Pennzoil GF-6 & Low Viscosity Q&A
Click here to participate in the Pennzoil Q&A
Pep Boys syn oil sale. . . $15.98 after rebate
by Robster. 06/25/19 09:47 PM
Another Amazon issue....
by mjk. 06/25/19 09:10 PM
Leupold screws
by buck91. 06/25/19 08:51 PM
2004 Lexus RX330, 5659mi, Pennzoil Platinum HM 5W30
by newtoncd8. 06/25/19 07:38 PM
Milesyn 5w/20, 5500 miles, 2007 Mazda6 2.3L
by RayCJ. 06/25/19 07:12 PM
Mystik JT-6 Green tube @ Tractor Supply
by K20FA5. 06/25/19 06:58 PM
Saw a '53 Chevy this morning
by fdcg27. 06/25/19 06:20 PM
Motorcraft Mercon V opinions?
by Vigilant. 06/25/19 05:28 PM
New Personal Best MPG
by Kjmack. 06/25/19 05:01 PM
DuraMAX Synthetic Oil?
by Torino117. 06/25/19 04:54 PM
Battery Cables!
by NYEngineer. 06/25/19 04:35 PM
Brake Rotors
by WyrTwister. 06/25/19 04:00 PM
Rubber cement tubes?
by buck91. 06/25/19 03:53 PM
2019 Camaro SS 10sp auto, brief review
by Cujet. 06/25/19 03:14 PM
John Deere LX280 Help!
by johnmichael. 06/25/19 03:01 PM
Which grease?
by maverickfhs. 06/25/19 12:43 PM
Potenza SO4 Pole Position on the 968
by BeerCan. 06/25/19 12:15 PM
New wheels and tires on our VW Passat
by SLO_Town. 06/25/19 11:28 AM
Beason, Toddstephens22, Macky, javadog, giwatcher
68488 Registered Users
103 registered members (AdditiveOCD, 1nighttrain, 77GrandPrix, AC1DD, 14Accent, 10 invisible), 1,962 guests, and 28 spiders.
Topics290,969
Posts4,996,140
Members68,488
Most Online2,967
Mar 10th, 2019
Anyone using a conventional synthetic in a CR TDI? #4777491
06/04/18 05:49 PM
06/04/18 05:49 PM
KY
Terry270 Offline OP
Terry270  Offline OP
KY
I have a deleted CR TDI and have been sticking with the recommended VW 507 oils since new but I am considering switching to T6 or Schaeffer's. Is that ok since it's 5w-40 instead of 5w-30 like the VW 507 oils?
Re: Anyone using a conventional synthetic in a CR TDI? [Re: Terry270] #4777496
06/04/18 05:59 PM
06/04/18 05:59 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
Id say youd be fine, most of the reason you had to use specific oils was when the oil burned it affects the emission equipment.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Anyone using a conventional synthetic in a CR TDI? [Re: Terry270] #4779491
06/06/18 07:15 PM
06/06/18 07:15 PM
Rabbit Creek, Alaska
jayg Offline
jayg  Offline
Lots of people stopped worrying about that certification after being deleting. Any modern synthetic diesel rated oil will do fine in them once the DPF is gone.
I will say that your thread title "conventional synthetic" was a little hard to follow for a second. cool
2018 Ford Ecosport AWD- Napa 0w20
2017 Ram 1500 Ecodiesel- CP Triton ECT 5w40
1973 Datsun 240Z 10w30- VWC from '73
1973 Triumph Bonneville 750- M1 5w50
1967 BSA 441 Victor Special- M1 5w50
Re: Anyone using a conventional synthetic in a CR TDI? [Re: jayg] #4779707
06/06/18 10:48 PM
06/06/18 10:48 PM
KY
Terry270 Offline OP
Terry270  Offline OP
KY
I hear people say that, but no one has posted an analysis yet.
Lol. It's been so long since I've used a non synthetic oil in anything I forgot about them being referred to as "conventional".
Re: Anyone using a conventional synthetic in a CR TDI? [Re: Terry270] #4779959
06/07/18 09:09 AM
06/07/18 09:09 AM
jayg Offline
jayg  Offline
I wouldn’t worry about seeing an analysis. People have been doing it for almost 10 years since the CR 2.0 came out over in TDIclub. I did it for a few years on my deleted 2012 Jetta with m1 tdt with no issues.
Without the dpf to worry about, there’s nothing to worry yourself over as far as lubrication. HPFP grenading , intercooler icing (for the air to air equipped cars) , egr issues....those on the other hand are still what if worry about.
Re: Anyone using a conventional synthetic in a CR TDI? [Re: Terry270] #4780795
06/07/18 11:44 PM
06/07/18 11:44 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
would move to Castrol 0W40. Forget T6.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: Anyone using a conventional synthetic in a CR TDI? [Re: edyvw] #4781501
06/08/18 05:14 PM
06/08/18 05:14 PM
KY
Terry270 Offline OP
Terry270  Offline OP
KY
The car has 240k on it now so I probably will get an analysis done.
As far as the other issues I have the 2micron kit so if the hpfp dies then I only have to replace the pump and filter. Egr is gone which also does away with intercooler icing issue. It should be pretty solid.
Have any data to back that up?
Re: Anyone using a conventional synthetic in a CR TDI? [Re: jayg] #4781740
06/08/18 09:21 PM
06/08/18 09:21 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
And happy birthday!
Plain, simple Garak.
Re: Anyone using a conventional synthetic in a CR TDI? [Re: Terry270] #4781885
06/09/18 04:12 AM
06/09/18 04:12 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Back up what? It has much lower NOACK (9.1% compare to 12.6%), it has robust HTHS, it has much lower cst. Simply it is much better oil for personal vehicle with engine of that size.
Research on the BITOG, numerous topics on Castrol 0W40, T6 or whatever.
