15w40 in my automatic trans.
by Ursatdx - 09/17/19 03:16 PM
Update on my Stihl BG 86
by 1978elcamino - 09/17/19 03:11 PM
Offset print oil
by Matt_Pill - 09/17/19 03:06 PM
Which 508.00 oil would you choose?
by Vigg - 09/17/19 02:55 PM
Any BMW LL04 recommendations?
by M3m3x5 - 09/17/19 02:18 PM
5W30 Suggestions/Subaru
by Motoretro - 09/17/19 02:18 PM
Recommend Costco tires
by henni - 09/17/19 01:58 PM
Castrol SRF Shortage
by kyoo - 09/17/19 01:26 PM
All aftermarket drums and shoes = junk?
by nthach - 09/17/19 12:38 PM
Synthetic ISO 32 Hydraulic Fluid for BL-7000SLX
by 05UFCaptain - 09/17/19 11:51 AM
TPS only seeing 3.7v at WOT
by joegreen - 09/17/19 11:39 AM
Granite Countertops Are Magnetic. Who Knew ?
by Dwight_Frye - 09/17/19 09:44 AM
2019 J.D. Power VDS
by buster - 09/17/19 09:05 AM
Possible to add catch can?
by cwilliamsws6 - 09/17/19 09:02 AM
Update on GF-6
by buster - 09/17/19 08:40 AM
motul eco-lite 5w30
by avi1777 - 09/17/19 07:47 AM
Hyundai sonata 2.4l burning oil
by Grambo - 09/17/19 07:22 AM
Mazda CX5 2.5 oil question
by Tallman - 09/17/19 06:54 AM
Can I use 10W40 gtx HM in cold winter like -5F?
by Cheburashka - 09/17/19 06:43 AM
BMW Longlife-04: Evolving Performance Requirements
by Bjornviken - 09/17/19 06:40 AM
thetransman, SamBilbrey, williamfoster060, kappa8, jayrod65
69308 Registered Users
100 registered members (4WD, 03s, 1978elcamino, 2004tdigls, 007, 72sub, 15 invisible), 2,380 guests, and 33 spiders.
Topics294,693
Posts5,064,713
Members69,308
Most Online3,532
Jul 30th, 2019
GDI Engine Wear Test Development #4781847 06/09/18 12:57 AM
J
JAG Offline OP
J
https://crcao.org/reports/recentstudies2018/AVFL-28/CRC%20AVFL-28_Final%20Report_JAN2018.pdf
The trends in the wear rates sure are complicated and don’t follow simple rules. Start-stop wear is particularly significant and is worse for the 0W-16 oil than the 5W-30 oil. Be sure to check out the graphs and the photos in the appendix.
Quote:
ABSTRACT
Existing engine lubrication wear tests based on ILSAC and ACEA specifications were developed for engines and operating conditions representative of port fuel injection (PFI) engine technology. The automotive industry is trending away from the PFI engine towards gasoline direct injection (GDI) technology with approximately 40 percent of passenger cars sold in 2014 having GDI engines, many of which are turbo-charged. These turbo-charged GDI engines often produce more severe operating conditions than PFI engines due to their higher operating temperatures, cylinder pressures, and specific torques. In addition, most turbo GDI engines are downsized, therefore operating at higher loads for a greater portion of their operating cycle. Some vehicles use alternative combustion cycles or stop-start technology which further subjects the engine and lubricants to higher levels of stress compared to conventional PFI engines.
In an effort to guide the development of engine lubrication wear tests in the next ILSAC and ACEA categories, the rings, liner and rod bearings of a modern turbo charged GDI engine, a Ford 2.0L Ecoboost engine, were irradiated and the engine assembled and placed on a test stand. The irradiation of these engine components resulted in the formation of different isotopes, depending on the component material. A series of in-field operating conditions were selected and the engine operated at these conditions using both a SAE 5W-30 oil and a SAE 0W-16 oil with the same additive package. Using the SwRI® Radioactive Tracer Technology (RATT®) the level of radioactive particles in the oil, present due to wear of the irradiated engine components, can be detected and the strength of the signal for each isotope can be correlated with the mass of wear material in the oil.
Results showed no measureable wear in the connecting rod bearings, higher wear response from transient than steady state engine operating conditions, noticeably higher wear during stop-start and roughly only two thirds of the operating conditions resulted in higher wear in the measured engine components using SAE 0W-16 oil over SAE 5W-30 oil.
Quote:
CONCLUSIONS
A project was undertaken to investigate the wear of rings, liner and connecting rod bearings in a Ford 2.0L Ecoboost engine using Radioactive Tracer Technology® to track real time wear of the components individually. The results clearly show the operating cycles that created significant wear in the irradiated engine components.
A significant amount of data was produced for the five irradiated engine components across the engine operating test matrix. The main findings are:
• After initial run-in, no measurable wear was recorded for the connecting rod bearings
SwRI Final Report, Project No. 08-22469 Page 14 of 15
Comparing the wear rates using SAE 5W-30 and SAE 0W-16 oils, lower viscosity lubricant resulted in higher wear across roughly two thirds of the engine operating conditions
• In general, transient engine operating conditions created higher wear than steady state conditions
• The stop-start cycles produced some of the most significant difference in wear rates for the two lubricants and often the highest wear rates recorded
• The cold start cycles operated at the beginning of every day of testing did not exhibit appreciable wear rates on any of the irradiated components
• It is intuitive that higher load would result in higher wear between the ring face and liner. However, the results of this work show that not to be entirely accurate, with only transient speeds at high load giving significant top ting face, top ring side and liner wear. The WOT 3500 at maximum boost only produced significant wear on the top ring side when running with SAE 0W-16 oil.
