Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Slight performance decrease
by A_User55555. 01/21/19 06:54 PM
how to keep your vehicle battery...
by Char Baby. 01/21/19 06:31 PM
2012 to 2016 ford focus
by WhyMe. 01/21/19 06:30 PM
LHM anyone?
by mistersooty. 01/21/19 06:30 PM
Walmart Oil Changes.
by Bill7. 01/21/19 06:10 PM
Coolbreez1973, jmcast1127, DF8005, FT86dude11, RTSAllison
67008 Registered Users
33 registered members (Char Baby, berniedd, alcyon, billt460, BlakeB, citationxeleven, 5 invisible), 868 guests, and 37 spiders.
Topics296,961
Posts4,962,404
Members67,008
Most Online2,821
Jan 21st, 2019
Motorcraft 5w20 synthetic blend substitutes #4779981
06/07/18 08:43 AM
06/07/18 08:43 AM
Pa
Kura Offline OP
Kura  Offline OP
Pa
Hello,
Ford recommends Motorcraft 5w20 synthetic blend for my 2016 Ford Explorer. I have used nothing but this since I've owned it, however my local Ford dealership is out of stock and Walmart is also out of stock and I was told they are no longer going to stock it. I can wait for the Ford dealership to get their shipment in, but I'd like to know what I can use in case the MC 5w20 synth blend is not available.
I did some searching, and I am more confused than I should be. My questions:
1) can I use ANY 5w20 synth blend? Walmart did have Quaker State 5w20 synth blend, but I was not sure if "synthetic blend" means the same thing for each brand of oil.
2) can I use a full synthetic 5w20, and go back to a 5w20 synth blend, or once I switch to full synth, I have to stay with full synth?
3) can I use any brand of 5w20 full synthetic?
4) are there any charts that indicate which oils are interchangeable with MC 5w20 synth blend? I want to maintain my warranty, so I am not interested in using something that doesn't meet the specs.
5) is AC/Delco oil a legitimate substitute for MC oil?
6) I did a Google search on the oil specs from the owners manual, and one of the "equivalent" oils was a Quaker State conventional oil. Not even blended. That didn't make sense to me, which is why I am here.
Thanks for any help.
Re: Motorcraft 5w20 synthetic blend substitutes [Re: Kura] #4779987
06/07/18 08:53 AM
06/07/18 08:53 AM
USA
slacktide_bitog Offline
USA
welcome
Any 5w20 or even 0w20 synthetic blend or full synthetic can be used with no problems smile
Re: Motorcraft 5w20 synthetic blend substitutes [Re: Kura] #4779989
06/07/18 08:59 AM
06/07/18 08:59 AM
NY
mx5miata Offline
mx5miata  Offline
NY
Oh yeah any 5w20 synthetic or blend will do.
NAPA FULL SYNTHETIC 0w20 Partsplus oil filter
Wix air filter
Re: Motorcraft 5w20 synthetic blend substitutes [Re: Kura] #4780000
06/07/18 09:21 AM
06/07/18 09:21 AM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
Any 5w20 synthetic will be fine
2010 Ford Escape 2.5 ~92K Miles: RP 5W-30, AMSOIL SS FE ATF.
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30, AMSOIL OE MV ATF.
AMSOIL in EVERYTHING!
Re: Motorcraft 5w20 synthetic blend substitutes [Re: Kura] #4780003
06/07/18 09:23 AM
06/07/18 09:23 AM
Outer Banks, NC
NormanBuntz Offline
NormanBuntz  Offline
Outer Banks, NC
I'd use the Quaker State blend listed in your #1 point. By industry standards, a synthetic blend motor oil must have a minimum of 10% synthetic base. This may be the wrong terminology, so others may split hairs with this point.
If you feel you must stick with Motorcraft and can't find it, try the Phillips 66 family of oils: Phillips 66, Kendall, Conoco and 76 Super. They are nearly identical to the Motorcraft formula. There should be a distributor near you.
2017 Honda Odyssey SE, 17K
2013 Honda Accord LX, 58K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: Motorcraft 5w20 synthetic blend substitutes [Re: Kura] #4780014
06/07/18 09:36 AM
06/07/18 09:36 AM
New York
pbm Offline
pbm  Offline
New York
To answer your specific questions:
1) Yes...all 5w20 contain a certain amount of GrIII and could be called semi-syn.
2) Yes...you can use full syn. and switch back and forth as you please
3) Yes...if it meets the Ford spec. WSS-M2C945-A....which virtually all do
4) No...I doubt there are 'charts' but if the oil meets the Ford spec. mentioned in #3, it's interchangeable...
