Do you label your oil filters when installing them?
by double vanos. 05/22/19 11:54 PM
'02 BMW 530i, Castrol Edge 0W-40, 3,850 miles
by Quattro Pete. 05/22/19 09:36 PM
That's not 30-36 lb/ft
by HangFire. 05/22/19 08:29 PM
"Usually ships within 1 to 3 months"
by das_peikko. 05/22/19 08:15 PM
Drones....
by Shannow. 05/22/19 08:06 PM
Removed Valve Cover
by miden851. 05/22/19 07:52 PM
Machine Polishers
by The Critic. 05/22/19 07:49 PM
Greasing without zerks?
by Fitz98. 05/22/19 07:47 PM
Who is lying?
by wjeszy. 05/22/19 07:40 PM
Oil extractor on Honda r18 engine
by JunkdrawerDog. 05/22/19 06:35 PM
Venting bathroom fans
by Donald. 05/22/19 05:59 PM
Mobil 1 5W30, 10980 kms, GMC Sierra 4.3l
by George7941. 05/22/19 05:40 PM
Tire dealer sold me 4 year old tires
by lange. 05/22/19 05:01 PM
Car door hinge squeals like a stuck...
by Mad_Hatter. 05/22/19 04:39 PM
Up2nogood, JP69, Bluethunder, patcatpat, Wilvoeka
68181 Registered Users
60 registered members (BigJohn, bdcardinal, Atesz792, bigdavey, Ag76, 7 invisible), 1,126 guests, and 23 spiders.
Topics289,270
Posts4,965,824
Members68,181
Most Online2,967
Mar 10th, 2019
2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi #4781095
06/08/18 09:52 AM
06/08/18 09:52 AM
CA
The Critic Offline OP
CA
Background info and general thoughts:
- This oil fill was installed at the vehicleís first oil change, which took place at 9,382 miles.
- At the time of oil sampling, the vehicle had been driven for more than 30 minutes at highway speeds. OLM was at 5% remaining. A Genuine Honda Oil Filter (A02) was used for the duration of this oil fill.
- At the time of oil sampling, the oil level was not abnormally high.
- Driving style consists of many short 5-10 mile trips in-town, however, the vehicle sees several 150 mi highway trips each month.
- I confirmed using the Honda J2534 rewrite tool that the vehicle has the latest engine calibration installed.
- Bearing wear appears to be controlled and the oxidation/nitration numbers are quite favorable. Despite the high fuel dilution, the oil appears to be doing its job very well.
2011 Toyota Prius 1.8L - 190K - Idemitsu ZEPRO Adv. Moly 0W-20
2007 Honda Accord 2.4 - 137K - Mobil 1 EP HM 5W-30
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781112
06/08/18 10:11 AM
06/08/18 10:11 AM
Danh Offline
Danh  Offline
Realize this engine is still fairly new, but isnít 3.7ppm iron/1,000 miles still pretty high? Maybe fuel dilution isnít quite so harmless.
This engine does seem more prone to fuel dilution than most. There was an extended sales stop in China for this reason; still waiting to see if American Honda incorporates any of the changes made for the Chinese market n
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: Danh] #4781124
06/08/18 10:24 AM
06/08/18 10:24 AM
Maricopa Arizona
dave1251 Offline
dave1251  Offline
Maricopa Arizona
No. 3.7 parts per million of iron per 1,000 miles is not high.
don't use.
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781129
06/08/18 10:29 AM
06/08/18 10:29 AM
Massachusetts
deven Offline
deven  Offline
Massachusetts
Does Mobil 1 EP 0w20 really only has 944ppm's of Calcium?
Proud user of ROYAL PURPLE products!
2019 BMW 330i X-drive(Factory Fill)
KEEP IT SIMPLE STUPID. IT'S ONLY OIL
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: deven] #4781156
06/08/18 10:46 AM
06/08/18 10:46 AM
PimTac Offline
PimTac  Offline
All the new formulations for the most part have lowered calcium. Itís not a issue.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781182
06/08/18 11:11 AM
06/08/18 11:11 AM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Yikes. Oil was water thin when changed.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: Castrol 0W-40
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: 1JZ_E46] #4781256
06/08/18 12:27 PM
06/08/18 12:27 PM
WA
John_Dude Offline
John_Dude  Offline
WA
water has a viscosity of 0.294 CST @ 100c
soooo... not quite.
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: John_Dude] #4781279
06/08/18 12:53 PM
06/08/18 12:53 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
soooo... not quite.
It's called a figure of speech.
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781302
06/08/18 01:28 PM
06/08/18 01:28 PM
Great White North.. eh
webfors Offline
webfors  Offline
These new Honda engines do not perform the same as the old Honda engines with respect to UOAs. I used to gush over the boring Honda UOAs. These are not boring.
I personally would not run a 20 weight in an engine that is known to reduce the viscosity of oil by 25-30%.
17 Cadillac ATS 2.0T, Edge D1G2 5w30, Champion COS10590
17 Dodge GC, VWB 5w30, Mopar MO-349
15 DL650, Valvoline Dino 20w50, Suzuki OEM OF
Small engines; RT5 10w30
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781330
06/08/18 01:55 PM
06/08/18 01:55 PM
Fredericksburg, VA
JAG Offline
JAG  Offline
Fredericksburg, VA
Mouse milk. laugh Is the factory fill a 5W-16 or 0W-16? What viscosity grade is recommended?
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781335
06/08/18 01:59 PM
06/08/18 01:59 PM
PA,US
HemiHawk Offline
HemiHawk  Offline
PA,US
Would it be wise to cut the interval back to 5k miles and see what that does for the fuel dilution? Its interesting that Honda's recall on some of those 1.5T motors states the the fuel issues had to do with cold climates... but this 1.5T is operated in CA.
2016 Nissan Frontier Pro4x
2017 VW GTI sport
1995 Mustang GTS
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781345
06/08/18 02:12 PM
06/08/18 02:12 PM
Fredericksburg, VA
JAG Offline
JAG  Offline
Fredericksburg, VA
In my opinion, the fuel content will reach steady state amount too quickly (maybe within 1k to 2k miles), so changing the oil at 5k miles isnít going to get the oil changed before it builds up more fuel in it. If one wanted to counteract the effect on viscosity, one could initially add less than the full amount and then starting around 1k miles gradually add oil one or two viscosity grades higher until the oil level is full.
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781434
06/08/18 04:00 PM
06/08/18 04:00 PM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
I would run a 30 grade to 15% on the MM. is the sump really 4qts?...maybe change it at 5k/50%.
Honda has a recall in China for fuel dilution...in China
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781444
06/08/18 04:11 PM
06/08/18 04:11 PM
Danh Offline
Danh  Offline
0w-20 is specíd. Sump + filter = 3.7 quarts.
And I still think 3.7 ppm of iron/1,000 Miles is a lot for a 1.5 liter engine.
Re: 2017 Honda CR-V 1.5T, Mobil 1 EP 0W-20, 10,188 mi [Re: The Critic] #4781568
06/08/18 06:28 PM
06/08/18 06:28 PM
TX
parshisa Offline
parshisa  Offline
TX
Twice as much of iron per 1k as i had on my second drain. I doesnít look like stratching OCI that far is a bright idea. Although Iím going 7.5K on my cutrent fill
