Masters where they test various exhausts and you can see the results compared
[Re: Char Baby]
#4783044
06/10/18 11:59 AM
CT8
Posts: 14,214 |
Add to the exhaust tuning intake tuning. It is exactly the same but different.
