How often to drive a car that sits in the winter?
by Corollaman. 02/17/19 08:49 AM
Top Off or Change it Early
by 99Saturn. 02/17/19 08:22 AM
Do your vehicles have a nickname?
by ZZman. 02/17/19 08:19 AM
Another work project thread
by mattd. 02/17/19 08:18 AM
Buzzing sound behind dash
by Spetz. 02/17/19 05:09 AM
Ain't stupid, but can't find Cummin Hist
by BrocLuno. 02/16/19 11:41 PM
Rethinking oil choices
by JLTD. 02/16/19 11:29 PM
coolster 150 cc atv 2019 new
by hyperscion. 02/16/19 10:37 PM
older gps - week counter rollover Apr 6 '19
by spackard. 02/16/19 10:32 PM
Thoughts on an old Lexus?
by JustN89. 02/16/19 09:50 PM
Understanding Fuel Trims for diagnostics.
by StevieC. 02/16/19 07:59 PM
book of matches for tune up?
by marine65. 02/16/19 07:53 PM
New Penrite 0w-30
by toyota62. 02/16/19 07:45 PM
New HID bulbs for the Cadillac
by 14Accent. 02/16/19 07:17 PM
2008 Prius - Water in oil
by cjolson140. 02/16/19 07:00 PM
Kitchen Faucet question
by reemoe2. 02/16/19 06:56 PM
Time for brakes again
by SilverFusion2010. 02/16/19 05:23 PM
Darn brake rotors
by Dave Sherman. 02/16/19 03:42 PM
jpdeal, Snipeuout, DeltaWing, JRS3, krzyq
67252 Registered Users
107 registered members (AdditiveOCD, 53' Stude, 1foxracing, 2015_PSD, Audios, 9 invisible), 1,775 guests, and 53 spiders.
Topics298,305
Posts4,989,208
Members67,252
Most Online2,548
Feb 16th, 2019
:::Re-Torquing Bolt After Loctite #4780582
06/07/18 07:26 PM
06/07/18 07:26 PM
Charlotte NC
NDL Offline OP
NDL  Offline OP
Charlotte NC
I gotta question for y'all:
Over the past month I have asked my fellow posters what they thought about me swapping out my fixed steering column, for a tilt steering column, out of the same year truck (2001 Ford Ranger).
Y'all gave me excellent advice, and I am grateful for it. I did the swap on Saturday, and I am so glad that I did...I am a tall guy and the tilt column gives my legs extra wiggle room.
I did not use a torque wrench on the steering wheel bolt or the pincher bolt at the bottom of the column, but I did tighten both (screw and nut) *very* tight. I coated both the steering wheel nut threads, and pincher bolt threads, with loctite blue; up and down the threads, top to bottom.
The truck drives fine, but it was suggested that I recheck the pincher bolt for tightness after a week or two of driving. If I do this, will I not break the loctite seal? Since I did not use a torque wrench when I installed the new column - at best, I can take it to my mechanic, and have him test the bolt for tightness with his torque wrench. I am assuming that the bolts are spec+ (again, they were very tight), when my mechanic sets his torque wrench to the bolt, since it should be within spec, the bolt will not move, and the loctite seal will be preserved. On the other hand, is it necessary that I take a wrench to the pincher bolt, or is a visual inspection sufficient? After tightening the bolt, a 2/8 of an inch of threads were exposed - and I should see the same now. I did put quite a bit of loctite on the threads, and I can't see them moving anywhere.
I do realize that I am coming to y'all with a few unknown variables here. Any advice?
Re: :::Re-Torquing Bolt After Loctite [Re: NDL] #4780585
06/07/18 07:27 PM
06/07/18 07:27 PM
ME
eljefino Offline
eljefino  Offline
ME
Leave it alone. Match mark the nuts with a sharpie if you're worried; if they slip, you'll see the misaligned marks.
Re: :::Re-Torquing Bolt After Loctite [Re: NDL] #4780609
06/07/18 07:41 PM
06/07/18 07:41 PM
Mid Atlantic
229 Offline
229  Offline
Mid Atlantic
You would not get an accurate torque reading with Loctite applied and would break the seal trying. If you put the German torque of Guten-Tight on it with the Loctite it will be fine. As mentioned, marking the nuts will ease your mind.
Re: :::Re-Torquing Bolt After Loctite [Re: NDL] #4780620
06/07/18 07:46 PM
06/07/18 07:46 PM
Charlotte NC
NDL Offline OP
NDL  Offline OP
Charlotte NC
I have driven the truck of a total of 50 miles since I did the job; to confirm: it isn't too late to use the sharpie approach (an excellent idea!)?
Appreciate y'all's help. Since this is my first column, I am taking a "better safe than sorry approach" hence the multitude of questions. Again, thank you both
Re: :::Re-Torquing Bolt After Loctite [Re: NDL] #4780627
06/07/18 07:50 PM
06/07/18 07:50 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Not a fan of loctite. There are cheaper ways. A sharp punch right in the top of the nut against the thread. My latest discovery is external tooth washers. 4 cents apiece. Ny-lock nuts are a better application. I get free loctite brown. AKA rust. grin2
Thick oil is better grin2
Re: :::Re-Torquing Bolt After Loctite [Re: andyd] #4780631
06/07/18 07:55 PM
06/07/18 07:55 PM
Charlotte NC
NDL Offline OP
NDL  Offline OP
Charlotte NC
Appreciate the input, and yes, ny-lock nuts...can't live without them smile.
Re: :::Re-Torquing Bolt After Loctite [Re: NDL] #4780640
06/07/18 08:05 PM
06/07/18 08:05 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
RE: Threadlocker application
You only need a dab covering three threads (and not all around, just a straight "line" from top to bottom) to get a perfect threadlocker anti-vibration lock. It will self-spread as required, it sets in the absence of air and the presence of moisture (from the air, prior to assembly).
The stuff is expensive, no need to over-apply. It won't work any better if you do, it's not a matter of "if some is good, too much should be perfect".
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: :::Re-Torquing Bolt After Loctite [Re: eljefino] #4780663
06/07/18 08:27 PM
06/07/18 08:27 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
+1
Re: :::Re-Torquing Bolt After Loctite [Re: eljefino] #4780679
06/07/18 08:38 PM
06/07/18 08:38 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Leave it alone.
+2
Re: :::Re-Torquing Bolt After Loctite [Re: Johnny2Bad] #4780683
06/07/18 08:44 PM
06/07/18 08:44 PM
Charlotte NC
NDL Offline OP
NDL  Offline OP
Charlotte NC
I appreciate you educating me; I never knew that "more isn't better" with loctite. Thank you.
+1
Originally Posted By: Trav
Leave it alone.
+2
Thanks guys...I feel a lot better about my project now that I have consulted with y'all.
Re: :::Re-Torquing Bolt After Loctite [Re: NDL] #4780744
06/07/18 09:29 PM
06/07/18 09:29 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
If you applied blue Loctite and tightened it up well, no need to check. Itís done and done.
If you want the job done right......do it yourself.
Moderated by  ekpolk
