2012 Ford 3.0 V6 Kendall GT-1 5W-20 6488 mi
by AITG. 07/20/19 04:37 PM
Replaced All Signaling Bulbs At One Time
by RayCJ. 07/20/19 04:21 PM
Cheryl's New She Shed
by MolaKule. 07/20/19 04:16 PM
Thread sealant for bolts holding diff cover.
by Snagglefoot. 07/20/19 03:30 PM
Meguiars Hybrid Ceramic
by rdevans89. 07/20/19 03:02 PM
2015 Mitsubishi Outlander GT trans. filter
by Kira. 07/20/19 03:02 PM
Could microglass/synthetic media filters harm engines?
by Deontologist. 07/20/19 01:47 PM
A/C problems 2016 Nissan Quest.
by JTK. 07/20/19 01:37 PM
change once a year regimen
by alex_at. 07/20/19 01:34 PM
What would you like to do in the future?
by Red91. 07/20/19 12:45 PM
Pulling timing for high IAT
by LAGA. 07/20/19 11:55 AM
I think I messed up. How badly?
by JohnG. 07/20/19 11:19 AM
[Cut Open] Volkswagen 04E 115 561 H (Virgin)
by DuckRyder. 07/20/19 10:51 AM
PARTS PLUS PH 500 CUT OPEN
by 53' Stude. 07/20/19 10:32 AM
MOBIL 1 M1-108A CUT OPEN
by 53' Stude. 07/20/19 10:25 AM
Mac Pro -- Keep Killing Keyboards
by ET16. 07/20/19 10:23 AM
Air filters with foam facing?
by Dave1027. 07/20/19 09:31 AM
Run em or replace
by faltic. 07/20/19 08:49 AM
Roadtripp, Denali376, GoldDot40, Dtn2, Bonebender
68717 Registered Users
115 registered members (01rangerxl, 53' Stude, 2015_PSD, 77GrandPrix, 97K15004WD, 4WD, 10 invisible), 2,287 guests, and 30 spiders.
Topics292,153
Posts5,017,716
Members68,717
Most Online2,967
Mar 10th, 2019
2018 Accord 2.0T Touring Factory Fill #4779445
06/06/18 06:27 PM
06/06/18 06:27 PM
Oklahoma
Brolly Offline OP
Brolly  Offline OP
Oklahoma
Filled back up Castrol Edge Extended 0w-20 Honda filter
1999 Toyota Camry CE 2.2L
PPHM or PP or PPU
5w-30
226,344
10spd
0w-20 Castrol Edge Honda Filter
Re: 2018 Accord 2.0T Touring Factory Fill [Re: Brolly] #4779452
06/06/18 06:35 PM
06/06/18 06:35 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
Holy moly batman.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: 2018 Accord 2.0T Touring Factory Fill [Re: ARB1977] #4779461
06/06/18 06:42 PM
06/06/18 06:42 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
Originally Posted By: ARB1977
Holy moly batman.
All down the drain, now.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: 2018 Accord 2.0T Touring Factory Fill [Re: ARB1977] #4779490
06/06/18 07:15 PM
06/06/18 07:15 PM
Danh Offline
Danh  Offline
Holy moly batman.
Typical Honda factory fill. Molybdenum is presumably from assembly lubes.
UOA looks good, but viscosity suggests considerable fuel dilution despite Blackstone’s assertion to the contrary.
Re: 2018 Accord 2.0T Touring Factory Fill [Re: Brolly] #4779492
06/06/18 07:16 PM
06/06/18 07:16 PM
MN
oil_film_movies Offline
MN
Probably should have high moly in your Honda for a few thousand miles more. Castrol Edge doesn't have the high moly.
mightymousetech, a Honda technician, last year said "I am a dealer tech (20 years with Acura/Honda) every couple years we get another service bulletin from Engineering stating that doing the first oil change early can damage the engine, and we are NOT to change the factory fill early. The factory fill oil is not the issue, it is the high moly assembly lube used they want retained in the oil. Doing the first oil change early can cause hot spots to form in the engine."
So if the issue is go with high moly in Honda new engines for a few thousand miles, then go with Zepro 0w20.
https://www.bobistheoilguy.com/forums/ub...lis#Post4768630
or go and get Mazda dealership "Mazda Genuine Motor Oil" which is the same stuff really.
(Note: There are 2 varieties of Zepro 0w20, and both have "high" moly, its just that one has insanely high moly, so either will work fine here.)
If you don't want to go thru the hassle of changing your Castrol out (understandable), then just put in a half-bottle of LiquiMoly Ceratec (napa autoparts; amazon), and that will raise the moly level safely.
Re: 2018 Accord 2.0T Touring Factory Fill [Re: Brolly] #4779500
06/06/18 07:20 PM
06/06/18 07:20 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
Do you think that it might have been a good idea to have left this high moly brew in for maybe double the miles, as Honda used to recommend in the earlier Accords?
