Brake Caliper Dampers?
by HangFire. 01/18/19 11:32 AM
Fully Formulated Coolant and old radiator
by Wheel. 01/18/19 11:27 AM
'15 6.7 Powerstroke UOA
by roadrunner1. 01/18/19 10:18 AM
Automotive Battery Voltage -What is ur reading?
by Patrick0525. 01/18/19 10:10 AM
Amsoil 0w-40 vs 5w-40
by Buddyp. 01/18/19 10:07 AM
M1 is changing their oils, site and adding a new oil
by Flashlightboy. 01/18/19 10:01 AM
Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
108 registered members (Astro14, 53' Stude, Bjornviken, aircooled, 15 invisible), 2,225 guests, and 56 spiders.
Topics296,781
Posts4,958,787
Members66,969
Most Online2,577
Jan 14th, 2019
GDI Engine Wear Test Development #4781847
06/08/18 11:57 PM
06/08/18 11:57 PM
Fredericksburg, VA
JAG Offline OP
JAG  Offline OP
Fredericksburg, VA
https://crcao.org/reports/recentstudies2018/AVFL-28/CRC%20AVFL-28_Final%20Report_JAN2018.pdf
The trends in the wear rates sure are complicated and don’t follow simple rules. Start-stop wear is particularly significant and is worse for the 0W-16 oil than the 5W-30 oil. Be sure to check out the graphs and the photos in the appendix.
Quote:
ABSTRACT
Existing engine lubrication wear tests based on ILSAC and ACEA specifications were developed for engines and operating conditions representative of port fuel injection (PFI) engine technology. The automotive industry is trending away from the PFI engine towards gasoline direct injection (GDI) technology with approximately 40 percent of passenger cars sold in 2014 having GDI engines, many of which are turbo-charged. These turbo-charged GDI engines often produce more severe operating conditions than PFI engines due to their higher operating temperatures, cylinder pressures, and specific torques. In addition, most turbo GDI engines are downsized, therefore operating at higher loads for a greater portion of their operating cycle. Some vehicles use alternative combustion cycles or stop-start technology which further subjects the engine and lubricants to higher levels of stress compared to conventional PFI engines.
In an effort to guide the development of engine lubrication wear tests in the next ILSAC and ACEA categories, the rings, liner and rod bearings of a modern turbo charged GDI engine, a Ford 2.0L Ecoboost engine, were irradiated and the engine assembled and placed on a test stand. The irradiation of these engine components resulted in the formation of different isotopes, depending on the component material. A series of in-field operating conditions were selected and the engine operated at these conditions using both a SAE 5W-30 oil and a SAE 0W-16 oil with the same additive package. Using the SwRI® Radioactive Tracer Technology (RATT®) the level of radioactive particles in the oil, present due to wear of the irradiated engine components, can be detected and the strength of the signal for each isotope can be correlated with the mass of wear material in the oil.
Results showed no measureable wear in the connecting rod bearings, higher wear response from transient than steady state engine operating conditions, noticeably higher wear during stop-start and roughly only two thirds of the operating conditions resulted in higher wear in the measured engine components using SAE 0W-16 oil over SAE 5W-30 oil.
Quote:
CONCLUSIONS
A project was undertaken to investigate the wear of rings, liner and connecting rod bearings in a Ford 2.0L Ecoboost engine using Radioactive Tracer Technology® to track real time wear of the components individually. The results clearly show the operating cycles that created significant wear in the irradiated engine components.
A significant amount of data was produced for the five irradiated engine components across the engine operating test matrix. The main findings are:
• After initial run-in, no measurable wear was recorded for the connecting rod bearings
SwRI Final Report, Project No. 08-22469 Page 14 of 15
Comparing the wear rates using SAE 5W-30 and SAE 0W-16 oils, lower viscosity lubricant resulted in higher wear across roughly two thirds of the engine operating conditions
• In general, transient engine operating conditions created higher wear than steady state conditions
• The stop-start cycles produced some of the most significant difference in wear rates for the two lubricants and often the highest wear rates recorded
• The cold start cycles operated at the beginning of every day of testing did not exhibit appreciable wear rates on any of the irradiated components
• It is intuitive that higher load would result in higher wear between the ring face and liner. However, the results of this work show that not to be entirely accurate, with only transient speeds at high load giving significant top ting face, top ring side and liner wear. The WOT 3500 at maximum boost only produced significant wear on the top ring side when running with SAE 0W-16 oil.
