Old school green antifreeze.
Here's the first one that comes to mind for me - Zerex Original Green, available at NAPA
https://www.valvoline.com/our-products/antifreeze-products/zerex-original-green-antifreeze
I assume you want concentrate but 50/50 is available as well.
https://www.napaonline.com/en/p/ZRXZX001
Carquest Conventional Green at Carquest & Advance Auto Parts, can use AAP discount codes
CQ GREEN AF LINK
FWIW I know the CQ Orange is made by Old World Industries and its MSDS is the same as Peak Orange, probably this is the same as Peak Conventional Green.
https://peakauto.com/products/antifreeze-and-cool/auto/conventional-green-full-strength-antifreeze/
Autozone brand Conventional Green
https://www.autozone.com/antifreeze-radi...540722_821605_0
Originally Posted By: Chris142
Originally Posted By: Red91
Walmart, parts stores, farm stores.... practically everywhere that sells antifreeze. Its still very common.
not available at Walmart!
You must have a pitiful walmart. Mine has full-strength and 50-50 in various brands, including Super Tech.
Those are all makes all models long life coolants. Not compatible with some metals in older equipment.
Supertech antifreeze has 2EHA. So is not conventional green.
thanks for the help i was afraid that supertech wasn't the real thing. i will be purchasing oreilly green from now on.
I'm glad someone confirmed it i have looked at all green antifreeze but i couldn't tell which ones where the real thing vs a clone.
If it says it mixes with any color or long life it's the wrong stuff.
Yep...Probably cheap ol'e Prestone.
I bought two gallons of oreilly brand antifreeze that says pre 95 gm i hope it is the right kind i plan on using it after i service the cooling and heating system on my car.
It meets these specs. ASTM D-3306, ASTM D-4340, Chrysler MS 7170, Ford ESE-M97B-44-A, GM 1825M, John Deere H24C1, SAE J103
