2002 chevy tahoe 5.3 oil selection
by Zahndkile - 09/19/19 12:20 AM
Considering Solar
by mbacfp - 09/18/19 11:16 PM
2008 Duramax
by Firemedic15 - 09/18/19 11:02 PM
Fleetguard LF777 performance
by Pyrotechnic - 09/18/19 10:54 PM
Any Vacuum experts? :)
by maverickfhs - 09/18/19 09:50 PM
15 F150 Gear & Transfer Case Question
by BISCUT - 09/18/19 09:24 PM
Anyone buy/run used tires?
by addyguy - 09/18/19 08:15 PM
2019 Mazda CX-5 Diesel
by miden851 - 09/18/19 07:58 PM
Toyota 90915-YZZD1 Cut Open (Sludge?)
by ThirdeYe - 09/18/19 07:45 PM
Fram Core COR3614ACC Cut Open
by ThirdeYe - 09/18/19 07:35 PM
Never the cheap part that goes bad...
by Elkins45 - 09/18/19 07:34 PM
Denso First Time Fit 150-1009 Cut Open (2 filters)
by ThirdeYe - 09/18/19 07:31 PM
2008 CRV A/C compressor replacement
by nwjones18 - 09/18/19 07:27 PM
Fram Ultra XG4967 Cut Open
by ThirdeYe - 09/18/19 07:25 PM
Ford Motorcraft FL-820S Cut Open
by ThirdeYe - 09/18/19 07:12 PM
AC Delco PF47E cut open
by ThirdeYe - 09/18/19 07:07 PM
AC Delco PF46 (Classic) Cut Open
by ThirdeYe - 09/18/19 07:01 PM
Carbon chains
by sloinker - 09/18/19 06:51 PM
Blain;s again .99 Citgo A/R
by dblshock - 09/18/19 06:46 PM
Is griots glass sealant rebranded rain x?
by WhyMe - 09/18/19 05:48 PM
bbrown, Firemedic15, jazzthepro, F_150_18, safebraking
69323 Registered Users
30 registered members (Cubey, Ctopher, dishdude, carlprop, ChristianReske, anndel, 3 invisible), 833 guests, and 23 spiders.
Topics294,761
Posts5,065,996
Members69,323
Most Online3,532
Jul 30th, 2019
Predator generators #4781192 06/08/18 11:18 AM
Dave Sherman Offline OP
Giving some thought to getting rid of my inverter generator and getting a Predator 4000 watt generator instead. The Powerhouse I have is 2000 watts and it's always been a pain to get it started. Figured a 4000 would be a little more practical and reviews seem generally favorable. Anything I should watch out for? Mostly Field Day use for ham radio, backup power if there's an extended power outage.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: Predator generators [Re: Dave Sherman] #4781206 06/08/18 11:27 AM
skyactiv Offline
Does it have a fuel line valve? Shutting the fuel line off and letting it run until it stops helps prevent the carb from gumming up.
Me: 13' VW GTI 3 door 6 speed manual
2018 Elantra Sport 6 speed manual
Re: Predator generators [Re: Dave Sherman] #4781217 06/08/18 11:38 AM
A
andyd Offline
A
No exp with genset. BUT the Predator I re-powered my Sno- Thro with is very easy to start. I'm tempted to buy another and keep it for a
Quote:
tune up
. Replacing the engine was waay easier than fixing a 40 yr old Tecumseh grin2
Thick oil is better grin2
Re: Predator generators [Re: Dave Sherman] #4781235 06/08/18 11:58 AM
M
mk378 Online Content
Online Content
M
The non-inverter generator will have much more noise and fuel consumption.
Proper put-away by draining the fuel system is essential for trouble free starting after months of storage. Whether you have a cut off valve or not, you should empty the gas tank then run until it runs out.
Re: Predator generators [Re: Dave Sherman] #4781254 06/08/18 12:22 PM
K
Kamele0N Offline
K
It applies to all marks/brands wink
Re: Predator generators [Re: Dave Sherman] #4781266 06/08/18 12:42 PM
K
Kamele0N Offline
K
Some more knowledge wink
Actually it is not such a biggie....unless you have 2 left hands laugh
Re: Predator generators [Re: Dave Sherman] #4781272 06/08/18 12:45 PM
R
racin4ds Offline
R
I have the Coleman 4000 which is the same thing as the Predator. Great little genny! I turn the fuel valve off every time its used and allow it to run out before storing, I also keep stabil in the fuel tank. Starts first time, every time I've ever needed it and runs like a top!
