Had a minor run in with a curb at slow speed (5 MPH) - simply took the corner too sharp and put a 1 inch rough spot on the side of the rim where it meets the tire then below that a 1 inch blemish / scrape on one of the alloy wheel spokes . *It's hard to notice unless you are looking but irritates me to no end because otherwise the car was flawless ... Local wheel guy wants $180 to redo the whole wheel good as new which is a bit steep . I was thinking more of 800 to 1000 grit sand paper over a small pliable rubber hose to carefully sand the rough spot on the curved part of the top rim (again a 1" spot) then try something like Flitz metal polish , car paint polishing compound to see if I can remove the blemish / scrape on the alloy wheel spoke (1 " spot) . Your thoughts and suggestions ?
