106 registered members (379KITTY, 2015_PSD, 2oldtommy, 01rangerxl, 10WSmuckers, 13 invisible),
1,924
guests, and 52
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics284,726
Posts4,875,849
Members67,327
Most Online2,548 Feb 16th, 2019
P0421, CO2 sensor bank 1
#4779514
06/06/18 06:32 PM
06/06/18 06:32 PM
Posts: 636 GA
miden851
OP
OP
GA
HI there
a few moments ago I got the code, so I was wondering which sensor is it; the car has 3 sensors down to the exhaust pipe
Help please!
2008 Mazda6i GT; @214K miles 2016 Honda CR-V EX-L; @39K miles
Re: P0421, CO2 sensor bank 1
[Re: miden851]
#4779520
06/06/18 06:36 PM
06/06/18 06:36 PM
Posts: 9,733 out there
spasm3
out there
How many miles on the upstream 02 sensors. And spark plugs?
13 elantra 75k 5w30 QSUD 03 chevy avalanche 80k synpwr 5w30 17 mazda cx-5 9500 miles m1 0w30
[Re: miden851]
#4779543
06/06/18 06:52 PM
06/06/18 06:52 PM
Posts: 636 GA
miden851
OP
OP
GA
Spark plugs about 15K; oxygen sensors from the factory; however, the 2nd has been replaced, 100K miles ago easily
[Re: miden851]
#4779569
06/06/18 07:17 PM
06/06/18 07:17 PM
spasm3
out there
I tend to replace upstream sensors around the 90k mark. I think they get slow, before throwing a code. Might be worth it to try on yours. But the cat may be degrading.
[Re: miden851]
#4779641
06/06/18 08:17 PM
06/06/18 08:17 PM
Posts: 636 GA
miden851
OP
OP
GA
OK I thank you guys;
I am inclined, it is the one was replaced last time; But I wanted to ask this too, where is it coming from or even better, what is the underlying cause for failing O2 sensor or a catalic converter for example.
I am asking this because recently I have implemented some changes to my car such as using different gas station (Quick Trip) and started using synthetic oil such as Super Tech, currently at 2nd oil change while from the beginning has been used dino only; could this change been related to the code somehow please
[Re: miden851]
#4779645
06/06/18 08:22 PM
06/06/18 08:22 PM
spasm3
out there
O2 sensors just go bad with mileage. Its an electrical sensor jammed in the exhaust stream. I'm amazed that they last as long as they do. Catalytic converters can be damaged by poor maintenace. Misfires send fuel down and the cat burns it, but its not good for the cat. Lean mixtures also make the EGT go up and that can damage a cat as well. The o2 sensors can kill a cat if you drive around with a bad one.
Oil should not have that much effect, unless you are burning a lot of oil, if so high zinc and phosporus oils are not good for the cats of an oil burner.
As long as you are running the correct fuel( don't try e-85 in a non flex fuel etc.), i don't thing brand matters.
[Re: miden851]
#4779669
06/06/18 09:07 PM
06/06/18 09:07 PM
Posts: 636 GA
miden851
OP
OP
GA
I thank you for you valuable input!
my car uses/burns some oil between oil changes, at 5K interval i'd say about 1qt or less; I plan to use Mobil 1 HM Synthetic for next time, so meanwhile is there any traditional way to test the O2 for its function, or is it possible for the sensor to go to off and on randomly, and should I use fuel cleaner to benefit the sensor for example
needless to say, I registered my cars last month, so the repair could wait; but at the same time, I like my M6 so Ill be continuously proactive about it
[Re: miden851]
#4779698
06/06/18 09:36 PM
06/06/18 09:36 PM
Posts: 2,742 Fort Worth, Texas
clinebarger
Fort Worth, Texas
I'm guessing this is a Ultra Low Emissions Vehicle? Your Catalyst isn't "lighting" in a timely manner!
