BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
103 registered members (4WD, 77GrandPrix, ABN_CBT_ENGR, amblerman, Ag76, 9 invisible), 2,045 guests, and 67 spiders.
Topics306,134
Posts5,288,099
Members71,604
Need recommendation for compressor Air Line #4780194 06/07/18 02:15 PM
H
henni Offline OP
H
Have a compressor for our various cars and trucks, it has a coiled air line with the dimensions 1/4" ID, 3/8" OD
The existing and original air line is starting to develop micro fissures and I have cut it multiple times and shortened it from 30 ft down to about 18 ft. Clearly it is on it's way out.
I don't need a loop/coiled hose, while it would be nice but is there a generic high pressure line, able to tolerate easily 150+ PSI for short duration ? Would like to have length around 30 ft.
The existing line connects to a male nipple, inside a coiled compression ring (thus the 1/4" ID, 3/8" OD) and the male nipple is part of a quick connection to the compressor and air gun at the two ends.
In case it is important, when the compressor runs, the closest quick connector end does heat up a little but the compressor automatically shuts off when 150 PSI is reached and waits for demand before restarting.
Have scouted amazon, wallyworld, home depot but not sure what is appropriate.
Re: Need recommendation for compressor Air Line [Re: henni] #4780205 06/07/18 02:25 PM
ArrestMeRedZ Online Content
Online Content
Harbor Freight used to sell a Goodyear black rubber air hose cheap. Now it has a different brand, touting it as "twice as strong as Goodyear". I've had the Goodyear hose for over 10 years now, and am very happy with it. No clue if the new "Diablo" hose is any good.
Amazon lists the Goodyear black rubber air hose for $29.99 for 3/8"x25', and $24.99 for a 3/8"x50' hose. Hmmm, I think I'd get the 50 ft.
Re: Need recommendation for compressor Air Line [Re: henni] #4780232 06/07/18 02:56 PM
E
EdwardC Offline
E
Lots of options out there. Your hose probably uses fairly standard quick connect fittings, with the male at the compressor, female at the other end. Most hoses are threaded on the end and you may need to buy fittings to put on them, unless you can reuse the quick connects from the old hose.
There are lots of different hose material options that have different advantages. Some are more flexible (particular in cold temperatures), or might be lighter weight, or more durable. For general use, I'd still avoid rubber just for the weight.
I'd recommend one of the newer hybrid hoses, they are flexible at all temps and are fairly light, although the cold temp issue may not be an issue for you.
I personally have this Flexzilla hose: https://www.amazon.com/dp/B001C6NC7O?tag=vglnkc3018-20 The only thing I don't really like about it is that it's bright green, so it gets more visibly dirty looking as I drag it around the garage.
I like Milton brand fittings ( https://www.amazon.com/Milton-S-216-Style-Coupler-Plug/dp/B001O2VPF2 ), but you can probably pick anything up locally that will work.
Re: Need recommendation for compressor Air Line [Re: henni] #4780238 06/07/18 03:09 PM
Superflop Offline
Yeah I will second the flexzilla air hose.. have the hose and whips on some of my air tools. Their water hose looks neat too.
2002 saab 9-5 2.3t wagon
2014 dodge grand caravan
Re: Need recommendation for compressor Air Line [Re: henni] #4780252 06/07/18 03:34 PM
demarpaint Offline
I have Blubird, Flexzilla, and Diablo air hoses. They're all good, but I'd go with Flexzilla if I needed to replace a hose. The Flexzilla doesn't kink, and it rolls up nicely when you're done with it. It does get a little dirty, but nothing that a rag with some Simple Green won't clean right up.
God Bless Our Troops
Re: Need recommendation for compressor Air Line [Re: henni] #4780298 06/07/18 04:07 PM
R
Rand Offline
R
Blubird or flexzilla.
Blubird has a really good price on some site trav linked last year.
edit:
here it is *I think*
https://www.hoseandfittingsupply.com/product-p/blbrd.htm
but I'm not sure that site is working.. wont give a shipping price.
I have one of these... and its amazing
https://www.amazon.com/Flexzilla-Retract...words=flexzilla
Re: Need recommendation for compressor Air Line [Re: Rand] #4780322 06/07/18 04:35 PM
Sluggo0018 Offline
I bought that Bluebird air hose upon Trav's recommendation and love it. It is especially good in the winter when it stays nice and soft with little or no memory. The hose I replaced would stiffen up and become unusable in cold temps. Highly recommend it.
Re: Need recommendation for compressor Air Line [Re: Rand] #4780365 06/07/18 05:13 PM
T
Trav Offline
T
edit:
That's the place, the shipping is free. Great hose, no complaints in year round use, no bubbles or splits.
Re: Need recommendation for compressor Air Line [Re: henni] #4780521 06/07/18 07:37 PM
Donald Offline
Flexzilla. Maybe some Milton fittings that do not restrict air flow as much as normal ones.
2015 Ford F-250 w/Powerstroke
Re: Need recommendation for compressor Air Line [Re: henni] #4780531 06/07/18 07:44 PM
J
Johnny2Bad Offline
J
I go to a local shop ... Goodall, in my case, but every town with a heavy equipment presence will have someone ... and get them to build me a hose with whatever fittings I need and whatever length I want. Heavy duty hose, just tell them what you want and trust their recommendation, and it will be the last air hose you ever buy.
It's not expensive, you basically pay for the quality hose you want at bulk reel per-foot price, fittings are inexpensive, and assembly is "while you wait" and often @ no additional charge. Why buy another Chinese hose?
The only other tip I would have is get large ID hose, it will save you grief in use. Be sure to ask for a flexible hose especially in larger diameters; any "low temperature" use type will be, even if you will never use it in the cold.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Need recommendation for compressor Air Line [Re: henni] #4781151 06/08/18 10:42 AM
P
punisher Offline
P
https://www.amazon.com/gp/product/B001C6NC7O
Bought this in Jan of 2012 and still does its job. No problems. If you ever get cold weather, this is when you really appreciate it.
Re: Need recommendation for compressor Air Line [Re: henni] #4781154 06/08/18 10:44 AM
Rat407 Offline
Flexzilla here as well. Easy to work with, no tangles.
2002 Silverado 5.3 5w-20 AMSOIL
Re: Need recommendation for compressor Air Line [Re: henni] #4782026 06/09/18 08:58 AM
funflyer Online Content
Online Content
I bought this one from Walmart and can't tell the difference from other hybrid hoses I've seen. It hangs from the ceiling in my garage and gets used weekly for just about everything from, tires, painting and blowing dirt out of the garage. So far, after two years of use, it still looks good and is just as flexable as it was when new. I've only used it up to 130PSI.
https://www.walmart.com/ip/Amflo-575-50A...r-Hose/49096187
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Re: Need recommendation for compressor Air Line [Re: henni] #4782059 06/09/18 09:39 AM
H
henni Offline OP
H
How about this one ?
Amflo 12-25E Blue 300 PSI Polyurethane Air Hose 1/4" x 25' With 1/4" MNPT Swivel Ends And Bend Restrictor Fittings
Price: $9.97
https://www.amazon.com/gp/product/B000Q759T4
Re: Need recommendation for compressor Air Line [Re: henni] #4782280 06/09/18 02:16 PM
G
George Bynum Offline
G
Price: $9.97
I've got that in a 50' length ... 99% of my use is inflating tires, it's fine, but doesn't coil worth a flip. IMO, it's too small for air tool use.
