2002 chevy tahoe 5.3 oil selection
by Zahndkile - 09/19/19 12:20 AM
Considering Solar
by mbacfp - 09/18/19 11:16 PM
2008 Duramax
by Firemedic15 - 09/18/19 11:02 PM
Fleetguard LF777 performance
by Pyrotechnic - 09/18/19 10:54 PM
Any Vacuum experts? :)
by maverickfhs - 09/18/19 09:50 PM
15 F150 Gear & Transfer Case Question
by BISCUT - 09/18/19 09:24 PM
Anyone buy/run used tires?
by addyguy - 09/18/19 08:15 PM
2019 Mazda CX-5 Diesel
by miden851 - 09/18/19 07:58 PM
Toyota 90915-YZZD1 Cut Open (Sludge?)
by ThirdeYe - 09/18/19 07:45 PM
Fram Core COR3614ACC Cut Open
by ThirdeYe - 09/18/19 07:35 PM
Never the cheap part that goes bad...
by Elkins45 - 09/18/19 07:34 PM
Denso First Time Fit 150-1009 Cut Open (2 filters)
by ThirdeYe - 09/18/19 07:31 PM
2008 CRV A/C compressor replacement
by nwjones18 - 09/18/19 07:27 PM
Fram Ultra XG4967 Cut Open
by ThirdeYe - 09/18/19 07:25 PM
Ford Motorcraft FL-820S Cut Open
by ThirdeYe - 09/18/19 07:12 PM
AC Delco PF47E cut open
by ThirdeYe - 09/18/19 07:07 PM
AC Delco PF46 (Classic) Cut Open
by ThirdeYe - 09/18/19 07:01 PM
Carbon chains
by sloinker - 09/18/19 06:51 PM
Blain;s again .99 Citgo A/R
by dblshock - 09/18/19 06:46 PM
Is griots glass sealant rebranded rain x?
by WhyMe - 09/18/19 05:48 PM
bbrown, Firemedic15, jazzthepro, F_150_18, safebraking
69323 Registered Users
33 registered members (dishdude, Ctopher, Cubey, carlprop, ChristianReske, anndel, 3 invisible), 840 guests, and 23 spiders.
Topics294,761
Posts5,065,996
Members69,323
Most Online3,532
Jul 30th, 2019
Page 3 of 3 1 2 3
Re: Spraying WD40 on arthritic joints?? [Re: BJD78] #4779771 06/07/18 03:03 AM
F
FT92 Offline
F
I have add my story....my uncle and dad both used wd 40 on joint pain and swore by it , both lived to 89 years old...myself I haven't tried it , not sure I will , but I guess if the pain is bad enough you just might try anything
Re: Spraying WD40 on arthritic joints?? [Re: BJD78] #4780738 06/07/18 10:27 PM
Driz Offline
Try rubbing or a poultice of castor oil instead. They have been using that for thousands of years and it really does work. Much cheaper too .
Re: Spraying WD40 on arthritic joints?? [Re: tc1446] #4780842 06/08/18 02:03 AM
Shannow Offline
Originally Posted By: tc1446
Originally Posted By: OneEyeJack
You've only got part of it. The story is that you put DMSO or ground up aspirin on the knee, spray it with WD-40 and then rub it in.
DMSO is a long time product used for such things. Heres what an MD web site says:
DMSO has been used as an industrial solvent since the mid-1800s. From about the mid-20th century, researchers have explored its use as an anti-inflammatory agent.
The FDA has approved DMSO as a prescription medication for treating symptoms of painful bladder syndrome. It's also used under medical supervision to treat several other conditions, including shingles.
DMSO is easily absorbed by the skin. It's sometimes used to increase the body's absorption of other medications.
Yes, DMSO is being used to speed, or even enable getting medications tow work transdermally. I've got some, don't use it for anything, just that I've got some.
Put it on your finger, and rub on the soles of your feet, and within minutes the garlic taste is in your mouth.
Re: Spraying WD40 on arthritic joints?? [Re: BJD78] #4788732 06/16/18 10:59 PM
V
vavavroom Offline
V
I believe the guy is rather a joker than a prat.
Re: Spraying WD40 on arthritic joints?? [Re: BJD78] #4871952 09/18/18 01:33 PM
Yah-Tah-Hey Offline
Fine line between foolishness and fraud.
Re: Spraying WD40 on arthritic joints?? [Re: andyd] #4894044 10/11/18 03:08 PM
M
mrdctaylor Offline
M
Originally Posted by andyd
MMO would smell better
I've actually heard of old guys using MMO this way, but never WD40.
02 Tacoma 3.4L, 231K, Hav ProDS 10W30 (me)
12 Highlander 3.5L, 111K, Napa Syn 0W20 (wife)
17 Escape 2.0L, 48K, Hav ProDS 5W30 (son)
Re: Spraying WD40 on arthritic joints?? [Re: BJD78] #4900028 10/19/18 05:42 AM
O
onetwoothreee Offline
O
Doing it wrong. You have to jam that nozzle in there deep.
Page 3 of 3 1 2 3