2001 Chevy Camaro L92/4L80E 2006 Chevy 2500HD LBZ/Allison 1000 2010 Toyota Corolla 2ZR-FE/U341E 2000 Toyota Avalon 1MZ-FE/A541E
[Re: spasm3]
#4781098
06/08/18 08:54 AM
06/08/18 08:54 AM
Posts: 1,160 Perris, CA
Anduril
Perris, CA
As long as you are running the correct fuel( don't try e-85 in a non flex fuel etc.), i don't thing brand matters. In my experience, it absolutely does. I went with the cheapest O2 sensor off of RockAuto to get my wife's old Cavalier to pass smog and it did pass, but her MPG was terrible. Suspecting the sensor, I swapped it out with an OEM ACDelco one, and gained 5 MPG.
2015 Nissan Versa Note 1.6/5MT 2012 Toyota Tacoma 2.7/4AT 2007 Toyota Camry 2.4/5AT 2005 Nissan XTerra 4x4 4.0/6MT 2002 Mustang GT Convertible 4.6/5MT 2009 Kawasaki Vulcan 900 2013 Hyosung ST7
[Re: Anduril]
#4781623
06/08/18 06:18 PM
06/08/18 06:18 PM
spasm3
out there
As long as you are running the correct fuel( don't try e-85 in a non flex fuel etc.), i don't thing brand matters. In my experience, it absolutely does. I went with the cheapest O2 sensor off of RockAuto to get my wife's old Cavalier to pass smog and it did pass, but her MPG was terrible. Suspecting the sensor, I swapped it out with an OEM ACDelco one, and gained 5 MPG. I was referring to brand of fuel, not o2 sensor. 02 sensor brand makes a huge difference. Denso or oem only for my engines.
[Re: miden851]
#4783209
06/10/18 04:08 PM
06/10/18 04:08 PM
Posts: 636 GA
miden851
OP
OP
GA
latest follow up on 02 sensor;
this morning on my way out, check engine light went away and it been like that since; I kind of knew it its going to happen like this;
so my question to BITOG community, what has caused it, bad gas or new prolonged(5k) oil change interval/low synthetic quality oil (ST) vs Mobil1 for example I'm inclined to bad gas
one more thing, I went to all auto parts establishment and no one could point out which out of three O2 sensors that my Mazda has is the faulty one; this is why is your imperative and do yourself a favor take care of your car on your own!
[Re: miden851]
#4783347
06/10/18 07:15 PM
06/10/18 07:15 PM
clinebarger
Fort Worth, Texas
P0421 IS NOT a HO2S sensor fault code. A auto parts house is not responsible for diagnosing your vehicle, Nor is it their responsibility to provide Repair or Component Location information. A competent Technician can test the Catalyst Oxygen Storage Capacity with a 2 Channel Lap Scope & some Propane, This will also test the HO2S sensors as the Lap Scope will be directly reading the Signal outputs. If this is a 3.0L V6? You have 4 HO2S sensors. Bank #1 is the bank nearest the firewall, Bank #2 faces the core support. 7 is Bank 1 Sensor #1 5 is Bank 1 Sensor #2.....This sensor monitors Bank 1 Catalyst efficiency. 8 is Bank 2 Sensor #1 6 is Bank 2 Sensor #2
[Re: miden851]
#4783514
06/11/18 12:19 AM
06/11/18 12:19 AM
spasm3
out there
I never meant in imply that the codes meant replace your o2 sensors. I was saying that at high mileage i replace mine before they throw codes to protect the cats. They get slow before they fail. Your cat is taking too long to work, as the upstream and down stream senors compare data.
The cat is probably degrading as i said above, but it would not hurt to change the upstream sensors if you are going to keep the vehicle. I would make sure the ignition system is fresh, and if there is high mileage on the 02 sensors, i'd change ALL the upstream sensors before changing the cat, to protect the new cat.
I'd replace the upstream sensors and run it on the high way for a good while to converters good and hot, see if that helps. If not, get someone to diagnose it before spending any more money. But it could be the catalytic converter starting to give up.
