Battery Maintainer/Tender
by Char Baby - 09/22/19 05:03 AM
Czechmate
by Marco620 - 09/21/19 10:58 PM
2013 Accord M1 Annual Protection 5w/20
by Scout1 - 09/21/19 09:29 PM
New Valvoline oil line - Valvoline European Vehicle!
by BurntMusic - 09/21/19 09:13 PM
Cummins 5.9: 5W 40 vs 15W 40
by ThisBigRoadTrip - 09/21/19 09:07 PM
New Fleet and Farm opening this week
by RazorsEdge - 09/21/19 09:04 PM
Ford testing new vehicles
by 97prizm - 09/21/19 08:00 PM
Any stuffed pepper lovers here?
by 53' Stude - 09/21/19 06:55 PM
Shrinking Window Tint.
by George7941 - 09/21/19 05:30 PM
Drain and refill or Cooler line flush?
by jrvn - 09/21/19 05:25 PM
Federated Auto Parts 400 at Richmond Raceway
by bdcardinal - 09/21/19 04:40 PM
Stick with OEM or try aftermarket?
by Nav45 - 09/21/19 04:25 PM
Body Shop guys, what should I expect to pay?
by dwcopple - 09/21/19 03:59 PM
What Vehicle and Trailer to Tow Tractor?
by lancerplayer - 09/21/19 03:40 PM
Garage high humidity floor wet vehicle inside.
by littleant - 09/21/19 03:34 PM
[NEW] Carquest 95515 / Fits MB GLA/CLA
by SlavaB - 09/21/19 03:23 PM
KENDALL GT-1 HIGH PERFORMANCE SYN BLEND 5W-30
by OilReport99 - 09/21/19 03:02 PM
Weekend detail
by gregk24 - 09/21/19 02:32 PM
vinod, gary1, rainall, Junker, Boon
69357 Registered Users
23 registered members (ChrisD46, caprice_2nv, Char Baby, AlexxMQ, Astro14, 6 invisible), 562 guests, and 21 spiders.
Topics294,884
Posts5,068,735
Members69,357
Most Online3,532
Jul 30th, 2019
Purolators- Napa- Motorcraft- AC Delco #4781835 06/09/18 12:15 AM
B
Beatlebob32 Offline OP
B
Ok- so Iíve read many old threads that Purolator is great, which was always my impression. Iíve seen some newer threads that seem to indicate this no longer the case, but I am unsure why?
I also hear Purolator makes Motorcraft, which I also perceive to be a good filter.
I had previously thought highly of AC Delco as well, but I hear now they are using e cores (plastic instead of metal) and while I donít completley understand the significance of this, or why it is detrimental, enough members seem to scorn them that I am happy to do so as well. I would like a little education though if anyone would be kind enough to share some wisdom on the topic.
I know WIX and K/N are the supposed best, but with as many cars as I have, and as rigorous as I am about on time service, I donít think the extra cost would be justified with 5k OCI.
For this same reason I usually stick with conventional or synblend oil, not because I am unaware that full synth is better- but because at 5k- it likely doesnít matter much.
I have also heard Mobil 1 is not what it used to be, something about red caps and it has lost some quality? I would like to understand what exactly that is, and if I should be concerned?
I use Synth (Mobil 1) in only 1 of my cars, chiefly because the previous owner had been faithfully using it for 14 years, and it does not leak or burn at all- so I figured Iíd stick with it. (92 Mercedes 400e)
Last question- is there any actual difference between Napa Silver and Napa Proselect filters?
Are these decent enough for 5k OCI or should I use something else?
Have been favoring Purolators and Motorcraft of late but open to recommendations.
Thanks All!
1997 Lincoln Towncar
1996 Buick Roadmaster Estate
1985 Volkswagen Vanagon
1992 Mercedes Benz 400e
1994 Chevrolet Suburban
Stopped counting at 200 cars past
1989 Deutz Allis 612h
Snapper LT2452
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4781882 06/09/18 03:55 AM
B
bbhero Offline
B
I would suggest reading a high number of the previous threads in the oil filter section. Your answer will be found in reading them. K&N are not the best... Several Purolator filter models (aka their their regular and tier above that Pureone) have a issue with staying together .. Has had a number of the Motorcraft filters as well.. Fram Ultra is actually the best filter on the market right now.
All of that is available if time is taken to read numerous threads in the oil filter section. Look at the cut and post filters. The pictures tell the story. It would be obvious in short order.
