EP Auto?
by HowAboutThis. 06/19/19 11:13 PM
Rear Wheel Bearing Replacement?
by Gebo. 06/19/19 10:37 PM
Coolant in Oil?
by Score294. 06/19/19 10:34 PM
The cool people of Bitog
by Marco620. 06/19/19 08:52 PM
How do Adjust Your Seat and Mirrors
by buster. 06/19/19 08:37 PM
AC for hybrid and electric vehicles
by JimPghPA. 06/19/19 08:06 PM
Mobil 1 sold at Walmart vs Summit Racing
by kosoku. 06/19/19 08:02 PM
Troy Bilt TB200
by Floyd1. 06/19/19 07:54 PM
Cutting vinyl planking, Do I need a snapper?
by JLawrence08648. 06/19/19 07:13 PM
1969 Honda N600, Serial #1...
by mattwithcats. 06/19/19 06:02 PM
My Son Turned Me On to a New Cooking Show
by NYEngineer. 06/19/19 05:42 PM
Naphthenic Oils
by MolaKule. 06/19/19 05:06 PM
Mopar 5W-20?
by John344. 06/19/19 04:39 PM
Toyota WS UOA and Redline D6 VOA
by Patrick0525. 06/19/19 04:28 PM
2015 4Runner UOA w/ TGMO ALUMINUM
by OCDoiler. 06/19/19 04:17 PM
Evinrude oil
by FastLane. 06/19/19 03:40 PM
engine air filters...all the same?
by flinter. 06/19/19 03:37 PM
DesertTech, Jamie_E_M, Tambo, Robw, taschnewitz
68438 Registered Users
26 registered members (Bailes1992, CleverUserName, E365, 4WD, 4 invisible), 652 guests, and 22 spiders.
Topics290,687
Posts4,990,988
Members68,438
Most Online2,967
Mar 10th, 2019
Opinions on diff fluid change with mityvac? #4777159
06/04/18 11:39 AM
06/04/18 11:39 AM
ca
monster1 Offline OP
monster1  Offline OP
ca
Hey guys, I'm wanting to change my diff gear oil in my 04 2500 5.9l cummins 4x4. Should I completely pull the covers or will using a mityvac suck and swap be ok? Odometer is about 75k. First service.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777181
06/04/18 12:11 PM
06/04/18 12:11 PM
California
nthach Offline
nthach  Offline
California
If you can get the Mityvac to pick up from the bottom of the diff, I think it should work but it could struggle with the thicker gear oil. I would try it with the diff oil warm.
Pulling the diff cover isn't a bad idea if not messy. I would go that way to avoid any drama. If you were planning on swapping diff covers to a Mag-Hytec or similar with a drain plug it's also a good time.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777225
06/04/18 12:43 PM
06/04/18 12:43 PM
Mid Atlantic
229 Offline
229  Offline
Mid Atlantic
Slow but better than not refreshing. Pull the covers so you can wipe out the slime. Use Mopar gear RTV or compatible black gear oil RTV silicone.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777249
06/04/18 01:09 PM
06/04/18 01:09 PM
ca
monster1 Offline OP
monster1  Offline OP
ca
I'll pull the covers. Thanks.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777397
06/04/18 04:06 PM
06/04/18 04:06 PM
ca
monster1 Offline OP
monster1  Offline OP
ca
Pulled the cover to the rear. Gear oil was dark. But no shavings and everything was really clean. Put in 3 quarts of Lucas full synthetic 75w-90 and tightened everything back up. I think the front diff will wait for now since the rear was so clean. Too dang hot for me to be working in the sun.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777405
06/04/18 04:10 PM
06/04/18 04:10 PM
Rainville, USA
JEL01 Offline
JEL01  Offline
Rainville, USA
Good on you for taking care of it,
You are now ahead of 99% of other drivers, BITOGers excluded smile
Cars I maintain:
02 Mercedes CLK430-Edge 0w40
05 Honda Accord V6-Maxlife 5w30
13 Lexus RX350 AWD-M1 AFE 0w20
02 Toyota Tundra 4x4 M1 5w30
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777424
06/04/18 04:27 PM
06/04/18 04:27 PM
midwest
Billy_D Offline
Billy_D  Offline
midwest
I donít bother pulling the cover on my truck. I just use an oil extractor every 40k miles. The process is painfully slow.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777439
06/04/18 04:45 PM
06/04/18 04:45 PM
NY
demarpaint Offline
demarpaint  Offline
NY
If you don't have a drain plug, that's what I'd do. thumbsup
God Bless Our Troops
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4778998
06/06/18 11:13 AM
06/06/18 11:13 AM
ca
monster1 Offline OP
monster1  Offline OP
ca
I towed my 4k lb boat yesterday on a 50 mile round trip. I know this is nothing for a 3/4 ton truck but the lazer thermometer showed the differential running at 150 degrees in 100 degree heat. Looks like that Lucas synthetic gear oil does it's job. I was a bit concerned I made a wring choice if lubricants because it's not a very popular product as far as the internet is concerned.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4779556
06/06/18 08:05 PM
06/06/18 08:05 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
150F diff temperature towing is fantastic for Lucas 75W90 with a high [email protected]*C of 142 cSt.
