NY Yankee fans...
by gfh77665 - 10/20/19 12:56 AM
168 inch pounds feels really--really tight
by perfect_oil - 10/19/19 11:36 PM
Older fram ultra
by tblt44 - 10/19/19 08:42 PM
Best price on Colt 9MM pattern mags?
by GumbyJarvis - 10/19/19 08:20 PM
Using a trim router for cutting sheetrock
by JLawrence08648 - 10/19/19 08:09 PM
C&P of a Tough Guard w/50,000 miles to be posted soon
by MrQuackers - 10/19/19 08:04 PM
Chevy dealer, 7 free oil changes?
by Zacc - 10/19/19 07:34 PM
School me..1200 amp jumper
by Schmoe - 10/19/19 07:19 PM
YouTube Finish Test
by RayCJ - 10/19/19 07:09 PM
Overfilled, drained some, still too full?
by OCDriver - 10/19/19 06:16 PM
Wix made in Korea?
by JGmazda - 10/19/19 06:01 PM
Oil change interval question
by SkipCam - 10/19/19 05:49 PM
Remove Spark Plug Wires
by borgward - 10/19/19 04:53 PM
Pinion yoke loose, is the bearing ruined?
by Fsharp - 10/19/19 03:45 PM
Need tires for the mustang
by BeerCan - 10/19/19 03:24 PM
No sign of of oil sample at BStone :(
by 21Rouge - 10/19/19 02:45 PM
Carpet Shopping - Need Advice
by The Critic - 10/19/19 02:17 PM
Local Autozone clearance
by Soggydog - 10/19/19 02:05 PM
Two Fumoto valves
by otis24 - 10/19/19 01:17 PM
Hallj49803, Tralever, Jhams, gmguy57, jamie24874
69612 Registered Users
29 registered members (4WD, billt460, Duke, csandste, bmod305, cos, 4 invisible), 759 guests, and 20 spiders.
Topics296,198
Posts5,093,326
Members69,612
Most Online3,532
Jul 30th, 2019
2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi #4781095 06/08/18 09:52 AM
The Critic Offline OP
Background info and general thoughts:
- This oil fill was installed at the vehicleís first oil change, which took place at 9,382 miles.
- At the time of oil sampling, the vehicle had been driven for more than 30 minutes at highway speeds. OLM was at 5% remaining. A Genuine Honda Oil Filter (A02) was used for the duration of this oil fill.
- At the time of oil sampling, the oil level was not abnormally high.
- Driving style consists of many short 5-10 mile trips in-town, however, the vehicle sees several 150 mi highway trips each month.
- I confirmed using the Honda J2534 rewrite tool that the vehicle has the latest engine calibration installed.
- Bearing wear appears to be controlled and the oxidation/nitration numbers are quite favorable. Despite the high fuel dilution, the oil appears to be doing its job very well.
2011 Toyota Prius 1.8L - 198K - Pennzoil Platinum 0W-20
2007 Honda Accord 2.4L - 139K - Valvoline Premium Blue Restore 10W-30
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781112 06/08/18 10:11 AM
Danh Offline
Realize this engine is still fairly new, but isnít 3.7ppm iron/1,000 miles still pretty high? Maybe fuel dilution isnít quite so harmless.
This engine does seem more prone to fuel dilution than most. There was an extended sales stop in China for this reason; still waiting to see if American Honda incorporates any of the changes made for the Chinese market n
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: Danh] #4781124 06/08/18 10:24 AM
dave1251 Offline
No. 3.7 parts per million of iron per 1,000 miles is not high.
don't use.
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781129 06/08/18 10:29 AM
deven Offline
Does Mobil 1 EP 0w20 really only has 944ppm's of Calcium?
Proud user of ROYAL PURPLE products!
2019 BMW 330i X-drive(Factory Fill)
KEEP IT SIMPLE STUPID. IT'S ONLY OIL
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: deven] #4781156 06/08/18 10:46 AM
PimTac Offline
All the new formulations for the most part have lowered calcium. Itís not a issue.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781182 06/08/18 11:11 AM
1
1JZ_E46 Offline
1
Yikes. Oil was water thin when changed.
2019 Tesla Model 3 SR+
2016 Countryman S: Castrol 0W-40
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: 1JZ_E46] #4781256 06/08/18 12:27 PM
J
John_Dude Offline
J
water has a viscosity of 0.294 CST @ 100c
soooo... not quite.
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: John_Dude] #4781279 06/08/18 12:53 PM
1
1JZ_E46 Offline
1
soooo... not quite.
It's called a figure of speech.
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781302 06/08/18 01:28 PM
W
webfors Offline
W
These new Honda engines do not perform the same as the old Honda engines with respect to UOAs. I used to gush over the boring Honda UOAs. These are not boring.
I personally would not run a 20 weight in an engine that is known to reduce the viscosity of oil by 25-30%.
17 Cadillac ATS 2.0T, Edge D1G2 5w30, Champion COS10590
17 Dodge GC, VWB 5w30, Mopar MO-349
18 DL1000XT, Valvoline Dino 20w50, Suzuki OEM OF
Small engines; RT5 10w30
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781330 06/08/18 01:55 PM
J
JAG Offline
J
Mouse milk. laugh Is the factory fill a 5W-16 or 0W-16? What viscosity grade is recommended?
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781335 06/08/18 01:59 PM
H
HemiHawk Offline
H
Would it be wise to cut the interval back to 5k miles and see what that does for the fuel dilution? Its interesting that Honda's recall on some of those 1.5T motors states the the fuel issues had to do with cold climates... but this 1.5T is operated in CA.
2015 Mustang GT
2017 VW GTI sport
1995 Mustang GTS
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781345 06/08/18 02:12 PM
J
JAG Offline
J
In my opinion, the fuel content will reach steady state amount too quickly (maybe within 1k to 2k miles), so changing the oil at 5k miles isnít going to get the oil changed before it builds up more fuel in it. If one wanted to counteract the effect on viscosity, one could initially add less than the full amount and then starting around 1k miles gradually add oil one or two viscosity grades higher until the oil level is full.
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781434 06/08/18 04:00 PM
L
LotI Offline
L
I would run a 30 grade to 15% on the MM. is the sump really 4qts?...maybe change it at 5k/50%.
Honda has a recall in China for fuel dilution...in China
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX http://www.fuelly.com/car/buick/regal_tourx/2019/loti/943992
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781444 06/08/18 04:11 PM
Danh Offline
0w-20 is specíd. Sump + filter = 3.7 quarts.
And I still think 3.7 ppm of iron/1,000 Miles is a lot for a 1.5 liter engine.
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781568 06/08/18 06:28 PM
P
parshisa Offline
P
Twice as much of iron per 1k as i had on my second drain. I doesnít look like stratching OCI that far is a bright idea. Although Iím going 7.5K on my cutrent fill
