Nine PH3600-size filters FS
by SubieRubyRoo. 02/23/19 04:45 PM
2003 Accord 2.4L Valve train pics
by WagonWheel. 02/23/19 04:24 PM
Leaky FL400s
by jongies3. 02/23/19 03:55 PM
Fram Ultra with Filter Mag pics
by ZZman. 02/23/19 03:39 PM
Which 0w20 meets VW 508.00?
by 53' Stude. 02/23/19 03:28 PM
RockAuto Injectors - Return / Weird
by StevieC. 02/23/19 02:23 PM
03 Nissan Maxima stalls uphill.
by LeakySeals. 02/23/19 01:47 PM
Delvac Rebate?
by 1JZ_E46. 02/23/19 01:23 PM
Oil recommendation for Audi turbo engine
by zorba02. 02/23/19 12:41 PM
Tiger shark oil consumption
by RedOak. 02/23/19 12:14 PM
2001 Grand Cherokee Rear Diff Lube
by Plimbob. 02/23/19 12:13 PM
2005 Forester Upper Radiator Hose
by HowAboutThis. 02/23/19 12:05 PM
2016 Civic 2.0. Strange driving habits. Which oil?
by DEEPfrom1. 02/23/19 12:03 PM
Mercedes OM617 3k Chevron Delo
by gonesurfing. 02/23/19 11:38 AM
Water Pump Replacement Question
by Gebo. 02/23/19 10:55 AM
Maxx Oil ?
by lawnguy. 02/23/19 10:54 AM
Pure Vermont Amber Rich Maple Syrup
by Vern_in_IL. 02/23/19 10:11 AM
Barrett, Beez1204, vmasse, zorba02, Ecodiesel
67326 Registered Users
119 registered members (2oldtommy, 1WildPig, 77GrandPrix, 2002 Maxima SE, 18 invisible), 2,026 guests, and 55 spiders.
Topics284,721
Posts4,875,814
Members67,326
Most Online2,548
Feb 16th, 2019
'14 ATS 2.0t / dealer bulk 5w-30 / 6.5k mi #4781841
06/08/18 11:30 PM
06/08/18 11:30 PM
CA, US
SLOsolstice Offline OP
CA, US
I bought this 14 Cadillac ATS 2.0T with a manual transmission with 29k miles. I had the dealer change the oil at 29k, 35k, and 40k. I was a little concerned about the cars history so I did the UOA. The OLM was at 14%.
I figured there would be high Fuel dilution because the last 3k had a majority of short trips. When I do drive it I drive it pretty hard, 5k shifts at least weekly. I also try to run an "Italian tune up" every couple of months(4k rpm for 20minutes) to prevent carbon buildup. Regarding the silicon I changed the air filter 3k mile into the interval.
Now that free oil changes are finished I put in Castrol Edge.
Re: '14 ATS 2.0t / dealer bulk 5w-30 / 6.5k mi [Re: SLOsolstice] #4781919
06/09/18 05:08 AM
06/09/18 05:08 AM
NY
mx5miata Offline
mx5miata  Offline
NY
i never heard of these practices "Italian tune-up" I just think this is unnecessary abuse especially for a turbo they should make plenty of low end torque that they shouldn't have to be rung out. a few good highway drives getting the oil hot should be sufficient.
NAPA FULL SYNTHETIC 0w20 Partsplus oil filter
Wix air filter
Re: '14 ATS 2.0t / dealer bulk 5w-30 / 6.5k mi [Re: SLOsolstice] #4781929
06/09/18 05:20 AM
06/09/18 05:20 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
With 6570 miles on dealer bulk you got 12 ppm iron wear, that is fine if you ask me.
What bulk oil is this ? It has a nice 164 ppm Moly, and 840 ppm zinc (near max for an ILSAC oil), with a detergent package of Mg (474 ppm) and Ca (1328 ppm) - which looks like a modern package designed to reduce LSPI. This is a good oil.
