Bent Jack Stand Ratchet Bar
by The Critic - 05/28/20 01:44 AM
Can a 2005 Volvo go 300K Miles easily?
by VolvoZ - 05/27/20 11:17 PM
Cam specs for '62 Corvette Fulie
by JeffKeryk - 05/27/20 11:06 PM
Grub hub
by Chris142 - 05/27/20 10:52 PM
Fiat 500e In the Stable
by Scout1 - 05/27/20 10:41 PM
Windows 10 2004 (May 2020 Update) is out
by KeithS_NW_Ohio - 05/27/20 08:56 PM
Harley Davidson Lithium LiFe 6Ah Battery 66000174
by DuckRyder - 05/27/20 07:29 PM
Belron Toolbox with collapsible cart. One neat setup
by 10WSmuckers - 05/27/20 07:16 PM
[Cut Open] Mobil 1 M1-209 (5267 miles)
by DuckRyder - 05/27/20 07:15 PM
[Cut Open] FRAM TG8A (30 minutes)
by DuckRyder - 05/27/20 07:06 PM
[Cut Open] Motorcraft FL500S - 5341 miles
by DuckRyder - 05/27/20 06:59 PM
Battery powered 1/2 inch impact wrench
by RazorsEdge - 05/27/20 06:50 PM
Subaru Dealer Filter 7KMI
by Jason_Michaels - 05/27/20 05:52 PM
Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
BlackMagicVarian, Mustache, mountaingoat, Alegrianyc, unavailable
71545 Registered Users
16 registered members (E365, GumbyJarvis, blufeb95, KenshinHimura, GemStater, ArrestMeRedZ, 4 invisible), 1,029 guests, and 61 spiders.
Topics305,958
Posts5,283,648
Members71,545
Driveway help needed #4781551 06/08/18 06:16 PM
F
FirstNissan Offline OP
F
Hi guys, I just bought my first house last week! Huge accomplishment for our family. I have an issue with the driveway wanted to see if anyone had a reasonable solution. The end of my driveway has a 2 to 3 inch dip and then joins the road. Both of my vans bottom out Unless we are crawling along at one mph. I have been wondering about making a little ramp out of concrete. I have an HOA So it has to be reasonably inconspicuous. Any suggestions? Thank you
2017 Toyota Sienna
2019 Toyota Camry
Re: Driveway help needed [Re: FirstNissan] #4781552 06/08/18 06:17 PM
M
mrsilv04 Offline
M
Some pictures would go a long way.... wink
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Driveway help needed [Re: FirstNissan] #4781559 06/08/18 06:22 PM
69GTX Offline
Whether asphalt or concrete driveway, adding more material to level it out seems easy enough. Just have to ensure ideal conditions for a bond.
Or just keep heading out at 1 mph.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Driveway help needed [Re: FirstNissan] #4781561 06/08/18 06:23 PM
M
maxdustington Offline
M
1. 2X4: pretty ghetto and out of the question.
2. Try to modify the curb to ease the transition
3. Asphalt ramp
Probably 2 and 3 together will get you where you want to go. The proliferation of SUVs and trucks has made people who pave parking lots, pour curbs and construct speed bumps not give AF anymore.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: Driveway help needed [Re: FirstNissan] #4781582 06/08/18 06:35 PM
R
raytseng Offline
R
you want to be aware that that is usually a gutter. if you fill it in consider how water will flow or pool up.
at a minimum you need to put a pipe or other culvert in to let water flow.
there are commercial solutions. google curb ramps. bridjit curb ramps come up a lot, but lots of products avail.
I've also just seen sections of heavy steel plate or diamondplate cut to proper dimensions to bridge the gutter.
https://www.google.com/search?q=curb+driveway+ramp
I wouldn't pour concrete or do anything that is not possible to easily reverse without getting a goahead in the HOA.
Re: Driveway help needed [Re: FirstNissan] #4781583 06/08/18 06:37 PM
M
MParr Offline
M
FirstNissan
Contact your city or county public works and talk with them first. City and County code trumps HOA busy bodies. They will likely send someone out to talk with you as well as look at your problem. They may have a solution.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2020 F-150 STX Super Cab 2WD 2.7 Ecoboost. FF & OE filter
Re: Driveway help needed [Re: FirstNissan] #4781600 06/08/18 06:50 PM
AZjeff Offline
The suspension bottoms out or the undercarriage hits pavement? Our new place has the drive-over curbs, yeah you have to slow way down or it's a jolt.
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Driveway help needed [Re: MParr] #4781691 06/08/18 08:29 PM
W
WiskyBadger Offline
W
Originally Posted By: MParr
FirstNissan
This, I’m going through the same thing right now. Sold our house, bought a different one and my wife can’t make it up with the Verano. Talked to the city and getting bids. Have to repour the apron and some sidewalk to get enough pitch. A lot of people in town have concrete that was poured past the gutter to the street that made a better angle, then they left a gap for water to run through. They then placed a 2x8, 2x10 etc over the gap. I couldn’t get away with it, City wouldn’t let me, not that I wanted to. But that may be a cheaper option for you if you can do it.
11 Silverado 76k Rotella Gas Truck and Champion filter
11 Traverse 123k Rotella Gas Truck and Delco filter
78 Chevy C10 Stepside VR1 10w30/20w50 mix Wix filter
Re: Driveway help needed [Re: FirstNissan] #4781720 06/08/18 08:55 PM
dishdude Offline
Do you need something like this?
http://www.bridjit.com/
https://curbramp.us/
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: Driveway help needed [Re: FirstNissan] #4781723 06/08/18 09:01 PM
4WD Offline
You require matching vehicles ? Get a couple 4 Runners … they will not hit …
