195/65R Yokohama Avid Ascend GT
by Marco620. 06/19/19 01:01 AM
New frontier 4.0 V6
by passgas55. 06/19/19 12:14 AM
Top 5 reliable, affordable car makers?
by Elkins45. 06/18/19 10:16 PM
Rear positive camber
by wing0. 06/18/19 09:44 PM
Odd vehicle / tags on I-70
by Marco620. 06/18/19 09:43 PM
Repainted bumper cover vs OEM
by DTS419. 06/18/19 09:37 PM
Sweet Ice Tea
by BlueOvalFitter. 06/18/19 09:30 PM
17 F150 6R80 ATF oil change
by MagneticFX. 06/18/19 08:49 PM
Best solution for crack in vinyl seat
by paulri. 06/18/19 07:50 PM
Lower Tier Interstate batteries @ Costco?
by Onetor. 06/18/19 07:46 PM
75W90 suggestions?
by WillB. 06/18/19 07:37 PM
Big R - Mag1 Synthetic $12.99
by RamFan. 06/18/19 07:30 PM
No title after 2.5 months?
by Shaman. 06/18/19 07:18 PM
Downgrade Windows 10?
by Robster. 06/18/19 07:17 PM
AC PF2257G Any good?
by Oldtom. 06/18/19 06:48 PM
New tire time...225/55/19, all seasons...
by Ws6. 06/18/19 06:48 PM
DTS419, chakir, 9J460, Petethedog, RenewableLubeBen
68429 Registered Users
64 registered members (Bailes1992, bbhero, 2015_PSD, 53' Stude, 5 invisible), 893 guests, and 18 spiders.
Topics290,645
Posts4,990,213
Members68,429
Most Online2,967
Mar 10th, 2019
Purolators- Napa- Motorcraft- AC Delco #4781835
06/09/18 12:15 AM
06/09/18 12:15 AM
Des Moines, IA
Beatlebob32 Offline OP
Des Moines, IA
Ok- so Iíve read many old threads that Purolator is great, which was always my impression. Iíve seen some newer threads that seem to indicate this no longer the case, but I am unsure why?
I also hear Purolator makes Motorcraft, which I also perceive to be a good filter.
I had previously thought highly of AC Delco as well, but I hear now they are using e cores (plastic instead of metal) and while I donít completley understand the significance of this, or why it is detrimental, enough members seem to scorn them that I am happy to do so as well. I would like a little education though if anyone would be kind enough to share some wisdom on the topic.
I know WIX and K/N are the supposed best, but with as many cars as I have, and as rigorous as I am about on time service, I donít think the extra cost would be justified with 5k OCI.
For this same reason I usually stick with conventional or synblend oil, not because I am unaware that full synth is better- but because at 5k- it likely doesnít matter much.
I have also heard Mobil 1 is not what it used to be, something about red caps and it has lost some quality? I would like to understand what exactly that is, and if I should be concerned?
I use Synth (Mobil 1) in only 1 of my cars, chiefly because the previous owner had been faithfully using it for 14 years, and it does not leak or burn at all- so I figured Iíd stick with it. (92 Mercedes 400e)
Last question- is there any actual difference between Napa Silver and Napa Proselect filters?
Are these decent enough for 5k OCI or should I use something else?
Have been favoring Purolators and Motorcraft of late but open to recommendations.
Thanks All!
1997 Lincoln Towncar
1996 Buick Roadmaster Estate
1985 Volkswagen Vanagon
1992 Mercedes Benz 400e
1994 Chevrolet Suburban
Stopped counting at 200 cars past
1989 Deutz Allis 612h
Snapper LT2452
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4781882
06/09/18 03:55 AM
06/09/18 03:55 AM
Virginia
bbhero Online content
bbhero  Online Content
Virginia
I would suggest reading a high number of the previous threads in the oil filter section. Your answer will be found in reading them. K&N are not the best... Several Purolator filter models (aka their their regular and tier above that Pureone) have a issue with staying together .. Has had a number of the Motorcraft filters as well.. Fram Ultra is actually the best filter on the market right now.
All of that is available if time is taken to read numerous threads in the oil filter section. Look at the cut and post filters. The pictures tell the story. It would be obvious in short order.
Nissan Altima 3.5 Coupe
Carquest High mileage full synthetic 5w30
CQ blue 84356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4781883
06/09/18 03:59 AM
06/09/18 03:59 AM
Des Moines, IA
Des Moines, IA
Thank you. Most everything I can find through searching in the subject is at least 3-6 years old, and I wondered if anything has changed during that time.
