Cut the cord, finally
by 14Accent. 05/21/19 10:29 PM
Av Gas 100LL in small engines and other things
by earthmover1980. 05/21/19 10:11 PM
Yamaha R1 on the Autobahn
by AZjeff. 05/21/19 09:11 PM
Sea Foam question
by vavavroom. 05/21/19 08:40 PM
Study on detergent additives and abrasiveness
by addyguy. 05/21/19 08:33 PM
ST9688 oil filter on motorcycle?
by AuthorEditor. 05/21/19 05:56 PM
Circle K frustrations
by Mark72. 05/21/19 05:44 PM
Milesyn SXR, 0w20, 5,100mi, 2018 Mazda3 2.5L
by RayCJ. 05/21/19 05:42 PM
What filter are the 2AZ-FE owners using?
by 53' Stude. 05/21/19 05:28 PM
NEW TOUGH GUARD 4386 CUT OPEN
by 53' Stude. 05/21/19 05:26 PM
300v 5w40 vs Redline racing 15w40
by junkyard_sal. 05/21/19 05:25 PM
Honda 1.5T Edge 0W40 8,800mi.
by dblshock. 05/21/19 05:17 PM
Cub Cadet LTX1050VT keeps shredding mower belts
by oilpsi2high. 05/21/19 04:27 PM
What’s the best price for a set
by ShutdownCorner. 05/21/19 04:01 PM
So who uses Exxon-Mobil EHC basestocks?
by csandste. 05/21/19 03:40 PM
Thoughts on this article?
by RyanY. 05/21/19 03:27 PM
BG products any good?
by Chris B.. 05/21/19 03:22 PM
Would you rather have three cars or two?
by brages. 05/21/19 02:01 PM
Car shows had a good run.....
by rekit. 05/21/19 01:45 PM
Fordpuppy, Geowebby, slugworks, tlogic, Danr42
68172 Registered Users
99 registered members (14Accent, 01rangerxl, 2015_PSD, AC1DD, 4WD, 2010Civic, 12 invisible), 1,679 guests, and 23 spiders.
Topics289,214
Posts4,964,716
Members68,172
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
One Synthetic Oil for all OPE #4781718
06/08/18 08:52 PM
06/08/18 08:52 PM
Pennsylvania
Astro_Guy Offline OP
Pennsylvania
I've been struggling with this question for several years now, having no fewer than four different oils in use with my OPE. My local conditions here in SE Pennsylvania might range from 0 degrees in winter to 100 degrees in summer. Only one machine in the fleet, that being the generator, would ever be called upon to operate across that entire range. I've decided to leave the snow blower out of this, as that is a really special purpose application very different from the others. Other than the generator, that limits the operating conditions to about 25 F to 90 F. Above 90 F I will happily wait for cooler weather.
Given my circumstances, I could just go with a synthetic 5w30 but favor something in an Xw40. There is both 5w40 and 15w40 in the fleet now. Aside from the lawn tractor, it is all pull start. The only machine running 15w40 is the leaf vacuum, mainly because it uses a lot of oil. It started a lot easier in the cooler late fall temperatures with 5w40 than the current 15w40 fill. I am never going back to the straight SAE 30 it calls for as it is very difficult to pull start it in cool fall temperatures when it is needed most.
So with that as the background, here are some of the contenders and my thoughts were needed:
1. Mobil 1 0w40. 3.6 HTHS; 12.9 KV100. This one is on the list because I have about 6 quarts on hand.
2. Mobil 1 5w40 Turbo Diesel Truck. 3.8 HTHS; 14.5 KV100. Seems to be be a happy place on that specification.
3. Rotella T6 5w40. Unknown HTHS; but 14.2 KV100 slightly less than M1 TDT. HTHS might be similar.
4. Delo 4000 XSP 5w40. 4.2 HTHS and 15.4 KV100. This one worries me for the Honds GCV160 powered equipment, particularly the push mower that is used for trimming what the lawn tractor cannot reach. That machine sees 5-10 minutes of run time per week, some of that in short start stop cycles.
Okay, so there you have it. Your thoughts: stick with a 5w30 or chose one of these or another 5w40?
Re: One Synthetic Oil for all OPE [Re: Astro_Guy] #4781719
06/08/18 08:52 PM
06/08/18 08:52 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Amsoil ACD 10w-30/30W or Delo 15w-30 if only one.
Re: One Synthetic Oil for all OPE [Re: Astro_Guy] #4781725
06/08/18 09:05 PM
06/08/18 09:05 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
RT6 5W40 for me, but I use it in my tractor and atv which require a 40 weight of some sort. I don't have a snow blower but if I did it would get 5W40 too.
07 Focus ZXW, 5spd manual, 230km M1 5W30
18 Outback 2.5 CVT 22km 0W20
Re: One Synthetic Oil for all OPE [Re: Astro_Guy] #4781731
06/08/18 09:12 PM
06/08/18 09:12 PM
wi
dave123 Offline
dave123  Offline
wi
Amsoil AFF or ASE
Re: One Synthetic Oil for all OPE [Re: Astro_Guy] #4781737
06/08/18 09:19 PM
06/08/18 09:19 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Rotella T5 10w30
If you want the job done right......do it yourself.
