How often to drive a car that sits in the winter?
by Corollaman. 02/17/19 08:49 AM
Top Off or Change it Early
by 99Saturn. 02/17/19 08:22 AM
Do your vehicles have a nickname?
by ZZman. 02/17/19 08:19 AM
Another work project thread
by mattd. 02/17/19 08:18 AM
Buzzing sound behind dash
by Spetz. 02/17/19 05:09 AM
Ain't stupid, but can't find Cummin Hist
by BrocLuno. 02/16/19 11:41 PM
Rethinking oil choices
by JLTD. 02/16/19 11:29 PM
coolster 150 cc atv 2019 new
by hyperscion. 02/16/19 10:37 PM
older gps - week counter rollover Apr 6 '19
by spackard. 02/16/19 10:32 PM
Thoughts on an old Lexus?
by JustN89. 02/16/19 09:50 PM
Understanding Fuel Trims for diagnostics.
by StevieC. 02/16/19 07:59 PM
book of matches for tune up?
by marine65. 02/16/19 07:53 PM
New Penrite 0w-30
by toyota62. 02/16/19 07:45 PM
New HID bulbs for the Cadillac
by 14Accent. 02/16/19 07:17 PM
2008 Prius - Water in oil
by cjolson140. 02/16/19 07:00 PM
Kitchen Faucet question
by reemoe2. 02/16/19 06:56 PM
Time for brakes again
by SilverFusion2010. 02/16/19 05:23 PM
Darn brake rotors
by Dave Sherman. 02/16/19 03:42 PM
looking @ a 2010 Escape Hybrid...
by earlyre. 02/16/19 03:24 PM
jpdeal, Snipeuout, DeltaWing, JRS3, krzyq
67252 Registered Users
102 registered members (bbslider001, 53' Stude, Audios, berlyn, AdditiveOCD, 8 invisible), 1,630 guests, and 55 spiders.
Topics298,304
Posts4,989,196
Members67,252
Most Online2,548
Feb 16th, 2019
2006 VW Jetta 1.9 TDI Schaeffers 5W 40 #4780718
06/07/18 09:14 PM
06/07/18 09:14 PM
Cincinnati
SAAA Offline OP
SAAA  Offline OP
Cincinnati
This is my first oil sample on this car. Using Schaeffers 5w 40. I ran the oil for 10k before the change. I deleted the EGR at 9,500 on this oil. Using a WIX filter. Was hoping to get some feedback on this oil report. Not too concerned about the metal wear, and was wondering if deleting EGR could cause a spike in certain metals. Thanks
Re: 2006 VW Jetta 1.9 TDI Schaeffers 5W 40 [Re: SAAA] #4780841
06/08/18 12:59 AM
06/08/18 12:59 AM
Suomi
Bjornviken Offline
Bjornviken  Offline
Suomi
Does this oil meet VW spec?
Re: 2006 VW Jetta 1.9 TDI Schaeffers 5W 40 [Re: SAAA] #4780852
06/08/18 01:31 AM
06/08/18 01:31 AM
Rio Rancho, NM
Pajero Offline
Pajero  Offline
Rio Rancho, NM
No Antimony? Very interesting.
Respectfully,
Pajero!
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 133,xxx
Fram Ultra/ Snorkel with Pre-filter
K-9-Co-pilot
Re: 2006 VW Jetta 1.9 TDI Schaeffers 5W 40 [Re: Bjornviken] #4780924
06/08/18 05:34 AM
06/08/18 05:34 AM
Cincinnati
SAAA Offline OP
SAAA  Offline OP
Cincinnati
When I started using Schaeffers about 5 years ago the bottle used to carry the VW approved specs. From my understanding there hasn't been a change in the oil, but Schaeffers no longer goes through the process of getting the VW certification. Someone please correct me if I'm wrong, but I'm confident the oil exceeds the VW specs.
Re: 2006 VW Jetta 1.9 TDI Schaeffers 5W 40 [Re: SAAA] #4781251
06/08/18 11:20 AM
06/08/18 11:20 AM
California
CleverUserName Offline
California
Deleting the EGR should reduce your wear metals and improve TBN retention.
Itís still 40w @ 10k miles so it held up. However the iron wear on these engines, esp with an EGR delete is usually a lot less.
Do you have a magnetic drain plug? If so, Was there any significant iron on the plug?
Did you notice any metals held in the filter?
High iron can be indicative of camshaft wear, which is a problem with these PD engines. Once the hard facing on the cam is worn through, failure is not far behind.
Re: 2006 VW Jetta 1.9 TDI Schaeffers 5W 40 [Re: CleverUserName] #4781267
06/08/18 11:42 AM
06/08/18 11:42 AM
Cincinnati
SAAA Offline OP
SAAA  Offline OP
Cincinnati
I don't have a Magnetic Drain Plug and I didn't notice any metals in the filter. The Camshaft was replaced 80k miles ago with a (BEW) cam from TDIFrank. The original cam had a little over 100k miles with very little wear. At that time I was running Castrol 505 5w30 VW approved oil from the dealer. Every since the cam swap I have been running Schaeffers 9000 5W40. Now that the EGR has been deleted I plan to run another 10k to see how the metals wear.
Re: 2006 VW Jetta 1.9 TDI Schaeffers 5W 40 [Re: SAAA] #4787566
06/15/18 02:20 PM
06/15/18 02:20 PM
Missouri
Rodmiser Offline
Rodmiser  Offline
Missouri
8008 Advanced European Performance Mid SAPS 5W-30 507
Re: 2006 VW Jetta 1.9 TDI Schaeffers 5W 40 [Re: SAAA] #4816327
07/17/18 11:08 AM
07/17/18 11:08 AM
Austin, Texas
Brons2 Offline
Brons2  Offline
Austin, Texas
IIRC those cam bearings are tri-metal on the PD engines. Watch your copper and lead.
2012 Hyundai Sonata GLS 6MT 2.4GDI, ProDS 10w30, XG9688 filter, 2018 Mitsubishi Outlander SEL 2.4 CVT, Factory fill still.
Re: 2006 VW Jetta 1.9 TDI Schaeffers 5W 40 [Re: Bjornviken] #4872463
09/19/18 04:57 AM
09/19/18 04:57 AM
Michigan
MoparMan12 Offline
MoparMan12  Offline
Michigan
I did not see the VW spec on the list for their 5w-40 but it does seem to be working for him.
Moderated by  ekpolk
