[Cut Open] Motorcraft FL500S - 5003 miles
by DuckRyder. 02/23/19 05:08 PM
Does Kia & Hundai use same motors?
by tc1446. 02/23/19 05:07 PM
Extreme fuel dilution
by BigShug681. 02/23/19 04:52 PM
Nine PH3600-size filters FS
by SubieRubyRoo. 02/23/19 04:45 PM
2003 Accord 2.4L Valve train pics
by WagonWheel. 02/23/19 04:24 PM
Leaky FL400s
by jongies3. 02/23/19 03:55 PM
Fram Ultra with Filter Mag pics
by ZZman. 02/23/19 03:39 PM
Which 0w20 meets VW 508.00?
by 53' Stude. 02/23/19 03:28 PM
RockAuto Injectors - Return / Weird
by StevieC. 02/23/19 02:23 PM
03 Nissan Maxima stalls uphill.
by LeakySeals. 02/23/19 01:47 PM
Delvac Rebate?
by 1JZ_E46. 02/23/19 01:23 PM
Oil recommendation for Audi turbo engine
by zorba02. 02/23/19 12:41 PM
Jeep Cherokee 2.4L oil consumption
by RedOak. 02/23/19 12:14 PM
2001 Grand Cherokee Rear Diff Lube
by Plimbob. 02/23/19 12:13 PM
2005 Forester Upper Radiator Hose
by HowAboutThis. 02/23/19 12:05 PM
2016 Civic 2.0. Strange driving habits. Which oil?
by DEEPfrom1. 02/23/19 12:03 PM
Mercedes OM617 3k Chevron Delo
by gonesurfing. 02/23/19 11:38 AM
snapy907, Barrett, Beez1204, vmasse, zorba02
67327 Registered Users
112 registered members (01rangerxl, 10WSmuckers, 2002 Maxima SE, 1WildPig, 2004tdigls, 14 invisible), 1,930 guests, and 54 spiders.
Topics284,726
Posts4,875,839
Members67,327
Most Online2,548
Feb 16th, 2019
Sprinkler valve question. #4781407
06/08/18 02:26 PM
06/08/18 02:26 PM
Hudson, NH
LeakySeals Online content OP
LeakySeals  Online Content OP
Hudson, NH
I want to straighten out a manifold valve that was installed twisted, hampering maintenance of other valves. Do I have to use this type clamp, or is a regular hose clamp ok? I don't have a crimper tool for a clamp like that.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Re: Sprinkler valve question. [Re: LeakySeals] #4781411
06/08/18 02:31 PM
06/08/18 02:31 PM
USA
oldhp Offline
oldhp  Offline
USA
A stainless steel automotive worm clamp should work fine to me.
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: Sprinkler valve question. [Re: LeakySeals] #4781428
06/08/18 02:49 PM
06/08/18 02:49 PM
FL
9050lx Offline
9050lx  Offline
FL
A quality clamp though, not a cheap China special that strips the worm gear at 5 ft lbs of torque.
Re: Sprinkler valve question. [Re: LeakySeals] #4781535
06/08/18 04:51 PM
06/08/18 04:51 PM
UT
BHopkins Offline
BHopkins  Offline
UT
As oldhp says, a worm gear style clamp will work fine, but use a quality stainless steel type. Also, always double clamp. Single clamps do not always hold well enough. Trust me on this one. Almost $10,000 of flood repair because of a failed sprinkler system hose clamp.
2013 Subaru Outback 2.5i - Idemitsu 0W-20 & Mobil 1 filter
2007 Mercedes SL550 - M1M 5W-40 & MB OEM filter
Re: Sprinkler valve question. [Re: BHopkins] #4781543
06/08/18 05:03 PM
06/08/18 05:03 PM
Hudson, NH
Hudson, NH
I will, thank you. Probably the answer to my leaky pool hoses as well.
Re: Sprinkler valve question. [Re: LeakySeals] #4781679
06/08/18 07:18 PM
06/08/18 07:18 PM
WY
sloinker Offline
sloinker  Offline
WY
Buy some new hose as the barbs will have already stretched out that piece. Carefully cut the old hose out with a utility knife minimizing the twisting of other connections.
Re: Sprinkler valve question. [Re: LeakySeals] #4781768
06/08/18 08:58 PM
06/08/18 08:58 PM
North Carolina
OilFilters Offline
OilFilters  Offline
North Carolina
The tool to use those type of pinch clamps is only around $20, they work better and the clamps are cheaper. Makes for a more professional job when you are done. I love using those pinch clamps for garden hose repair, they won't cut your hand like the tail on a normal worm gear type.
Moderated by  ekpolk
