Selling my Mustang
by SilverGt - 02/24/20 11:05 AM
Tractor Supply more Mobil 1 clearance
by jayjr1105 - 02/24/20 10:51 AM
BG PLATINUM 44K
by UG_Passat - 02/24/20 09:51 AM
F-150 trucks in the past 10 years
by lancerplayer - 02/24/20 08:38 AM
What Fluid For Snapper Rear Axle
by Propflux01 - 02/24/20 07:25 AM
Played in the sand a little.
by Chris142 - 02/24/20 07:11 AM
oil extractors manual type
by passgas55 - 02/24/20 06:14 AM
Tesla Disrupts German Economy
by Y_K - 02/24/20 01:53 AM
Difference in Valvoline Asian red offerings?
by MichaelRS - 02/24/20 01:51 AM
RV's . give me the good and bad of owning one
by WhyMe - 02/24/20 01:36 AM
Removing silicone spray overspray/residue
by Calikura - 02/23/20 09:13 PM
Oil Questions for My New Mower
by CamBurt33 - 02/23/20 08:43 PM
2007 Vibe coolant smell
by philipp10 - 02/23/20 08:36 PM
S&W 38 Special
by BlueOvalFitter - 02/23/20 07:23 PM
Oil Life Monitor question
by Mark72 - 02/23/20 07:06 PM
Any member a tax accountant ?
by mjk - 02/23/20 07:00 PM
Driven oil delivered after 6 months
by luna - 02/23/20 06:48 PM
M1 209 VS M1 209A
by BlueOvalFitter - 02/23/20 06:19 PM
Sig P516 - my take
by stockrex - 02/23/20 05:45 PM
PeterNST, SkinnRS, Bama65, wjamyers, L00btech
70793 Registered Users
120 registered members (andreigbs, 01VFR, 53' Stude, advocate, Alfred_B, 1978elcamino, 8 invisible), 2,214 guests, and 15 spiders.
Topics301,867
Posts5,204,274
Members70,793
Any thoughts on univega? #4782407 06/09/18 04:49 PM
M
maverickfhs Offline OP
M
So I have this univega classic bike laying around.
Its rusty and needs some work, like tires, brakes, chain etc...
Should I rebuild it or get rid of it? Never worked on bicycles and hence wanted to check before I go too deep into it in terms of money.
Thanks for the advice and help.
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: Any thoughts on univega? [Re: maverickfhs] #4782408 06/09/18 04:49 PM
M
M
It fits me perfectly and light weight.
Re: Any thoughts on univega? [Re: maverickfhs] #4782436 06/09/18 05:47 PM
MrQuackers Offline
Pictures
Master the 1000 yard stare
coffeeMobil 1 USA
Re: Any thoughts on univega? [Re: maverickfhs] #4782438 06/09/18 05:49 PM
W
wha232 Offline
W
They were generally better than department store bicycles. I think it sounds interesting. Don't let a little money be the deciding issue- GO FOR IT
Re: Any thoughts on univega? [Re: maverickfhs] #4782464 06/09/18 06:28 PM
M
M
Its univega chromoly.
Re: Any thoughts on univega? [Re: maverickfhs] #4782496 06/09/18 07:06 PM
M
maxdustington Offline
M
If it has a lugged frame then it is probably worth while.
99 Toyota Tercel CE 5EFE/C151
Re: Any thoughts on univega? [Re: maverickfhs] #4782527 06/09/18 07:39 PM
skyactiv Offline
It's hard to beat the ride quality of a road bike that has a chromoly frame. Until about the turn of the century, 4130 chromoly was cheaper than aluminum and now aluminum is cheaper than chromoly steel. A good chromoly frame is lighter than a cheap aluminum frame. If the bike has 700c tires it is probably worth fixing up. If the bike sat outside and rusted, I would re-grease the headset. Should probably re-grease everything anyways. Tubes, tires, brake pads, grip tape and a chain doesn't cost much. If you have a Performance Bike store near you, pay them a visit as they stock the typical stuff cheap.
https://www.performancebike.com/shop/retail/oh/columbus
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Any thoughts on univega? [Re: maverickfhs] #4782545 06/09/18 07:51 PM
M
M
Here are some pics, thanks for all feedback.
Re: Any thoughts on univega? [Re: maverickfhs] #4782551 06/09/18 08:00 PM
saginawmale50 Offline
If youre looking to ride it, keep it. If youre thinking you can fix it up and sell it, you will lose money. And if you have never worked on bicycles before you wont know how to work on the headstem and crank or even the cables and derailler gears. But that being said if you dont mind spending 200 or so on a 75 dollar bike go for it. Most of the bikes on craigslist are junk IMHO so unless you live in a college town where cheap bikes are plentiful, Id do it but just know what youre in for.
Re: Any thoughts on univega? [Re: saginawmale50] #4782559 06/09/18 08:13 PM
M
M
Definitely not planning to flip it, because I would rather get rid of it as-is. Instead of putting effort, money and energy into it.
I have never worked on a bicycle, that's why weighing my options if I should consider it or no?
I could spend up to $100-$150(top max) in parts and doing the work on my own, but otherwise would just get rid of it.
Re: Any thoughts on univega? [Re: skyactiv] #4782561 06/09/18 08:14 PM
M
M
Please have a look at the pictures of the bike, I am not well versed at the specifics of it frown
Re: Any thoughts on univega? [Re: maverickfhs] #4782595 06/09/18 09:19 PM
AZjeff Offline
OK, an old MTB. It's a TIG'd cromo frame, traditional fork/quill stem. The LX in the name might indicate decent components. Got any pics of the rear derailleur or thumb shifters? You might get it running for as little as some tubes and copious amounts of lube on the chain and in the cables. To be right it needs a complete overhaul top to bottom. No doubt you can find Youtube vids that cover everything you'd need to do, bikes aren't rocket surgery but getting those canti brakes and the shifters adjusted correctly can be frustrating. I've got a bike in similar condition that I'll make good and give away to someone to enjoy. It takes $50-$100 depending on what all they need but it's a hobby I enjoy. It's not worth much as is or running so your call.
Edit, does the sticker on the frame say double or triple butted? Tange was good tubing BITD.
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Any thoughts on univega? [Re: AZjeff] #4782797 06/10/18 06:37 AM
L
Linctex Offline
L
I am seeing "triple butted"
What does that mean?
Re: Any thoughts on univega? [Re: maverickfhs] #4782853 06/10/18 07:32 AM
R
Recalculating Offline
R
Thought I'd throw in a few photos of my 15 year ago purchase of a Univega. Purchased for $50. It has been in storage for 2 years and am looking to retrofit it to an upright handlebar system. You will find a serial number under the crank which be be referen
ce to year made.
2009 Honda CR-V EX-L 61k
2007 Buick Lacrosse 62k
2008 Ford Ranger XLT V-6 4.0 SOHC 75k
Re: Any thoughts on univega? [Re: Linctex] #4783309 06/10/18 06:20 PM
AZjeff Offline
Triple butted means the main tubes have been worked to have 3 different thicknesses, thicker at the welds then thinner toward the middle of the tube. Lighter and livelier ride. Not an entry level bike.
Nice lugged frame road bike Recalc. Are you moving the shifters to the bars too? Also, take a look at "alternative" bars with some sweep. Love em.
