Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
Ollie_B_2000, akarip, BJD2020, ToyTaco2002, EarlT500
70802 Registered Users
77 registered members (bismic1, AurionX2, BoiseRob, aquariuscsm, BIGJ552000, 9 invisible), 1,564 guests, and 15 spiders.
Topics301,934
Posts5,205,827
Members70,802
Page 1 of 3 1 2 3
LSPI and Euro engines, any low-Ca high-Mg C3 oils? #4779719 06/06/18 10:02 PM
1
1JZ_E46 Offline OP
1
Are European GDI and TGDI engines somehow immune from LSPI? Or do they have ways of addressing beyond changing the oil formulation? Just about every Euro specíd oil Iíve seen (including, LL-01, LL-04, 229.5, 229.51, A40, C30, etc.) are high Ca (2,000-2,400 for A3/B4 and around 1,600 for C3) with essentially no Mg. Even the more recent specs donít seem concerned with calcium doses. It makes me wonder how much changing the calcium content really can impact LSPI. Thoughts? Ever seen a low-Ca C3 oil?
2019 Tesla Model 3 SR+
2016 Countryman S: Castrol 0W-40
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: 1JZ_E46] #4779772 06/07/18 02:24 AM
Z
zeng Offline
Z
C3's I come across are high Ca with minimal Mg.
LSPI as high Ca related in oil is American (marketing) way of sorting out a non-issue in (Euro) LSPI, IMHO.
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: 1JZ_E46] #4779776 06/07/18 03:00 AM
wemay Offline
Well, Hyundai still publish 5W-40 as a recommended option for the 2.0T and i have that jug on deck for it's next oci. But there have been too many industry papers coming to the same conclusion to think that Calcium and Sodium don't contribute to the issue i.e., from SAE Papers, Chevron Ornite, Lubrizol etc. I guess time will tell. Maybe the exclusion of Na is a simpler, cheaper solution to the issue than introducing the add package found in Euro specc'd oils, just a guess.
19 VW Passat Wolfsburg TSI (VW Genuine 0W-20+OEM)
13 Hyundai Santa Fe Sport 2.0T (Shell RGT 5W-30+OEM)
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: zeng] #4779937 06/07/18 07:50 AM
N
nap Offline
N
I believe the Europeans don't have CAFE and thus don't have much incentives to push the engines regime into LSPI.
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: 1JZ_E46] #4779949 06/07/18 07:55 AM
B
Bjornviken Offline
B
Havent heard of any LSPI related issues here in EU. Think its only concerns the ilsac oils line up.
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: 1JZ_E46] #4779966 06/07/18 08:19 AM
W
Whimsey Offline
W
The European spec oils usually have much higher levels of Zinc & Phosphorus which helps to offset the LSPI caused by higher calcium, so I read. US spec oils have lower levels of Zinc and Phosphorus to help with cat poisoning and those doesn't offset calcium's effect with LSPI.
Whimsey
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: nap] #4779968 06/07/18 08:21 AM
Z
zeng Offline
Z
Points taken, thumbsup
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: Whimsey] #4780024 06/07/18 09:53 AM
wemay Offline
Whimsey
This^
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: Whimsey] #4780035 06/07/18 10:17 AM
1
1JZ_E46 Offline OP
1
Whimsey
ACEA C3 oils (specs like LL-04, 229.51, C30) have zinc and phosphorous levels about equal to today's SN/GF-5 oils, and they all have no magnesium and most have no moly.
I think part of the reason LSPI doesn't seem to be a concern for euro manufacturers (at least from an oil formulation standpoint) is that they specify premium fuel for their engines, resulting in less soot (a contributor to LSPI).
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: nap] #4780036 06/07/18 10:18 AM
1
1JZ_E46 Offline OP
1
If they are selling their cars here, they have CAFE.
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: 1JZ_E46] #4780041 06/07/18 10:23 AM
Z
zeng Offline
Z
.... but Euro OEM's doesn't recommend RC GF5 oils in CAFEland , do they?
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: zeng] #4780059 06/07/18 10:54 AM
1
1JZ_E46 Offline OP
1
Well, no, but they are still squeezing out every last drop of fuel economy from the engines via engineering and tuning (for CAFE requirements)... which is the cause of LSPI in the first place. Oil is only one very small lever to pull in the quest for MPGs.
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: 1JZ_E46] #4780147 06/07/18 12:26 PM
drtyler Offline
I can't speak for other cars & engines, but the VW EA888 engine in Europe has an extra injector in the intake to squirt a bit of gas down to the valves and the fuel mapping in the ECU is programmed differently (presumably for Euro emission requirements rather than USA & Canada). I realize this affects intake valve buildup rather than LSPI specifically.
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: nap] #4780793 06/07/18 10:41 PM
E
edyvw Offline
E
Nope, they have limits of grams of CO2 per 100km and $6 gallon of gas.
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: LSPI and Euro engines, any low-Ca high-Mg C3 oils? [Re: drtyler] #4780794 06/07/18 10:43 PM
E
edyvw Offline
E
Injector issue is due to cost. Cars in US are cheaper and more affordable.
Also yes, EU engines have more lean burn which produces more NOx which has higher limits in EU.
Page 1 of 3 1 2 3
