Have a compressor for our various cars and trucks, it has a coiled air line with the dimensions 1/4" ID, 3/8" OD
The existing and original air line is starting to develop micro fissures and I have cut it multiple times and shortened it from 30 ft down to about 18 ft. Clearly it is on it's way out.
I don't need a loop/coiled hose, while it would be nice but is there a generic high pressure line, able to tolerate easily 150+ PSI for short duration ? Would like to have length around 30 ft.
The existing line connects to a male nipple, inside a coiled compression ring (thus the 1/4" ID, 3/8" OD) and the male nipple is part of a quick connection to the compressor and air gun at the two ends.
In case it is important, when the compressor runs, the closest quick connector end does heat up a little but the compressor automatically shuts off when 150 PSI is reached and waits for demand before restarting.
Have scouted amazon, wallyworld, home depot but not sure what is appropriate.
