98 registered members (2015_PSD, andyd, Aero540T, AandPDan, 2009Edge, 11 invisible),
1,620
guests, and 58
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics284,685
Posts4,875,001
Members67,313
Most Online2,548 Feb 16th, 2019
First major issue with 2014 Jetta...
#4779640
06/06/18 08:14 PM
06/06/18 08:14 PM
Posts: 5,987 FL, USA
gregk24
OP
OP
FL, USA
We dropped of our 2014 Volkswagen Jetta at the VW last night for its 40K mile service today. It was purchased with a maintenance plan brand new so service items for the 40K mile service include transmission fluid and filter change, oil and filter change, new wiper blades, new air filters *I think, and from what the dealership told us, new spark plugs.
Two things I wanted them to check into in addition to the preventative maintenance were harsh shifts at times when going from reverse to drive (it's an auto), hard shifts (at times) when coming to a stop, and to top off the coolant reservoir. It has been low 3 times over the life of the car, but this time I told them to check for leaks. They have in the past, but said they didn't see any.
We got a call today saying they would need to have the car another day due to water pump failure! I am glad it was caught before the warranty ran out, but a little disappointed that it failed so soon. They said it would be a four hour job, I am not sure where the water pump is located so this may be the case.
Other than this issue, and sticky ignition cylinders it has been a rock solid car thus far. Just wanted to share with the BITOG crowd. Oh, and as for the clunky / harsh shifting they said they didn't find anything wrong. So maybe a new fluid and filter is what was needed to smooth things out.
2012 Honda Accord EX-L K24z3 56,xxx miles PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888 44,xxx miles Castrol OEM dealer fill / OEM filter
Re: First major issue with 2014 Jetta...
[Re: gregk24]
#4779642
06/06/18 08:18 PM
06/06/18 08:18 PM
Posts: 12,115 Middlesex County CT
simple_gifts
Middlesex County CT
Make sure they replace the WP with OEM, and you'll be g2g to 80K. j/k.
Thanks for the update.
2004 Prius; 102K; ASL 2007 Yaris 78K 0w-40 Castrol 2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
[Re: gregk24]
#4779648
06/06/18 08:28 PM
06/06/18 08:28 PM
PimTac
Does this have a DCT for a transmission?
Cannot see signatures any longer so it doesn’t matter.
[Re: PimTac]
#4779652
06/06/18 08:37 PM
06/06/18 08:37 PM
gregk24
OP
OP
FL, USA
Does this have a DCT for a transmission? No it has the 6 speed AISIN unit.
[Re: gregk24]
#4779656
06/06/18 08:43 PM
06/06/18 08:43 PM
Posts: 17,390 Michigan
daves87rs
Michigan
Glad they caught it first...
2019 Chevrolet Equinox LS 2006 Chevrolet Cobalt LS
[Re: gregk24]
#4779658
06/06/18 08:46 PM
06/06/18 08:46 PM
PimTac
Does this have a DCT for a transmission? No it has the 6 speed AISIN unit. Thanks for clarifying. It’s surprising the techs haven’t sensed the same issue.
[Re: gregk24]
#4779661
06/06/18 08:49 PM
06/06/18 08:49 PM
Posts: 5,493 In the Garage...
ls1mike
In the Garage...
At those miles it should be rock solid. Not a big deal to do the WP but why is that people on here are like "35,000, 45,000, 50,000 it is rock solid" A car should be with those miles.
Mike 00 Trans Am WS6 5.7 LS1 02 Silverado 2500HD 6.0 14 Caprice PPV 6.0 15 Malibu LTZ Turbo 12 Passport TT
[Re: gregk24]
#4779670
06/06/18 09:07 PM
06/06/18 09:07 PM
Posts: 13,070 Canyon County Idaho
CT8
Canyon County Idaho
I had a 92 Toyota V6 pickup that needed a water pump at 15,000 miles. My dads Toyota p/u didn't need ant thing except Shocks, tires and brakes as well as tune ups for 20 years.Stuff happens . Nothing happening is best but it is not always so.
2015 Ford F150 2.7 2018 Ford F350 6.2
[Re: ls1mike]
#4779685
06/06/18 09:22 PM
06/06/18 09:22 PM
Posts: 762 MN
14Accent
MN
At those miles it should be rock solid. Not a big deal to do the WP but why is that people on here are like "35,000, 45,000, 50,000 it is rock solid" A car should be with those miles. Ever done the water pump on an EA engine? It's not fun... it takes all of 4 hours and I promise the dealer tech stuck doing it is salty about it. They're a total pain.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
[Re: gregk24]
#4779746
06/06/18 10:53 PM
06/06/18 10:53 PM
Posts: 163 Rainville, USA
JEL01
Rainville, USA
Yep also had a 2006 Toyota 4.0 water pump go belly up around 35k miles, replaced under warranty. It happens on such mass produced machines, glad they nailed it down early on VW’s dime
Cars I maintain: 02 MB CLK430-Edge 0w40 05 Honda Accord V6-Maxlife 5w30 13 Lexus RX350 AWD-M1 AFE 0w20 02 Toyota Tundra 4x4 M1 5w30
[Re: gregk24]
#4779782
06/07/18 03:47 AM
06/07/18 03:47 AM
Posts: 10,850 Indiana
dlundblad
Indiana
Hopefully they use OE and the new pump lasts the next 125k+ or so.
Does VW recommend the WP and timing belt be changed together?
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16 02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D 97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
[Re: CKN]
#4779783
06/07/18 03:48 AM
06/07/18 03:48 AM
dlundblad
Indiana
With all the parts manufactured-there is a "fail rate" on new parts.
So some parts will fail prematurely-it happens. Sure does. My mom's old Tahoe had a water pump failure when it was only a few years old.
[Re: gregk24]
#4779791
06/07/18 04:18 AM
06/07/18 04:18 AM
Posts: 1,414 South Central PA (Fulton Co)
Delta
Hmm, so VW still can't get water pumps right. I do think this was an issue on earlier EA888's though, so we'll see how long mine last. At the current rate it'll be a while  Edit: dlundblad, VW has gone away with the belt and went to chains on these motors.
'17 VW GTI 2.0T - 6MT - 13K - PPE 5w40 '15 Camry SE - 2.5 - 21K - PP 0w20 '99 S10 - 2.2 5MT - 157K - PP 10w30
