Valvoline Premium Blue 8600 ES 15W40
by 53' Stude - 09/21/19 01:20 PM
Axle shaft seal leak?
by aquariuscsm - 09/21/19 01:14 PM
Refills for Denso Designer wipers
by mclasser - 09/21/19 12:45 PM
What make steering wheel hard to turn
by Rohan - 09/21/19 12:43 PM
Z55 coil spring options
by LeakySeals - 09/21/19 12:28 PM
diy AA Solar charger?
by earlyre - 09/21/19 11:53 AM
Would you worry about this tire for 6K miles?
by MoneyJohn - 09/21/19 11:34 AM
TCW3 fuel mix
by otis24 - 09/21/19 10:44 AM
FRAM XG4967 C&P ~18,000 kms
by mcwilly - 09/21/19 10:16 AM
Any reason not to use high mileage formula oil?
by jimbrewer - 09/21/19 10:03 AM
Holley carb only works on cold engine
by liberty - 09/21/19 10:01 AM
turbo cool down
by mobilaltima - 09/21/19 09:04 AM
10K Mile Oil Change - 1.8L TSI Jetta
by SandCastle - 09/21/19 08:08 AM
Pennzoil Platinum 10w30 HTHS
by donnyj08 - 09/21/19 07:56 AM
Mortality stats
by CourierDriver - 09/21/19 07:38 AM
Is it time for a brake fluid flush?
by A_A_G - 09/21/19 03:22 AM
Take that!
by Mad_Hatter - 09/21/19 03:18 AM
02 Honda Accord V6 Aluminum Radiator
by David1 - 09/21/19 01:55 AM
Difinitive Answer for SCA, Silicates, and Diesels
by ErikLeifson - 09/20/19 11:11 PM
Quart bottle cap
by maverickfhs - 09/20/19 11:11 PM
OilReport99, TungGT, ErikLeifson, Kinnes25, Bamajoe
69348 Registered Users
78 registered members (ammolab, 69GTX, 64bawagon, 10 invisible), 2,436 guests, and 36 spiders.
Topics294,863
Posts5,068,240
Members69,348
Most Online3,532
Jul 30th, 2019
Got a Residential HVAC Estimate - Not Bad #4768480 05/26/18 07:06 AM
L
LoneRanger Offline OP
L
Old system:
2004 model year Rheem 3.5 ton A/C unk SEER (likely 12 or 13) & gas furnace 80% AFUE
Proposed new system:
Amana 3.5 ton single stage A/C 16 SEER & gas furnace 96% AFUE. Lifetime warranty heat exchanger, compressor (Copeland scroll), and condensor coil, 10 yrs on evap coil and all else. $5890 after utility company rebate and $500 federal 1040 income credit. Includes running new refrigerant lines and two new thermostats one for upstairs zone one for downstairs. Also includes running new flue since the high efficiency gas furnaces apparently use a PVC flue on account of condensate build-up (flue temp does not exceed 120 F). He offered two different dual stage (A/C) systems for more money but since selling the house soon I'm not inclined to install a bells and whistles system.
I have requested an estimate from local Trane contractor but no one is calling me back since Tuesday (It's now Saturday).
2019 Ford F-150 ................................(Factory fill)
2019 GMC Terrain .............................(ACDelco dexos2)
2016 Moto Guzzi Stelvio <for sale>...(eni 10W60)
Re: Got a Residential HVAC Estimate - Not Bad [Re: LoneRanger] #4768487 05/26/18 07:18 AM
CourierDriver Offline
As a former installer in HVAC and salesperson, you got a real good deal....
800,000 folks die each year from congestive heart failure..
If guns are dangerous, then pencils cause bad grades..
Re: Got a Residential HVAC Estimate - Not Bad [Re: LoneRanger] #4768491 05/26/18 07:25 AM
Char Baby Offline
I have our furnace(98%)replaced and added AC in 2011 and paid similar to your price, $5200 after all rebates. We went with RUDD(off brand of Rheem) along with AprilAire. We had never has AC so, it had to be installed from scratch.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Got a Residential HVAC Estimate - Not Bad [Re: LoneRanger] #4768540 05/26/18 08:18 AM
M
motor_oil_madman Offline
M
Rheem seems to be pretty good other than eating capacitors at a rate of about 1 per year. I think that's probably an issue with the installer using cheap capacitors.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Got a Residential HVAC Estimate - Not Bad [Re: LoneRanger] #4768542 05/26/18 08:19 AM
M
M
It actually got real bad where they would come out once every 6 months or so. Never cost us anything.
