Thin silicone grease?
West Michigan
Looking for something thinner than my Motorcraft XG3A solicone compound or Jet-Lube NLGI 3 silicone grease. Definitely no thicker than NLGI 1 maybe even a 0 grade or similar. I'm looking at the Nyogel 760G but its a specialty grease and rather costly in small quantities. Any other options which may offer better economy; perhaps in a larger volume?
Superlube might be good. I have some of their multipurpose grease. I also have their silicone oil but I'd like to stick with grease. Sylglide is an option but I've only been moderately happy with it in the past.
I believe Superlube sells a silicone oil.
AGS DOT 5.1 brake fluid is essentially dow corning silicone oil with a very small level of additives.
