Hand Sanitizer 1gallon $36 after code
by Touring5 - 03/31/20 08:49 AM
Trailblazer tire pressures
by zrxkawboy - 03/31/20 06:01 AM
Lincoln MKZ hybrid / Sitting for 6+ weeks
by Ammofirst - 03/31/20 04:01 AM
Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
SantiagoT, cabriopeugeot, Z08969, TCU_Adam, deaner1979
71063 Registered Users
102 registered members (1978elcamino, 2015_PSD, 4WD, 53' Stude, 07titan, 007, 9 invisible), 1,673 guests, and 17 spiders.
Topics303,501
Posts5,235,289
Members71,063
Blazer swaying after alignment. #4779947 06/07/18 08:54 AM
dlundblad Offline OP
I replaced the upper and lower control arms (w/ ball joints and bushings.), tie rod ends, adjusting sleeves, camber bolts, pitman arm, idler arm, and sway bar end links. While driving it to the shop, I could feel it swaying as I went over bumps. I figured it was no big deal seeing how the toe could have very well been off.
Got it back today and drove it to work on some bouncy roads. The same condition exists although it isn't quite as severe. Driving down a flat road the truck drives straight with no pulling. By swaying, I mean it feels like it's being pulled to the left and to the right almost simultaneously.
*I also added new bump stops which are about 2" above the lower control arm with the truck sitting level. I measured my 2 front fenders from the ground after initially adjusting the torsion bars and I was about 1/4" off. Perhaps something changed and one is cranked substantially different than the other?
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Blazer swaying after alignment. [Re: dlundblad] #4779984 06/07/18 09:47 AM
Billbert Offline
Did you get a printout of the alignment angles after the alignment, how much positive caster?
If you think you can, or if you think you can't, You are probably right.
Auto Instructor / ASE Master Tech
Re: Blazer swaying after alignment. [Re: dlundblad] #4779999 06/07/18 10:21 AM
T
Trav Offline
T
Caster will also do that, create a slight pull and wandering.
Re: Blazer swaying after alignment. [Re: Billbert] #4780010 06/07/18 10:29 AM
No printout sadly. Didn't even think of asking for one.
Sounds like I should take it back then?
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
Re: Blazer swaying after alignment. [Re: dlundblad] #4780017 06/07/18 10:38 AM
L
Lasthope05 Offline
L
Death wobble.
Re: Blazer swaying after alignment. [Re: dlundblad] #4780072 06/07/18 12:11 PM
T
Trav Offline
T
Sure take it back, tell them its wandering all over the place like a homeless person, and trying to pull you all over the place like a street walker.
Re: Blazer swaying after alignment. [Re: Trav] #4780083 06/07/18 12:21 PM
That'd be a slight over exaggeration, but it certainly get's the point across.
I did end up calling the shop and the guy said to bring it back in. I told him I'd do some self diagnosing tonight by rotating and properly inflating the tires and if the condition still existed I'd give him a call. He already booked me out a slot for Monday, which is awesome customer service IMO.
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
Re: Blazer swaying after alignment. [Re: dlundblad] #4780342 06/07/18 05:00 PM
T
Trav Offline
T
No print out and I am super PO'd. I need that to understand whats going on and how I might be able to correct it. I have had a clown tell me its fine but the printer is broke. o.2 too much positive camber on the left and caster way out is not fine, he didn't bother to mention the rear toe was out because in his opinion it isn't adjustable anyway, it is with shims.
I couldn't wait to the dealers machine on the weekend to do it myself so I had a place I used before for a quick job do it for a customer, huge mistake. Mess around like that and I am not an easy person to deal with.
Re: Blazer swaying after alignment. [Re: dlundblad] #4780394 06/07/18 05:35 PM
B
bigjl Offline
B
I would take it to a different alignment shop.
To me a before and after printout are essential.
I keep them as part of my cars history file.
16 S350d LWB 25k Mobil Super 3000 XE 5w30
17 Smart ForFour Auto 6.5k Mobil 1 0w40 FS
Re: Blazer swaying after alignment. [Re: Trav] #4780405 06/07/18 05:51 PM
Iíll ask tomorrow if I can get a print out or at least a photo of the findings.
I guess if all else fails, off to the Chevy dealer I go.
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
Re: Blazer swaying after alignment. [Re: dlundblad] #4780408 06/07/18 05:52 PM
A
AVB Offline
A
What is the condition of the shocks?
Re: Blazer swaying after alignment. [Re: AVB] #4780418 06/07/18 06:00 PM
Monroe monoflexes. hide
23k or so.
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
Re: Blazer swaying after alignment. [Re: dlundblad] #4781128 06/08/18 10:28 AM
T
Trav Offline
T
If the shocks are good they are good the brand has no effect on the alignment. The problem is with these places is there is a lot of OJT going on and they don't understand the adjustments and how one angle can effect the other.
Re: Blazer swaying after alignment. [Re: dlundblad] #4781167 06/08/18 10:53 AM
Nick1994 Offline
Did you take the sway bar out?
I ask because my brother had a 97í Chevy pickup that we did the same thing, replaced control arms, toe rods, etc. but put the sway bar back in upside down. It drove fine except clunked over speed bumps. Just a thought.
2015 Hyundai Genesis 5.0L 58k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 238k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Mobil 1 HM 10w40 & Fram Ultra
Re: Blazer swaying after alignment. [Re: dlundblad] #4787606 06/15/18 04:15 PM
Turned out to be a wrong or bad idler arm.
My Rock Auto receipt says 4WD, but the shop thinks itís a 2WD.
One more alignment and the labor/ part... $160.
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
