Hey BusyLittleShop
by Shannow - 10/21/19 04:47 AM
TT Equalizer: MORryde CRE3000 VS Lippert Equa-Flex
by SavagePatch - 10/21/19 12:53 AM
Group 78 Battery Connector Issues
by Falcon_LS - 10/21/19 12:37 AM
Factors that can affect warming up time
by SlavaB - 10/20/19 11:59 PM
A nokian lineup review
by UG_Passat - 10/20/19 11:19 PM
Dealer Oil Change
by HowAboutThis - 10/20/19 10:35 PM
small qty of automitive paint
by danez_yoda - 10/20/19 09:36 PM
2017 Chevy Cruze recommended oil filter
by Electromotive - 10/20/19 09:13 PM
4L80E to Allison filter conversion
by P10crew - 10/20/19 09:03 PM
Pickles and gardenia
by 53' Stude - 10/20/19 09:00 PM
Weird Electrical Problems Due To Bad Ground.
by RayCJ - 10/20/19 08:59 PM
ECOGARD X 4610 CUT OPEN
by 53' Stude - 10/20/19 08:23 PM
FRAM ULTRA 7317 CUT OPEN
by 53' Stude - 10/20/19 08:17 PM
Easy to use free video editor
by Rat407 - 10/20/19 08:11 PM
Best budget tire for 2006 Nissan Pathfinder SE
by Dogred08 - 10/20/19 07:51 PM
Latest on SSD, HDD and USB Drives?
by JHZR2 - 10/20/19 07:43 PM
Oxy Clean On Leather Seats...WoW
by Warstud - 10/20/19 07:22 PM
Winter street biking
by CourierDriver - 10/20/19 06:47 PM
AltairJr, PMSARATOGA, bobmay460, RoddyCGA, whizznbyu
69628 Registered Users
46 registered members (alchargo, 2015_PSD, 4WD, 77GrandPrix, 1960Elco, 87sammy, 3 invisible), 876 guests, and 21 spiders.
Topics296,251
Posts5,094,232
Members69,628
Most Online3,532
Jul 30th, 2019
Page 1 of 3 1 2 3
LSPI and Euro engines, any low-Ca high-Mg C3 oils? #4779719 06/06/18 11:02 PM
1
1JZ_E46 Offline OP
1
Are European GDI and TGDI engines somehow immune from LSPI? Or do they have ways of addressing beyond changing the oil formulation? Just about every Euro specíd oil Iíve seen (including, LL-01, LL-04, 229.5, 229.51, A40, C30, etc.) are high Ca (2,000-2,400 for A3/B4 and around 1,600 for C3) with essentially no Mg. Even the more recent specs donít seem concerned with calcium doses. It makes me wonder how much changing the calcium content really can impact LSPI. Thoughts? Ever seen a low-Ca C3 oil?
2019 Tesla Model 3 SR+
2016 Countryman S: Castrol 0W-40
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: 1JZ_E46] #4779772 06/07/18 03:24 AM
Z
zeng Offline
Z
C3's I come across are high Ca with minimal Mg.
LSPI as high Ca related in oil is American (marketing) way of sorting out a non-issue in (Euro) LSPI, IMHO.
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: 1JZ_E46] #4779776 06/07/18 04:00 AM
W
wemay Offline
W
Well, Hyundai still publish 5W-40 as a recommended option for the 2.0T and i have that jug on deck for it's next oci. But there have been too many industry papers coming to the same conclusion to think that Calcium and Sodium don't contribute to the issue i.e., from SAE Papers, Chevron Ornite, Lubrizol etc. I guess time will tell. Maybe the exclusion of Na is a simpler, cheaper solution to the issue than introducing the add package found in Euro specc'd oils, just a guess.
2018 KIA Sportage LX 2.4 AWD
GTX Magnatec 5W20, Purolator PL14459
2013 Hyundai Santa Fe Sport 2.0T
GTX Magnatec 5W30, OEM
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: zeng] #4779937 06/07/18 08:50 AM
N
nap Offline
N
I believe the Europeans don't have CAFE and thus don't have much incentives to push the engines regime into LSPI.
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: 1JZ_E46] #4779949 06/07/18 08:55 AM
B
Bjornviken Offline
B
Havent heard of any LSPI related issues here in EU. Think its only concerns the ilsac oils line up.
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: 1JZ_E46] #4779966 06/07/18 09:19 AM
W
Whimsey Offline
W
The European spec oils usually have much higher levels of Zinc & Phosphorus which helps to offset the LSPI caused by higher calcium, so I read. US spec oils have lower levels of Zinc and Phosphorus to help with cat poisoning and those doesn't offset calcium's effect with LSPI.
Whimsey
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: nap] #4779968 06/07/18 09:21 AM
Z
zeng Offline
Z
Points taken, thumbsup
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: Whimsey] #4780024 06/07/18 10:53 AM
W
wemay Offline
W
Whimsey
This^
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: Whimsey] #4780035 06/07/18 11:17 AM
1
1JZ_E46 Offline OP
1
Whimsey
ACEA C3 oils (specs like LL-04, 229.51, C30) have zinc and phosphorous levels about equal to today's SN/GF-5 oils, and they all have no magnesium and most have no moly.
I think part of the reason LSPI doesn't seem to be a concern for euro manufacturers (at least from an oil formulation standpoint) is that they specify premium fuel for their engines, resulting in less soot (a contributor to LSPI).
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: nap] #4780036 06/07/18 11:18 AM
1
1JZ_E46 Offline OP
1
If they are selling their cars here, they have CAFE.
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: 1JZ_E46] #4780041 06/07/18 11:23 AM
Z
zeng Offline
Z
.... but Euro OEM's doesn't recommend RC GF5 oils in CAFEland , do they?
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: zeng] #4780059 06/07/18 11:54 AM
1
1JZ_E46 Offline OP
1
Well, no, but they are still squeezing out every last drop of fuel economy from the engines via engineering and tuning (for CAFE requirements)... which is the cause of LSPI in the first place. Oil is only one very small lever to pull in the quest for MPGs.
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: 1JZ_E46] #4780147 06/07/18 01:26 PM
drtyler Offline
I can't speak for other cars & engines, but the VW EA888 engine in Europe has an extra injector in the intake to squirt a bit of gas down to the valves and the fuel mapping in the ECU is programmed differently (presumably for Euro emission requirements rather than USA & Canada). I realize this affects intake valve buildup rather than LSPI specifically.
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: nap] #4780793 06/07/18 11:41 PM
E
edyvw Offline
E
Nope, they have limits of grams of CO2 per 100km and $6 gallon of gas.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: drtyler] #4780794 06/07/18 11:43 PM
E
edyvw Offline
E
Injector issue is due to cost. Cars in US are cheaper and more affordable.
Also yes, EU engines have more lean burn which produces more NOx which has higher limits in EU.
Page 1 of 3 1 2 3