Re: Got a Residential HVAC Estimate - Not Bad [Re: LoneRanger] #4768545 05/26/18 08:23 AM
A
Audios Offline
A
Interesting, I was worried about our system, its an old York I believe from 1995, it was 92 yesterday and the house held at 74, but that was about it. We are looking to move in a year or so, so Im a little undecided on whether to try a recharge and clean the evaporator or maybe its time for a replacement. $6k is really not bad, I was expecting worse, plus we are in a small ranch so Im expecting that unit would be a little overkill.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Got a Residential HVAC Estimate - Not Bad [Re: LoneRanger] #4768627 05/26/18 10:39 AM
L
L
Yeah it's not bad. Technically it's $6390 up front but next year when filing Federal 1040 you qualify for a $500 tax credit from IRS. Sort of like an extra rebate that takes a year to get.
Re: Got a Residential HVAC Estimate - Not Bad [Re: LoneRanger] #4768733 05/26/18 12:39 PM
Zee09 Offline
If they install it right, great deal!!!!
"If I walked on water, they'd say I couldn't swim."
Re: Got a Residential HVAC Estimate - Not Bad [Re: LoneRanger] #4768797 05/26/18 02:54 PM
P
pbm Offline
P
That sounds like a very good deal.
I think 10 SEER was the standard in 2004 so you should see a nice savings in energy usage too....Good Luck.
'Journalism is Dead'
Re: Got a Residential HVAC Estimate - Not Bad [Re: LoneRanger] #4769042 05/26/18 08:42 PM
T
thooks Offline
T
Donít buy a 3-1/2 ton. Get a 4. A 3-1/2 is not available in 2-stage cooking and itís just a [censored] 3 ton system. All brands.
Re: Got a Residential HVAC Estimate - Not Bad [Re: LoneRanger] #4769044 05/26/18 08:45 PM
dishdude Offline
Sounds about right, I paid $5300 for a 4 ton single stage 3 piece system a little over 3 years ago. I think it's a 14 SEER 80% system.
I'm surprised you're replacing a 14 year old system.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan
Re: Got a Residential HVAC Estimate - Not Bad [Re: LoneRanger] #4769233 05/27/18 07:44 AM
G
greenjp Offline
G
Is the furnace multi-stage or modulating?
How does he propose to do the zoning with a single stage AC (and maybe single stage heat)?
Disagree on remark above to go with 4 ton - if anything too big is worse than too small.
jeff
Re: Got a Residential HVAC Estimate - Not Bad [Re: greenjp] #4779139 06/06/18 01:32 PM
B
brianl703 Offline
B
My house has a zoned system with a single stage AC/heat pump.
The air handler has an ECM motor that delivers constant CFM no matter if one zone is calling or both are calling.
This does mean that if only one zone is calling, the airflow from the registers is higher than if both are calling.
That doesn't bother me. I think it works fine.
Re: Got a Residential HVAC Estimate - Not Bad [Re: LoneRanger] #4779814 06/07/18 06:30 AM
L
L
The zone system that was installed with the original hvac when the house was built in 2005 is just an electric actuated damper thing that has three positions or something-- when both zones are on at once there's low air flow from all registers, upstairs only gets high flow upstairs, downstairs only gets high flow downstairs.
Like I just mentioned, if both thermostats are calling for heat or cooling and the damper is letting flow go to both levels of the house the registers don't blow very hard. What's remarkable is the home was built by one of the area's supposedly "premium" home builders with this rep of building quality stuff. But he put in a budget-asss system as far as I can tell.
I would note also that the crawl space has no foundation vents installed. Instead it has two registers on a supply plenum that runs in the crawl space. Builder said this is the way they do it now (then, in 2005) it's called "a conditioned crawl space." But there are no returns in the crawl space that I could find. Again, this is a so called premium builder who constantly thumps their chest about building to the highest standards. When going through the home on the "30 day punch list" after purchase in 2006, I noted to the builder that the copper tubing for the hot water heater blow off valve just stops above the untreated plywood floor of the cove in garage where hvac and water heater sit, and that any blow off water would flood out onto the untreated wood. His response? "County building code says all we have to do install a blow off pipe to bottom of the water heater." I'd suggested drilling a hole through the plywood and routing it into main drain pipe in crawl space or just letting it blow off in crawl space instead of all over the untreated plywood floor. Strange response from a builder that proclaims to build to the highest standards... sounds like they build to the minimum standard, which is what local building codes are-- the minimum standard.