Re: GDI Engine Wear Test Development [Re: JAG] #4781863
06/09/18 01:06 AM
06/09/18 01:06 AM
St. Charles County, Missouri
csandste Online content
csandste  Online Content
Doesn't Ford spec 5w20? Would have been interesting to see that weight thrown into the mix for comparison.
2017 Kia Soul Plus-- VWB 5-30, 54,000 miles.
Re: GDI Engine Wear Test Development [Re: JAG] #4781897
06/09/18 04:13 AM
06/09/18 04:13 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Thanks for posting. After a quick read start/stop seems to be a real killer with the lower viscosity oil, especially with 0w-16 in the sump.
God Bless Our Troops
Re: GDI Engine Wear Test Development [Re: JAG] #4781898
06/09/18 04:15 AM
06/09/18 04:15 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Dunno, general superiority of higher viscosity oil and higher wear from transient than steady state conditions doesn't seem all that unexpected.
Low cold start wear doesn't fit the "90% in the first 10 mins" (or whatever) recieved opinion but I don't think I've ever seen the source for that.
The test method acronym being RATT might cause some confusion though.
Re: GDI Engine Wear Test Development [Re: demarpaint] #4782017
06/09/18 07:47 AM
06/09/18 07:47 AM
out there
spasm3 Offline
spasm3  Offline
out there
I have always wondered about hot, short trips with the lighter oils. When the engine cools, of course you have thicker oil. But the weight of the crank is sitting on the bearings with a 7-8cst oil and then rotates on start up before pressure comes up. Seems worse than cold start up to me.
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: GDI Engine Wear Test Development [Re: csandste] #4782046
06/09/18 08:15 AM
06/09/18 08:15 AM
Midwest
volk06 Offline
volk06  Offline
Midwest
Ford specs 5w-30 in some of the ecoboost engines.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
Re: GDI Engine Wear Test Development [Re: JAG] #4782062
06/09/18 08:45 AM
06/09/18 08:45 AM
5600 feet elevation, Arizona
double vanos Offline
Ford may spec 5w-30 for the 3.5 EB ; mine is on a steady diet of 0w-40. New start sequence for a new EB F150: twist key to start, hit stop/start deactivation button, then put it in sport mode to get all 10 gears in the mix before driving.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: GDI Engine Wear Test Development [Re: JAG] #4782104
06/09/18 09:36 AM
06/09/18 09:36 AM
Alberta
carviewsonic Online content
carviewsonic  Online Content
Alberta
Thanks for posting. I'm not a fan of stop/start, but still surprised that they found some of the highest wear levels during stop/start events. I thought that warm starts produced no appreciable wear, and that cold starts were the major source of wear. This wear test shows the opposite. Interesting!
'18 Impala
'05 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: GDI Engine Wear Test Development [Re: JAG] #4782114
06/09/18 09:44 AM
06/09/18 09:44 AM
WI.
dblshock Offline
dblshock  Offline
WI.
well so much for the thin crowd again, my lubricated fuel should come around one of these days too.
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: GDI Engine Wear Test Development [Re: JAG] #4782154
06/09/18 10:15 AM
06/09/18 10:15 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Thicker oil usually has a thicker oil film / wedge.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: GDI Engine Wear Test Development [Re: dblshock] #4782156
06/09/18 10:16 AM
06/09/18 10:16 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Kerosene.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: GDI Engine Wear Test Development [Re: carviewsonic] #4782177
06/09/18 10:42 AM
06/09/18 10:42 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I'm not a fan of it either, but it is a technology that most likely will be forced upon me at some point. Hopefully if I do end up with it it can easily be disabled. After looking over that link I wonder if they'll be changing oil specs or back specing to something "thicker" at some point for engines with stop/start. hide Once again only time will tell.
Re: GDI Engine Wear Test Development [Re: spasm3] #4782193
06/09/18 10:55 AM
06/09/18 10:55 AM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
While I'm sure the activated additives should negate this issue, I too get queasy about it, so I spike my 0w20 with a few quarts of 10w30.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 104K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 37k Idemitsu 0w20, 57047
Re: GDI Engine Wear Test Development [Re: demarpaint] #4782198
06/09/18 11:03 AM
06/09/18 11:03 AM
Alberta
Alberta
I think CAFE pressure on manufacturers will keep the thinner grades in play. Our new Impala 3.6L specs 5w30 and does not have stop/start or cylinder deactivation. Old School! Well, except for DI...
'18 Impala
'05 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: GDI Engine Wear Test Development [Re: carviewsonic] #4782264
06/09/18 12:49 PM
06/09/18 12:49 PM
NY
demarpaint Offline
demarpaint  Offline
NY
I think so too.