Re: One Synthetic Oil for all OPE [Re: Astro_Guy] #4781772
06/08/18 10:05 PM
06/08/18 10:05 PM
York, Pa
fozzdesy2001 Offline
York, Pa
Mobil 1 0-40 is what use in all my OPE. Easy winter starts and takes on the summer heat. My generator has run for days with this fill winter or summer and my snowblower is easier to pull start when its really cold, old or new engines all seem to do excellent with Mobil 1 0-40.
2001 Subaru Forester S
Replaced with a 2006 Forester
2004 Subaru Forester XT
Death by deer. Replaced with 2003 Impreza Outback Sport (beater)
Re: One Synthetic Oil for all OPE [Re: Astro_Guy] #4781795
06/08/18 10:43 PM
06/08/18 10:43 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
For 25 or so years I have used M1 10-30 in all my OPE.
2007 Ford Fusion 242,000 miles
M1 0-20 EP
2017 Ford Fusion 70K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: One Synthetic Oil for all OPE [Re: Astro_Guy] #4781800
06/08/18 10:55 PM
06/08/18 10:55 PM
out there
spasm3 Offline
spasm3  Offline
out there
I've moved from amsoil syn oils to delo 400 15w 40 non sythetic.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: One Synthetic Oil for all OPE [Re: Astro_Guy] #4781817
06/08/18 11:29 PM
06/08/18 11:29 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Mobile 1 High mileage 10w30
2012 Chevy Cruze LT 1.4T - 62k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 147k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: One Synthetic Oil for all OPE [Re: Astro_Guy] #4781868
06/09/18 02:26 AM
06/09/18 02:26 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
My list would be 4...2...3...
The higher the HTHS&KV100 the better it
Will protect air cooled OPE...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: One Synthetic Oil for all OPE [Re: Astro_Guy] #4781950
06/09/18 07:11 AM
06/09/18 07:11 AM
PA
umungus1122 Offline
umungus1122  Offline
PA
Mobil 1 HM 10w-30 or 10w-40
'95 Chevy 1/2t 305 208k -NexGen Maxlife 5w-30, Wix filter
'89 Jeep Comanche 4.0 5spd 285k - GC 0w-30, Bosch LongLife filter
Re: One Synthetic Oil for all OPE [Re: Astro_Guy] #4782055
06/09/18 09:33 AM
06/09/18 09:33 AM
key largo,fl
henni Offline
henni  Offline
key largo,fl
Shell ROTELLA T6 5W-40 Full Synthetic Diesel Engine Oil, 1 Gallon (550045347)
Price: $22.47 Free Shipping for Prime Members
Post-purchase rebate: $7.00 Rebate forms
Price after rebate: $15.47
https://www.amazon.com/dp/B01LH7L0KS/
Re: One Synthetic Oil for all OPE [Re: Astro_Guy] #4782071
06/09/18 09:54 AM
06/09/18 09:54 AM
Snagglefoot Offline
Snagglefoot  Offline
I didnít read your question properly the first time. Stick with 10w30. Looking at Pittsburgh Weatherspark you basically hit 90 degrees a few days a year. However, for the high viscosity fans out there, go ahead and use a xw40. Wonít make a difference. Fifteen years later the equipment will be in equally good shape if you change the oil once per year. Still, fun discussing it.
Re: One Synthetic Oil for all OPE [Re: Snagglefoot] #4782478
06/09/18 07:48 PM
06/09/18 07:48 PM
Pennsylvania
Pennsylvania
Thanks for the input everyone. My current stash OPE compatible stash looks like this:
1. 4 qts. 5w30 Mobil 1 high mileage.
2. 6 qts. 0w40 Mobil 1 FS. Enough to change the Volvo one more time.
3. 1 qt. 15w40 Rotella T5, used exclusively in the leaf vaccum that goes thru a lot of oil.
4. 2 qts. of drip oil, consisting of Mobil 1 5w20, 5w30, and 0w40. This will go in the Honda push mower with GCV160.
At present there is 5w40 Rotella T6 in the generator (Champion 3500 watt continuous / 4000 watt starting) and the trusty Troy-Bilt rototiller with 5 HP B&S flathead. The John Deere D140 has 10w30 Mobil 1 EP. Everything else has 5w30 Mobil 1 high mileage. I can see where 10w30 Mobil 1 high mileage with its 3.5 HTHS might do the job across the board. On the other hand, I sure wish I knew the HTHS value for 5w40 Rotella T6. And on yet another hand, the 3.8 HTHS of 5w40 Mobil 1 Turbo Diesel Truck does look appealing. The lack of enthusiasm towards the Delo 4000 XSP does have me sort of cooling towards that option.
'01 Volvo V70XC, 238k, 10W-30 M1 High Mileage
'16 Accord, 32k, 0W-20 M1 EP
Re: One Synthetic Oil for all OPE [Re: Astro_Guy] #4782521
06/09/18 08:34 PM
06/09/18 08:34 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Iím currently running the M1 HM 10w-30 in all the OPE I maintain. I havenít decided if Iíll change grades next year or not. Itís a stout oil that meets ACEA A3/B3. The HTHS of 3.5 is right where a regular SAE 30 monograde would be, and has the cold starting benefits. 12.1 KV100
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Page 1 of 4 1 2 3 4
