How often to drive a car that sits in the winter?
by Corollaman. 02/17/19 08:49 AM
Top Off or Change it Early
by 99Saturn. 02/17/19 08:22 AM
Do your vehicles have a nickname?
by ZZman. 02/17/19 08:19 AM
Another work project thread
by mattd. 02/17/19 08:18 AM
Buzzing sound behind dash
by Spetz. 02/17/19 05:09 AM
Ain't stupid, but can't find Cummin Hist
by BrocLuno. 02/16/19 11:41 PM
Rethinking oil choices
by JLTD. 02/16/19 11:29 PM
coolster 150 cc atv 2019 new
by hyperscion. 02/16/19 10:37 PM
older gps - week counter rollover Apr 6 '19
by spackard. 02/16/19 10:32 PM
Thoughts on an old Lexus?
by JustN89. 02/16/19 09:50 PM
Understanding Fuel Trims for diagnostics.
by StevieC. 02/16/19 07:59 PM
book of matches for tune up?
by marine65. 02/16/19 07:53 PM
New Penrite 0w-30
by toyota62. 02/16/19 07:45 PM
New HID bulbs for the Cadillac
by 14Accent. 02/16/19 07:17 PM
2008 Prius - Water in oil
by cjolson140. 02/16/19 07:00 PM
Kitchen Faucet question
by reemoe2. 02/16/19 06:56 PM
Time for brakes again
by SilverFusion2010. 02/16/19 05:23 PM
Darn brake rotors
by Dave Sherman. 02/16/19 03:42 PM
looking @ a 2010 Escape Hybrid...
by earlyre. 02/16/19 03:24 PM
jpdeal, Snipeuout, DeltaWing, JRS3, krzyq
67252 Registered Users
105 registered members (53' Stude, Audios, berlyn, AdditiveOCD, alarmguy, 10 invisible), 1,603 guests, and 51 spiders.
Topics298,304
Posts4,989,185
Members67,252
Most Online2,548
Feb 16th, 2019
'05 Impala front wheel "squeal". #4782712
06/10/18 02:49 AM
06/10/18 02:49 AM
chicagoland
Lee4212 Offline OP
Lee4212  Offline OP
chicagoland
Have had this "squeal" sound for a about 1 month or a bit more now.
Had NEW rotors on all corners with pads about 1 week ago, noise still there !! Fronts we're not that bad but i got them done anyway,rears we're not working anymore.
Lately it's been 20 mph and less, take some turns fairly tight and it get's LOUDER and can go away..or not.(just like i never had the brakes replaced).
Saturday i rocked the car by hand back and forth, found a squeal noise passenger side worse than drivers, alot worse. Now by "looking" around i seem to hear it not from the brakes while rocking the car but the axle (?), could it be from a bad axle or going bad??
It still has winter tires on it but changing them next week to the General RT43 tires(it's a cash flow issue).
Odd that it can (but not always) go away if i hit a bump..like something shifted.
Confused yet lol,i'm puzzled.
I can start it and crawl forwards OR backwards and i hear that squeal.
It's NOT any sort of scraping like a bad pad indicator would make. Like a wet rubber shoe on tile flooring.
Funny thing...if i take a turn in a parking lot and go over those parking lot stripes the front tires can make that squeal sound even on dry days.
Lost..i am so i am here for any direction to go.
Car run flawlessly so i keep it,can't hear/feel it run most of the time! Almost 64,000 on it, i like to maintain it as best as i can.
(Rust at the lower front panels is about it).
Input ?? Thanks friends !!!
Re: '05 Impala front wheel "squeal". [Re: Lee4212] #4782721
06/10/18 03:40 AM
06/10/18 03:40 AM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
By your description I'd say a bad wheel bearing.
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive236K miles
PPHM 5w30 x 2 Fram Ultra x 2
Currently under the influence of oil shocked2
Re: '05 Impala front wheel "squeal". [Re: Lee4212] #4782734
06/10/18 04:27 AM
06/10/18 04:27 AM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
Bad ball joint is my vote.
1997 Maxima 195k, Castrol GTX Synblend 5W-30, FL400S
2004 Corolla 196k, VWB 5w20 + SSS 10w40, MGL4967
Re: '05 Impala front wheel "squeal". [Re: Lee4212] #4782736
06/10/18 04:34 AM
06/10/18 04:34 AM
out there
spasm3 Online content
spasm3  Online Content
out there
Sounds like a bad wheel bearing hub.
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: '05 Impala front wheel "squeal". [Re: Lee4212] #4782772
06/10/18 05:43 AM
06/10/18 05:43 AM
ME
eljefino Online content
eljefino  Online Content
ME
Could be the backing plate rubbing the rotor.
Re: '05 Impala front wheel "squeal". [Re: Lee4212] #4782793
06/10/18 06:28 AM
06/10/18 06:28 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
A wheel bearing could be going away which would be common on these at that mileage, it could be a strut bearing/mount or rusted and touching brake shield which is also pretty common.
CV axles usually make clicking noises when turning (outside joint) or clunking and vibration (inside joint).
Re: '05 Impala front wheel "squeal". [Re: Lee4212] #4782798
06/10/18 06:39 AM
06/10/18 06:39 AM
Idaho
sprite1741 Offline
sprite1741  Offline
Idaho
Hubs are a common issue on GM FWD. I check mine every oil change. Put the front end on jack stands and grab the wheel at the top and bottom and shake. Any play at all and the hub is bad. Easy DIY job.
2005 Grand Prix GXP 5.3L Supertech Synthetic Dexos 5w30 Fram Ultra 3506
1986 Dodge Lancer 2.2L Turbo, Supertech Synthetic 10w30 Fram Ultra 3614
Re: '05 Impala front wheel "squeal". [Re: Lee4212] #4783045
06/10/18 12:00 PM
06/10/18 12:00 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
I would put the car up on jack stands and spin the wheels by hand. If you don't find the problem then run the car while up on stands and have someone turn the wheel.
Re: '05 Impala front wheel "squeal". [Re: Lee4212] #4783439
06/10/18 08:58 PM
06/10/18 08:58 PM
chicagoland
Lee4212 Offline OP
Lee4212  Offline OP
chicagoland
THANKS for the input folks. I will see the mechanic that did the work and go from there. I'll keep ya posted.
'05 impala base that so far has been great.3.4 v/6. 62,500 miles. Runs ultra smooth.
Re: '05 Impala front wheel "squeal". [Re: Lee4212] #4785403
06/12/18 11:06 PM
06/12/18 11:06 PM
chicagoland
Lee4212 Offline OP
Lee4212  Offline OP
chicagoland
I found the noise myself with my mechanics stethoscope. it is coming from the hub bearing sooo. i guess i'll need to get both sides done. Price range ?? No abs. Base car.
Re: '05 Impala front wheel "squeal". [Re: Lee4212] #4785485
06/13/18 04:51 AM
06/13/18 04:51 AM
Trav Offline
Trav  Offline
Get quality hubs like the SKF X tracker at Rock Auto about $120 ea. the most important thing to long life with these units is proper CV axle nut torque, if some monkey uses an impact (which too many of them like to do) life will be significantly shortened.
This is a very easy job to do but the three bolts holding the hub on may have red loctite from the factory if original and will need a little heat from even a propane torch to break the glue bond. Once broken the bolts come out easily.
Do not skimp or try to save when buying these hubs, cheap ones will put you on an endless replacement cycle and cost a lot more in the long run.
https://www.rockauto.com/en/moreinfo.php?pk=1839294&cc=1431091&jsn=532
Moderated by  ekpolk
