Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Slight performance decrease
by A_User55555. 01/21/19 06:54 PM
how to keep your vehicle battery...
by Char Baby. 01/21/19 06:31 PM
2012 to 2016 ford focus
by WhyMe. 01/21/19 06:30 PM
LHM anyone?
by mistersooty. 01/21/19 06:30 PM
Walmart Oil Changes.
by Bill7. 01/21/19 06:10 PM
Coolbreez1973, jmcast1127, DF8005, FT86dude11, RTSAllison
67008 Registered Users
33 registered members (Char Baby, berniedd, alcyon, billt460, BlakeB, citationxeleven, 5 invisible), 868 guests, and 37 spiders.
Topics296,961
Posts4,962,404
Members67,008
Most Online2,821
Jan 21st, 2019
98 Dodge Caravan No Turn Signal Diag #4782737
06/10/18 04:37 AM
06/10/18 04:37 AM
Specific Ocean
Kibitoshin Online content OP
Kibitoshin  Online Content OP
Specific Ocean
Got this hunk of junk in for inop turn signal and ABS light on so first thing I checked was turn signal stalk, flasher relay, and hazard fuse. Unfortunately I jumped the gun and threw in a new turn signal stalk and that did not fix the problem. Checked relay (videos showing bad solder) and looked a-okay.
Poked around the underdash fusebox and found the ABS and reverse light fuse blown, replaced the fuse and the turn signals work but the reverse lights came on while it was still in park. A few moments later the reverse lights went off as the fuse blew again (as I was shifting the lever.)
Looked through wiring diagrams and this particular fuse (RUN A22 - FUSE 12 10A) feeds the reverse light, ABS, and turn signal relay.
The turn signal works and the ABS light went off with key on and new fuse so that's ruled out.
My attention is now the reverse lamp circuit. It's a 10amp POS feed to the trans range sensor/reverse switch (not sure) then to the rear lamps.
Another odd thing I've discovered is the gear selector display shows all gears selected when in park.
Trying to narrow down this issue because changing the range switch involves dropping the valve body in these trans so I need to make the right call before tearing into the trans.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: 98 Dodge Caravan No Turn Signal Diag [Re: Kibitoshin] #4782743
06/10/18 04:47 AM
06/10/18 04:47 AM
Tn.
CourierDriver Offline
Tn.
suggest you find a low voltage/high voltage technician that deals in troubleshooting circuits and is experienced in voltage drop calculations and circuit analysis techniques. If you can find such a person...good luck.
turn in your old jackets, shirts and other clothes to a Salvation Army or any homeless shelter this year...
Re: 98 Dodge Caravan No Turn Signal Diag [Re: Kibitoshin] #4782834
06/10/18 07:17 AM
06/10/18 07:17 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Any way to jump across 1 & 3 on the position switch and see if the fuse holds? That would tell you if it's the switch, or the wiring going back to the backup lamps.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 98 Dodge Caravan No Turn Signal Diag [Re: Kibitoshin] #4782964
06/10/18 09:53 AM
06/10/18 09:53 AM
Canada
Run Offline
Run  Offline
Canada
This sounds familiar to a problem I had with a 96 caravan. In my case there was an aftermarket trailer wiring harness and it got damaged and shorted out. I was blowing fuses for the lights. The turn signal wouldn't work. Sometimes the turn light came on but didn't blink and wouldn't shut off. I removed the harness and returned it to stock. Problem solved in that case.
03 Neon 2.0 - VSP 5W-30 Pentius XL
Re: 98 Dodge Caravan No Turn Signal Diag [Re: Run] #4782980
06/10/18 10:31 AM
06/10/18 10:31 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
That's the sort of thing I thought he might have going on-a pinched wire somewhere that is grounding out & blowing the fuse, or the position switch in the transmission is grounding out. May or may not be detectable with a VOM to ground, and I wouldn't use a megger (megohm meter) on a car, too easy to blow up electronic parts.
Re: 98 Dodge Caravan No Turn Signal Diag [Re: Kibitoshin] #4783118
06/10/18 01:41 PM
06/10/18 01:41 PM
ME
eljefino Online content
eljefino  Online Content
ME
This is randomly stupid but there's a giant wiring distribution blob behind the blower motor speed selector that overheats and goes south on these vans, negatively affecting the BCM and who knows what else.
Also tug on the harnesses while it runs, I had one with wires broken inside the insulation, no fun at all.
Re: 98 Dodge Caravan No Turn Signal Diag [Re: Kibitoshin] #4784319
06/11/18 07:47 PM
06/11/18 07:47 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Disconnect the Range Switch & look closely at the wires going into the connector.
The 41TE transaxle is notorious for leaky cooler hoses & TCM to Case gasket, The ATF gets on the the range switch wiring & eats through the insulation causing shorts.
Also check that the Manual Shift Lever isn't rubbing a harness.
2001 Chevy Camaro L92/4L80E