Snapper LT2452
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4781909
06/09/18 05:49 AM
06/09/18 05:49 AM
In the shop
53' Stude Online content
53' Stude  Online Content
In the shop
BBHERO is right. I cut thousands of torn Puro and "made by Puro" junk filters that were torn frown
Go with WIX, Baldwin or Fram ULTRA/TOUGH GUARD
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4781988
06/09/18 08:17 AM
06/09/18 08:17 AM
Southeast Texas
gfh77665 Offline
gfh77665  Offline
Southeast Texas
The ProSelect and Silver are absolutely great for 5K intervals. Use with full confidence.
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4781998
06/09/18 08:26 AM
06/09/18 08:26 AM
High Country of Western NC
sopususer Offline
sopususer  Offline
Everyone has their opinions. For me Wix produced filters (ie NAPA Gold) are my go to brand. I certainly would not mind using a Fram XG but I cannot make myself buy the fiber end cap Frams. I don't like the idea, even though I understand it has been improved over time, of a plastic center tube, ie e-cores. For the same, or basically the same money I can go with Wix with coil springs, metal end caps, silicone ADV and metal center tube. Plus in my Subaru as well as GM truck applications they make filters that meet the OEM bypass specs. While the Silver or Proselect are a step down, I would have no hesitation in using them either. Right now I think as a whole, the product offering lineup of Wix is the best bang for the buck.
Years ago I would have said this about Purolator, but with all the torn media on c/p threads; I cannot go there now. With my current fleet I have an ecore and Fram/Honeywell fiber end cap filter installed, only because they were part of a dealer change. When I buy filters, it will be Wix. My 2 cents; YMMV.
2017 Subaru Impreza 2.0
Magnatec 0W-20/NAPA 7055
2017 GMC Sierra Denali 5.3
NAPA Syn 0W-20/NAPA Gold 100255
2017 Subaru Forester 2.5
NAPA 0W-20/NAPA Gold 7055
2018 Subaru Impreza 2.0
PP 0W-20/NAPA 7055
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4782028
06/09/18 08:59 AM
06/09/18 08:59 AM
Tri State Conservative
Zee09 Offline
Zee09  Offline
If in doubt you can always go with OEM.
"If I walked on water, they'd say I couldn't swim."
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4782064
06/09/18 09:47 AM
06/09/18 09:47 AM
5600 feet elevation, Arizona
double vanos Offline
Indeed! OEM for me, cheap at Walmart and the logos match ha ha.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4782140
06/09/18 11:08 AM
06/09/18 11:08 AM
Washington, USA
Onug Offline
Onug  Offline
Washington, USA
The search feature on the forum is lacking for sure. There are a lot of posts the past few years that show what filters are hurting in the quality department. Car51 is the most active thread starter, so maybe adding his user name will help the search results.
2016 F-150 3.5L Ecoboost
Current Oil: Castrol Magnatec 5W-30 and Fram Ultra filter
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4782175
06/09/18 11:40 AM
06/09/18 11:40 AM
Massachusetts
deven Offline
deven  Offline
Massachusetts
Go to Google then type in the keywords you want to search for then space and type site:bobistheoilguy.com You'll get all the results you want!
Proud user of ROYAL PURPLE products!
2019 BMW 330i X-drive(Factory Fill)
KEEP IT SIMPLE STUPID. IT'S ONLY OIL
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4782189
06/09/18 11:51 AM
06/09/18 11:51 AM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
Motorcraft for Ford, and so on down the line, if unsure use OE. M1 filters are what they used to be. There are manufacturing glitches on most brands except Toyota. laugh
The ecore plastic cage is twice as strong as metal, according to Champ Labs, nothing wrong with it. "They say so, it must be true or they would be sued." ( board consensus)
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4782300
06/09/18 02:59 PM
06/09/18 02:59 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Ecore center tubes are alot better now then they were when they first came out. Designers learned lessions the hard way instead of in the development lab about wide window spacing that caused media blow through.
Re: Purolators- Napa- Motorcraft- AC Delco [Re: ZeeOSix] #4782399
06/09/18 05:36 PM
06/09/18 05:36 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
What is the point of bringing that up. What is the purpose.
Re: Purolators- Napa- Motorcraft- AC Delco [Re: goodtimes] #4782401
06/09/18 05:40 PM
06/09/18 05:40 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Wow, maybe because there's talk about Ecore center tubes in this thread. Are you Ok?
Re: Purolators- Napa- Motorcraft- AC Delco [Re: ZeeOSix] #4782434
06/09/18 06:42 PM
06/09/18 06:42 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
Don't change the subject to me. Maybe it works on some, but I won't be bullied. What was the purpose to talk about the ecore wider ct spacing on filters several years ago? And there were only a few shown defective. I had them come on two used cars I bought and they were fine.
Now they are changed for a long time, yet you choose to still cast doubt on them by bringing up the past. Wondering what that purpose is. You didn't say.