A KV100 of 8.75 cSt, it's out of grade - no longer a 30, but this is probably due to fuel dilution with short trips and a turbo.
Anyway, good report.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: '14 ATS 2.0t / dealer bulk 5w-30 / 6.5k mi [Re: SLOsolstice] #4781932
06/09/18 05:28 AM
06/09/18 05:28 AM
NY
mx5miata Offline
mx5miata  Offline
NY
Chevy dealers my way use Acdelco oil which is ExxonMobil
Wix air filter
Re: '14 ATS 2.0t / dealer bulk 5w-30 / 6.5k mi [Re: mx5miata] #4781941
06/09/18 05:58 AM
06/09/18 05:58 AM
FL, USA
gregk24 Offline
gregk24  Offline
FL, USA
Sure, the turbo makes plenty of torque down low. The point of sustained high RPM driving is to heat up the engine to the point where it burns some carbon off. I do the same in the Jetta every now and then.
2012 Honda Accord EX-L K24z3
56,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
44,xxx miles
Castrol OEM dealer fill / OEM filter
Re: '14 ATS 2.0t / dealer bulk 5w-30 / 6.5k mi [Re: SLOsolstice] #4782451
06/09/18 06:09 PM
06/09/18 06:09 PM
CA, US
CA, US
Yes this is the theory in DI turbo engines.
It's just your typical Cadillac/Hyundai/Subaru/Buick dealer. It calls for Dexos so I'm assuming it at least meets those requirements.
Re: '14 ATS 2.0t / dealer bulk 5w-30 / 6.5k mi [Re: SLOsolstice] #4783683
06/11/18 08:35 AM
06/11/18 08:35 AM
Great White North.. eh
webfors Offline
webfors  Offline
Good report for a DI turbo engine. Other than the viscosity loss this is a pretty good report. Happy to see a healthy 4 year old LTG with a good UOA.
17 Cadillac ATS 2.0T, Edge D1G2 5w30, XG10575
17 Dodge GC, VWB 5w20, Fram DL11665
15 DL650, Rotella T6 5w40, KN-138
Small engines; RT5 10w30
Re: '14 ATS 2.0t / dealer bulk 5w-30 / 6.5k mi [Re: SLOsolstice] #4784491
06/12/18 01:55 AM
06/12/18 01:55 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Use Euro oils. Kinematic viscosity proves that. That engine in Europe is anyway slated for ACEA A3/B3 B4 oils, so cannot do any harm to engine.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: '14 ATS 2.0t / dealer bulk 5w-30 / 6.5k mi [Re: edyvw] #4784548
06/12/18 05:43 AM
06/12/18 05:43 AM
webfors Offline
webfors  Offline
Out of warranty, agreed. I have a long way to go to get there.
Re: '14 ATS 2.0t / dealer bulk 5w-30 / 6.5k mi [Re: webfors] #4785438
06/13/18 01:57 AM
06/13/18 01:57 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Why don't you use 5W30 ACEA A3/B3 B4? If 5W30 is recommended does it say ILSAC GF-5 or just 5W30 API SL/SM/SN?
Re: '14 ATS 2.0t / dealer bulk 5w-30 / 6.5k mi [Re: edyvw] #4785649
06/13/18 08:03 AM
06/13/18 08:03 AM
webfors Offline
webfors  Offline
Must be a Dexos 1 Gen 2 5w30 for warranty adherence.
Re: '14 ATS 2.0t / dealer bulk 5w-30 / 6.5k mi [Re: webfors] #4786035
06/13/18 03:40 PM
06/13/18 03:40 PM
New England
Virtus_Probi Offline
New England
GM included an LSPI test in dexos2 so they could specify that for gas as well as diesel engines in Europe, but that might not help in the US in the extremely unlikely event that the oil used was called into question for a warranty claim.
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Moderated by  ekpolk