Nissan Altima 3.5 Coupe
Cam2 Dexos1 Gen 2 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4781883 06/09/18 03:59 AM
B
B
Thank you. Most everything I can find through searching in the subject is at least 3-6 years old, and I wondered if anything has changed during that time.
Snapper LT2452
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4781909 06/09/18 05:49 AM
53' Stude Offline
BBHERO is right. I cut thousands of torn Puro and "made by Puro" junk filters that were torn frown
Go with WIX, Baldwin or Fram ULTRA/TOUGH GUARD
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4781988 06/09/18 08:17 AM
G
gfh77665 Offline
G
The ProSelect and Silver are absolutely great for 5K intervals. Use with full confidence.
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4781998 06/09/18 08:26 AM
sopususer Offline
Everyone has their opinions. For me Wix produced filters (ie NAPA Gold) are my go to brand. I certainly would not mind using a Fram XG but I cannot make myself buy the fiber end cap Frams. I don't like the idea, even though I understand it has been improved over time, of a plastic center tube, ie e-cores. For the same, or basically the same money I can go with Wix with coil springs, metal end caps, silicone ADV and metal center tube. Plus in my Subaru as well as GM truck applications they make filters that meet the OEM bypass specs. While the Silver or Proselect are a step down, I would have no hesitation in using them either. Right now I think as a whole, the product offering lineup of Wix is the best bang for the buck.
Years ago I would have said this about Purolator, but with all the torn media on c/p threads; I cannot go there now. With my current fleet I have an ecore and Fram/Honeywell fiber end cap filter installed, only because they were part of a dealer change. When I buy filters, it will be Wix. My 2 cents; YMMV.
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4782028 06/09/18 08:59 AM
Zee09 Offline
If in doubt you can always go with OEM.
"If I walked on water, they'd say I couldn't swim."
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4782064 06/09/18 09:47 AM
double vanos Offline
Indeed! OEM for me, cheap at Walmart and the logos match ha ha.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4782140 06/09/18 11:08 AM
O
Onug Offline
O
The search feature on the forum is lacking for sure. There are a lot of posts the past few years that show what filters are hurting in the quality department. Car51 is the most active thread starter, so maybe adding his user name will help the search results.
2016 F-150 3.5L Ecoboost
Current Oil: Castrol Magnatec 5W-30 and Fram Ultra filter
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4782175 06/09/18 11:40 AM
deven Offline
Go to Google then type in the keywords you want to search for then space and type site:bobistheoilguy.com You'll get all the results you want!
Proud user of ROYAL PURPLE products!
2019 BMW 330i X-drive(Factory Fill)
KEEP IT SIMPLE STUPID. IT'S ONLY OIL
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4782189 06/09/18 11:51 AM
G
goodtimes Offline
G
Motorcraft for Ford, and so on down the line, if unsure use OE. M1 filters are what they used to be. There are manufacturing glitches on most brands except Toyota. laugh
The ecore plastic cage is twice as strong as metal, according to Champ Labs, nothing wrong with it. "They say so, it must be true or they would be sued." ( board consensus)
Re: Purolators- Napa- Motorcraft- AC Delco [Re: Beatlebob32] #4782300 06/09/18 02:59 PM
Z
ZeeOSix Offline
Z
Ecore center tubes are alot better now then they were when they first came out. Designers learned lessions the hard way instead of in the development lab about wide window spacing that caused media blow through.
Re: Purolators- Napa- Motorcraft- AC Delco [Re: ZeeOSix] #4782399 06/09/18 05:36 PM
G
goodtimes Offline
G
What is the point of bringing that up. What is the purpose.
Re: Purolators- Napa- Motorcraft- AC Delco [Re: goodtimes] #4782401 06/09/18 05:40 PM
Z
ZeeOSix Offline
Z
Wow, maybe because there's talk about Ecore center tubes in this thread. Are you Ok?
Re: Purolators- Napa- Motorcraft- AC Delco [Re: ZeeOSix] #4782434 06/09/18 06:42 PM
G
goodtimes Offline
G
Don't change the subject to me. Maybe it works on some, but I won't be bullied. What was the purpose to talk about the ecore wider ct spacing on filters several years ago? And there were only a few shown defective. I had them come on two used cars I bought and they were fine.
Now they are changed for a long time, yet you choose to still cast doubt on them by bringing up the past. Wondering what that purpose is. You didn't say.
