Redline 10W-40
Cincinnati, OH
code:
Redline 10W-40
Lab: Blackstone Laboratories
Sample Date: April 19, 2005
TBN: Not Done
Aluminum 1
Chromium 0
Iron 2
Copper 0
Lead 0
Tin 0
Molybdenum 592
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 1
Boron 13
Silicon 14
Sodium 21
Calcium 2852
Magnesium 7
Phosphorus 1355
Zinc 1360
Barium 0
Sus Viscosity @210F 75.3 (Should be 65-76)
Flashpoint (F) 420 (Should be >375)
Fuel % -
Antifreeze % -
Water % 0
Insolubles % 0
First off, nice molly
, second, that's a lot of silicon, I'll have to keep it in mind during the UOA.
I'm currently running this in my 2000 Toyota Celica GT-S in addition to 1oz LC per quart and per 1k miles. I'll have a UOA in about 4k-5k miles.
I'd run it without the LC. RL doesn't need that IMO. How long of a drain? I hope it's more then 5k miles.
quote:
No more than 5k, this oil is fairly thick, I definitely notice it on startup and until it warms up. Car normally calls for a 30W at temp and I got it for quart at Advance AutoParts when I heard they had it on clearance, wanted to experiment with a 40W just to see what the UOA would look like.
That and it's my first run of this oil type/viscosity so I don't want to run it out too long.
So you are running a thicker oil than required because it was cheap?
You notice it is too thick yet you still bought it?
I don't get it.
You could use it one quart at a time to beef up a regular dino oil. Then you would not be running anyting too thick.
[/QUOTE]So you are running a thicker oil than required because it was cheap?
I don't get it.
[/QB][/QUOTE]
My mistake, I have run 40 weights in this car even though the US manual doesn't list it, particularly when I had to make a 2000 mile trip (round trip) when it was 90+ out for days. I didn't do a UOA then and what the **** , why not try it and see what pops up.