Re: GDI Engine Wear Test Development [Re: JAG] #4781863 06/09/18 02:06 AM
csandste Offline
Doesn't Ford spec 5w20? Would have been interesting to see that weight thrown into the mix for comparison.
2017 Kia Soul Plus-- VWB 5w30 65,000 miles
Re: GDI Engine Wear Test Development [Re: JAG] #4781897 06/09/18 05:13 AM
demarpaint Offline
Thanks for posting. After a quick read start/stop seems to be a real killer with the lower viscosity oil, especially with 0w-16 in the sump.
God Bless Our Troops
Re: GDI Engine Wear Test Development [Re: JAG] #4781898 06/09/18 05:15 AM
Ducked Offline
Dunno, general superiority of higher viscosity oil and higher wear from transient than steady state conditions doesn't seem all that unexpected.
Low cold start wear doesn't fit the "90% in the first 10 mins" (or whatever) recieved opinion but I don't think I've ever seen the source for that.
The test method acronym being RATT might cause some confusion though.
Re: GDI Engine Wear Test Development [Re: demarpaint] #4782017 06/09/18 08:47 AM
spasm3 Offline
I have always wondered about hot, short trips with the lighter oils. When the engine cools, of course you have thicker oil. But the weight of the crank is sitting on the bearings with a 7-8cst oil and then rotates on start up before pressure comes up. Seems worse than cold start up to me.
13 elantra 78k 5w30 synpwr
17 mazda cx-5 12300 miles m1 0w30
Re: GDI Engine Wear Test Development [Re: csandste] #4782046 06/09/18 09:15 AM
V
volk06 Offline
V
Ford specs 5w-30 in some of the ecoboost engines.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
Re: GDI Engine Wear Test Development [Re: JAG] #4782062 06/09/18 09:45 AM
double vanos Offline
Ford may spec 5w-30 for the 3.5 EB ; mine is on a steady diet of 0w-40. New start sequence for a new EB F150: twist key to start, hit stop/start deactivation button, then put it in sport mode to get all 10 gears in the mix before driving.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: GDI Engine Wear Test Development [Re: JAG] #4782104 06/09/18 10:36 AM
carviewsonic Offline
Thanks for posting. I'm not a fan of stop/start, but still surprised that they found some of the highest wear levels during stop/start events. I thought that warm starts produced no appreciable wear, and that cold starts were the major source of wear. This wear test shows the opposite. Interesting!
'18 Impala
'05 Park Avenue
'03 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: GDI Engine Wear Test Development [Re: JAG] #4782114 06/09/18 10:44 AM
dblshock Offline
well so much for the thin crowd again, my lubricated fuel should come around one of these days too.
05 Lexus GX470 167k
640:1 TCW-3
5/30 10/30 5/40 15/40
Michelin Latitude
06 4Runner SR5 150k
640:1 TCW-3
Citgo 10/30 conv XG3614
Falken Wildpeak AT3W
Re: GDI Engine Wear Test Development [Re: JAG] #4782154 06/09/18 11:15 AM
CT8 Offline
Thicker oil usually has a thicker oil film / wedge.
2015 F150 2.7
2018 F350 6.2
Re: GDI Engine Wear Test Development [Re: dblshock] #4782156 06/09/18 11:16 AM
CT8 Offline
Kerosene.
2015 F150 2.7
2018 F350 6.2
Re: GDI Engine Wear Test Development [Re: carviewsonic] #4782177 06/09/18 11:42 AM
demarpaint Offline
I'm not a fan of it either, but it is a technology that most likely will be forced upon me at some point. Hopefully if I do end up with it it can easily be disabled. After looking over that link I wonder if they'll be changing oil specs or back specing to something "thicker" at some point for engines with stop/start. hide Once again only time will tell.
Re: GDI Engine Wear Test Development [Re: spasm3] #4782193 06/09/18 11:55 AM
Dyusik Offline
While I'm sure the activated additives should negate this issue, I too get queasy about it, so I spike my 0w20 with a few quarts of 10w30.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 111K Frankenbrew, WIX 57173 (4 sale)
04 YZF-R1 20K Frankenbrew 20w50ish, XG7317
14 RX450h 41k Idemitsu 0w20, WIX 57047
18 RAM 3500 2k VWB 15w40, DBL7349
Re: GDI Engine Wear Test Development [Re: demarpaint] #4782198 06/09/18 12:03 PM
I think CAFE pressure on manufacturers will keep the thinner grades in play. Our new Impala 3.6L specs 5w30 and does not have stop/start or cylinder deactivation. Old School! Well, except for DI...
'18 Impala
'05 Park Avenue
'03 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: GDI Engine Wear Test Development [Re: carviewsonic] #4782264 06/09/18 01:49 PM
demarpaint Offline
I think so too.