5) Yes...but it probably wasn't tested for the Ford spec.
6) see # 1 and # 3....
I would just use whatever name brand 5w20 that's cheapest or even ST syn. 5w20 and change it every 5 or 6K or 6 months.....you could probably go by the OLM, especially if using a synthetic.
'Journalism is Dead'
Re: Motorcraft 5w20 synthetic blend substitutes [Re: Kura] #4780023
06/07/18 09:51 AM
06/07/18 09:51 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Buy an equal amount of synthetic and conventional oils - then blend your own concoction 50-50.
Any brand will do..... Pennzoil, QS, Valvoline (for example)...... even Supertech.
Synblends are a wallet rip-off.... just about all of them offering only 10-25% synthetic in that synblend jug.
2019 Hyundai Santa Fe 2.4 factory fill and OEM filter
2004 Chevrolet Colorado 3.5 QS / Valvo syn 5w30/20 blend K&N filter
2003 Chevrolet Malibu 3.1 QS / Valvo Syn 5w30/20 blend Fram EG filter
Re: Motorcraft 5w20 synthetic blend substitutes [Re: Kura] #4780029
06/07/18 09:59 AM
06/07/18 09:59 AM
Raleigh ,NC CSA
rshaw125 Offline
rshaw125  Offline
Raleigh ,NC CSA
Go back to Walmart buy Mobil 1. $22 currently. 5W20 or 0W20. A Motorcraft filter. Job done.
2012 Porsche Carrera S
2016 Ford Edge 2.0
2002 Taurus Vulcan SOLD
2006 Explorer SOLD
Re: Motorcraft 5w20 synthetic blend substitutes [Re: Kura] #4780038
06/07/18 10:20 AM
06/07/18 10:20 AM
Ohio
hallstevenson Offline
Ohio
Had a debate here with someone about the spec for the oil for our '14 Fusion and my research indicates that the "MCC xxx245" (don't remember it exactly right now) is NOT a synthetic nor even a synthetic blend. Conventional oils ARE ABLE to meet this particular spec. Sounds like the case for your truck as well.
Re: Motorcraft 5w20 synthetic blend substitutes [Re: Kura] #4780050
06/07/18 10:38 AM
06/07/18 10:38 AM
ROCHESTER, NY
Char Baby Online content
Char Baby  Online Content
ROCHESTER, NY
You'll be getting an education on oil(s) as well as other lubricants now that you've become a member.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Motorcraft 5w20 synthetic blend substitutes [Re: rshaw125] #4780053
06/07/18 10:45 AM
06/07/18 10:45 AM
Michigan
Greggy_D Offline
Greggy_D  Offline
Michigan
Right here.
Greggy D.
Re: Motorcraft 5w20 synthetic blend substitutes [Re: Kura] #4780057
06/07/18 10:48 AM
06/07/18 10:48 AM
PimTac Offline
PimTac  Offline
You can run any brand of synthetic blend or full synthetic that meets Ford’s specs in that vehicle with no worries.
Cannot see signatures any longer so it doesn’t matter.
Re: Motorcraft 5w20 synthetic blend substitutes [Re: Kura] #4780064
06/07/18 11:01 AM
06/07/18 11:01 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
I use nothing but M1 0-20 in my last three Ford engines for the last 10 years at 10K OCI.
2007 Ford Fusion 236,000 miles
M1 0-20 EP
2017 Ford Fusion 62K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Motorcraft 5w20 synthetic blend substitutes [Re: Kura] #4780104
06/07/18 11:47 AM
06/07/18 11:47 AM
Midwest
volk06 Offline
volk06  Offline
Midwest
You can use any motor oil that meets the motorcraft spec. It does NOT have to be a synthetic blend. Ford only RECOMMENDS and does not REQUIRE a synthetic blend or even full synthetic for this vehicle. The only reason motorcraft has been a synblend for so long is because Phillips 66 blends the oil in the US. In Canada for example, exxon makes motorcraft and it was a "conventional" while in the USA it was a syn-blend. They source motorcraft from a blend to manufacture and bottle it for them.
95% of all readily available name brand and major store brand conventional, syn-blends and full synthetic meet the ford spec.
Super tech at walmart even meets the ford specs.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
Re: Motorcraft 5w20 synthetic blend substitutes [Re: volk06] #4780141
06/07/18 12:20 PM
06/07/18 12:20 PM
Ohio
Ohio
That explains why the owner's manual I found for a Mustang differentiated between the oil 'type' and US vs Canada, while BOTH a blend and a conventional met their spec.
