The Fatal Flaw...
by Mad_Hatter - 08/21/19 10:58 PM
early OCI because of HIGH REVVING
by tahoe_hybrid - 08/21/19 10:38 PM
API diesel / gas ratings
by KiwiBiker - 08/21/19 10:18 PM
For the XOM fans!
by Marco620 - 08/21/19 09:43 PM
I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
talk to me about security cameras
by 1978elcamino - 08/21/19 03:30 PM
modem in 1 room want phone in another room
by raaizin - 08/21/19 02:17 PM
Robto, Chaparro_trucker, KiwiBiker, Rixter, yote556
69025 Registered Users
62 registered members (BlakeB, burla, ArrestMeRedZ, bdcardinal, BlueOvalFitter, 10 invisible), 1,431 guests, and 26 spiders.
Topics293,634
Posts5,043,777
Members69,025
Most Online3,532
Jul 30th, 2019
Driveway help needed #4781551 06/08/18 06:16 PM
F
FirstNissan Offline OP
F
Hi guys, I just bought my first house last week! Huge accomplishment for our family. I have an issue with the driveway wanted to see if anyone had a reasonable solution. The end of my driveway has a 2 to 3 inch dip and then joins the road. Both of my vans bottom out Unless we are crawling along at one mph. I have been wondering about making a little ramp out of concrete. I have an HOA So it has to be reasonably inconspicuous. Any suggestions? Thank you
2017 Toyota Sienna
2019 Honda Civic
Re: Driveway help needed [Re: FirstNissan] #4781552 06/08/18 06:17 PM
M
mrsilv04 Offline
M
Some pictures would go a long way.... wink
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Driveway help needed [Re: FirstNissan] #4781559 06/08/18 06:22 PM
69GTX Offline
Whether asphalt or concrete driveway, adding more material to level it out seems easy enough. Just have to ensure ideal conditions for a bond.
Or just keep heading out at 1 mph.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Driveway help needed [Re: FirstNissan] #4781561 06/08/18 06:23 PM
M
maxdustington Offline
M
1. 2X4: pretty ghetto and out of the question.
2. Try to modify the curb to ease the transition
3. Asphalt ramp
Probably 2 and 3 together will get you where you want to go. The proliferation of SUVs and trucks has made people who pave parking lots, pour curbs and construct speed bumps not give AF anymore.
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: Driveway help needed [Re: FirstNissan] #4781582 06/08/18 06:35 PM
R
raytseng Offline
R
you want to be aware that that is usually a gutter. if you fill it in consider how water will flow or pool up.
at a minimum you need to put a pipe or other culvert in to let water flow.
there are commercial solutions. google curb ramps. bridjit curb ramps come up a lot, but lots of products avail.
I've also just seen sections of heavy steel plate or diamondplate cut to proper dimensions to bridge the gutter.
https://www.google.com/search?q=curb+driveway+ramp
I wouldn't pour concrete or do anything that is not possible to easily reverse without getting a goahead in the HOA.
Re: Driveway help needed [Re: FirstNissan] #4781583 06/08/18 06:37 PM
M
MParr Offline
M
FirstNissan
Contact your city or county public works and talk with them first. City and County code trumps HOA busy bodies. They will likely send someone out to talk with you as well as look at your problem. They may have a solution.
2019 VW Tiguan SE Now: Factory fill & OEM filter
2017 Ford Escape SE 2.0T Now: Motorcraft 5W30 SynBlend & NAPA Gold 1348
Re: Driveway help needed [Re: FirstNissan] #4781600 06/08/18 06:50 PM
AZjeff Offline
The suspension bottoms out or the undercarriage hits pavement? Our new place has the drive-over curbs, yeah you have to slow way down or it's a jolt.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Driveway help needed [Re: MParr] #4781691 06/08/18 08:29 PM
W
WiskyBadger Offline
W
Originally Posted By: MParr
FirstNissan
This, I’m going through the same thing right now. Sold our house, bought a different one and my wife can’t make it up with the Verano. Talked to the city and getting bids. Have to repour the apron and some sidewalk to get enough pitch. A lot of people in town have concrete that was poured past the gutter to the street that made a better angle, then they left a gap for water to run through. They then placed a 2x8, 2x10 etc over the gap. I couldn’t get away with it, City wouldn’t let me, not that I wanted to. But that may be a cheaper option for you if you can do it.
11 Silverado 67k OReilly FS and Champion filter
11 Traverse 120k Frankenblend Ultra Power filter
78 Chevy C10 Stepside VR1 10w30/20w50 mix Wix filter
Re: Driveway help needed [Re: FirstNissan] #4781720 06/08/18 08:55 PM
dishdude Online Content
Online Content
Do you need something like this?
http://www.bridjit.com/
https://curbramp.us/
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan
Re: Driveway help needed [Re: FirstNissan] #4781723 06/08/18 09:01 PM
4WD Offline
You require matching vehicles ? Get a couple 4 Runners … they will not hit …