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: Predator generators [Re: Dave Sherman] #4781291 06/08/18 01:14 PM
28oz Offline
I have the big quiet Predator generator for my camp trailer. Handles the A/C with ease, runs quiet, and starts extremely easily. My son (9 last summer) was starting it with the pull cord pretty easily.
1990 Nissan 300zx VG30DE - PP Euro 0W-40
2004 Nissan Quest VQ35DE - PP Euro 0W-40
2003 Ford Excursion 7.3 PSD - Rotella T6 5W-40
2005 Ford Taurus 3.0 Vulcan - Havoline HM 5W-20
Re: Predator generators [Re: Dave Sherman] #4781354 06/08/18 02:20 PM
Donald Offline
If you have propane or natural gas, go that route. Gasoline is a PIA. You can do all the things needed so it will start right back up. But storing the many gallons of gas that is going to be needed for running during an extended outage. That is a PIA by itself.
2015 Ford F250 w/Powerstroke
Re: Predator generators [Re: Dave Sherman] #4781370 06/08/18 02:38 PM
Spartanfool Offline
I have the Predator 4000 and I like it a lot. Good price, fairly quiet, starts easy. It has the fuel shut off, so you kill the fuel to run the carb dry.
Things to keep in mind: Get rid of the China made spark plug early (or buy a spare NGK and tape it to the unit), store it with Stabil in the fuel, and realize it is 4000 peak watts, 3200 running watts. If that's not enough juice, step up to the next size.
Re: Predator generators [Re: Donald] #4781410 06/08/18 03:29 PM
I
itguy08 Offline
I
I'm not sure I'd want to run a genny off propane - if you're using 20/30/50/100lb bottles the storage is the same issue as gas although it doesn't go bad but tanks rust. And if you've got a tank for heating/cooking you'll be competing for that propane unless you upgrade. And then there's the de-rating on Propane.
Natural gas would be the best but sizing and plumbing will have to be taken into account. It also de-rates same as propane.
Gas isn't that bad if you have a detached shed to store 10-15 gallons. I store the generator full (5 Gallons), 2 5 gallon cans, a 2.5 gallon can. I do mean to add another 5-10 gallons though. I use StaBil and MMO and rotate through using them for lawn care and once a year I dump the gas into the truck and fill it all up. If there's a disaster I can go for a while on that and within 1 hour can be in quite a few major areas to get more gas.
I've got the old 5500 watt Chicago Electric Blue generator. It works great, starts pretty easily (electric) and runs great. I'd not hesitate to buy another. I'm seriously thinking of the 3500w inverter for the camper.
Re: Predator generators [Re: Dave Sherman] #4781440 06/08/18 04:07 PM
H
HeritageHighRoof Offline
H
Unless you have a true diaphragm style carburetor, turning off the fuel valve will not allow you to run the carburetor dry. The engine will stop running, but residual fuel will remain and It is still necessary to manually drain the float bowl.
Re: Predator generators [Re: HeritageHighRoof] #4781479 06/08/18 04:50 PM
Spartanfool Offline
Yes, this is true. The Predator has a manual drain bolt on the carb bowl. Not as convenient as the spring loaded ones on B&S engines, but it does the job.
Re: Predator generators [Re: Dave Sherman] #4781513 06/08/18 05:22 PM
E
eljefino Offline
E
I have a duel-fuel generator. Trade my tired old propane tanks that people just give me for Blue Rhino then refill the Rhinos at BJs. They're stored in a woodshed so if they rust out and leak, they don't leak in my residence. This would take many years vs many months for gasoline.
Re: Predator generators [Re: Dave Sherman] #4781520 06/08/18 05:32 PM
K
Kamele0N Offline
K
The Powerhouse I have is 2000 watts and it's always been a pain to get it started. Anything I should watch out for?
Could be even that you just need to adjust valve lash...