Fuel dilution looks to be negligible, which means that it'll be 3X negligible on a normal 15% MM IOLM change.
Maybe the whole fuel dilution thing has been more hype than reality?
Anyway, this FF UOA looks good.
How do you like the car overall?
Have you owned earlier generation Accords?
I ask because we've had a number of them over a few generations and my Gen 8 is less satisfactory in ride compliance, handling and tracking than previous generation Accords we've had.
18 Accord Hybrid 10K HGMO 0W-20
17 Forester 24K VME 0W-20
12 Accord LX 115K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: 2018 Accord 2.0T Touring Factory Fill [Re: Brolly] #4779504
06/06/18 07:23 PM
06/06/18 07:23 PM
New York Queens
Ram02 Offline
Ram02  Offline
New York Queens
3k should be enough for the moly to settle in the engine . You should be fine
2013 Malibu 2LT M1 5w30
2013 Accord Sport M1 AP 0w20
Re: 2018 Accord 2.0T Touring Factory Fill [Re: oil_film_movies] #4779560
06/06/18 08:09 PM
06/06/18 08:09 PM
Oklahoma
Brolly Offline OP
Brolly  Offline OP
Oklahoma
Thanks for the info! I probably will add some in till I get to the next change.
PPHM or PP or PPU
5w-30
226,344
10spd
Re: 2018 Accord 2.0T Touring Factory Fill [Re: oil_film_movies] #4779563
06/06/18 08:10 PM
06/06/18 08:10 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
+1
Re: 2018 Accord 2.0T Touring Factory Fill [Re: fdcg27] #4779579
06/06/18 08:26 PM
06/06/18 08:26 PM
Oklahoma
Brolly Offline OP
Brolly  Offline OP
Oklahoma
Probably would have been a good idea to keep the high moly in will look to possibly add some moly in.
I had a 2008 Accord Ex 2.4 that I bought brand new. Quality is a huge step up with this 10th Gen. the 2008 Brakes were a problem with in the first 5k the pads where shot. They replaced 2-3 times I believe. Heard that the pads were made incorrectly. I got tired of dealing with it so I put some NAPA Ceramic pads and new rotors. Cured the problem. Then there was a front suspension issue that took 6 months worth of time in the shop to figure it out over 2yrs. Also had a oil leak that showed up forgot where it was but that was fixed. Before I gave it to my BIL I had Pirelli CINTURATO P7™ ALL SEASON PLUS which made the ride sooo much better. I still love the car and it will come back to me after he is done with it. I do like this one it’s a different ride and interior are much nicer in this one. The transmission is smooth the cabin is quiet. Infotainment is very well done. Sure there have been a couple resets on the infotainment but that does doesn’t bother me.
PPHM or PP or PPU
5w-30
226,344
10spd
Re: 2018 Accord 2.0T Touring Factory Fill [Re: fdcg27] #4779586
06/06/18 08:29 PM
06/06/18 08:29 PM
Danh Offline
Danh  Offline
6.28 cSt @ 100C and you believe fuel dilution is negligible? This is Blackstone. Had an almost identical Blackstone report a few years ago; subsequent OAI UOA had very similar viscosity but fuel dilution > 5%.
Re: 2018 Accord 2.0T Touring Factory Fill [Re: Brolly] #4779593
06/06/18 08:33 PM
06/06/18 08:33 PM
Oklahoma
Brolly Offline OP
Brolly  Offline OP
Oklahoma
I took 2 samples. 1 went to Blackstone and now I need to send the other somewhere else. Napa maybe?
PPHM or PP or PPU
5w-30
226,344
10spd
Re: 2018 Accord 2.0T Touring Factory Fill [Re: Brolly] #4779596
06/06/18 08:35 PM
06/06/18 08:35 PM
PimTac Offline
PimTac  Offline
Does Ceratec contain moly? I thought it didn’t. LM does make a moly additive.
There will be residual moly in the engine to add to the new oil so no need to worry.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: 2018 Accord 2.0T Touring Factory Fill [Re: Brolly] #4779602
06/06/18 08:42 PM
06/06/18 08:42 PM
Danh Offline
Danh  Offline
I’d try Polaris/Oil Analyzers, Inc. They use gas chromotography to determine fuel dilution and are really nice folks to deal with. If you get a second UOA please post it as well.
Re: 2018 Accord 2.0T Touring Factory Fill [Re: Brolly] #4779759
06/07/18 12:30 AM
06/07/18 12:30 AM
Yellowbrick Rd(KS)SemiRetired
Marco620 Offline
Marco620  Offline
Couldnt he add a bit of redline 0w20 or Lubegard Biotech to boost the moly?
15' Civic 1.8 i-vtec 254,000 mi Redline 5/0w20, BP transmax cvt fluid & Archoil9100
Tornado Chaser Extraordinar!
Son of a Navy Corpsman. Support vets!
