Attack on plant and wells in Saudi Arabia
by addyguy - 09/15/19 09:09 PM
Teamsters about to strike
by P10crew - 09/15/19 09:07 PM
Found this old race video too!
by ls1mike - 09/15/19 09:01 PM
30W or 40W ?
by lukejo - 09/15/19 09:00 PM
Some of my old cars! Found these today.
by ls1mike - 09/15/19 08:49 PM
Magnets on oil filter base plate
by MrQuackers - 09/15/19 08:44 PM
Supertech h/m atf rollback
by HyundaiAbuser - 09/15/19 08:42 PM
2020 Ford Explorer (Police Interceptor Utility)
by dogememe - 09/15/19 08:33 PM
OEM battery dead?
by Reddy45 - 09/15/19 08:32 PM
Accurate cell coverage maps
by stockrex - 09/15/19 08:17 PM
Hyundai Transmission Fluid SP-IV-RR replacement?
by CrazyElf - 09/15/19 08:09 PM
New steering wheel, 2014 Mustang GT
by bdcardinal - 09/15/19 07:32 PM
Anyone Here Know BW35s?
by bunnspecial - 09/15/19 07:14 PM
How Long Should it Take to Clear on an 09 Suburban?
by NYEngineer - 09/15/19 06:44 PM
DOT 3 Synthetic Brake Fluid
by Snagglefoot - 09/15/19 06:36 PM
Coolant Leak?
by coopns - 09/15/19 06:12 PM
Most CEL codes you've ever had at once?
by cwilliamsws6 - 09/15/19 06:08 PM
Fall Dilution
by Snagglefoot - 09/15/19 05:56 PM
KevATL, DragSGT, Gbenitez, DoctorPc, FarmerDan
69277 Registered Users
111 registered members (addyguy, AZjeff, 2002 Maxima SE, 2010Civic, 17 invisible), 1,996 guests, and 22 spiders.
Topics294,614
Posts5,063,170
Members69,277
Most Online3,532
Jul 30th, 2019
Peak Global Life Time-Is it really "Life Time" #4778105 06/05/18 11:51 AM
W
willbur Offline OP
W
Greetings-
What makes Peak Global Life Time coolant "Life Time". Is it really "Life Time", or is that just marketing? All other coolants specify a change frequency/mileage, but not this brew. I would think if its truly "Life Time", car manufactures' would be all over it.
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778146 06/05/18 12:49 PM
M
maverickfhs Offline
M
At least, I am sure there's nothing as 'lifetime'
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778147 06/05/18 12:50 PM
M
maverickfhs Offline
M
But subscribing to it
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778159 06/05/18 01:07 PM
SirTanon Offline
I suspect that the use of the phrase "Life Time" in this based on the following:
The coolant is a "super long-life" coolant, which an be used for a ridiculously long time. Add to that the term "Global" in the name, and you also add that it can be used in any vehicle. Your average consumer interprets that to mean that they can use it in any car they own without concern, an that they can leave it in pretty much 'forever', which since most (90+ percent) consumer car owners only keep their cars for 5 years or less means that for them, it essentially IS forever.
2013 Nissan Altima SV - 2.5 liter/CVT - 119,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 67,500mi
2010 Ford Fusion - 274,600mi
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778162 06/05/18 01:13 PM
SHOZ Offline
I use the Farm and Fleet long life universal. Made by Peak. Buy a case at a time and just about anytime the coolant gets drained for some reason new coolant goes in,long life or not.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778177 06/05/18 01:32 PM
J
John_K Offline
J
My mechanic says lifetime means "until it fails because it needed new fluid." Applies here.
2009 Mercury Grand Marquis, 8 cyl auto, 91xxx miles, PU/Fram Ultra
2005 Hyundai Sonata, 4 cyl auto, 98xxx miles, Maxlife/OEM Filter
Current oil stash: 459 qts.
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778185 06/05/18 01:39 PM
SHOZ Offline
On my third set of 'Lifetime Windows' in my house over 35 years
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778212 06/05/18 01:59 PM
skyactiv Offline
That is the coolant I had in a 07' WRX I once owned. I bought the concentrated type and mixed it 50/50. Subaru was still using traditional coolant and called for the change interval at 30K miles or 30 months. I sold the car with 136K, only changing the coolant once and never had an issue.
Me: 13' VW GTI 3 door 6 speed manual
2018 Elantra Sport 6 speed manual
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778213 06/05/18 01:59 PM
M
maxdustington Offline
M
Until the system needs to be serviced (water pump, heater core, hoses, thermostat), 100k KM max before one of those events.
You have to assume low mileage cars are more likely to get the real thing, "global" coolant is for emergencies where the system is probably going to get flushed. Or some high mileage beater that just gets generic coolant now.
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: Peak Global Life Time-Is it really "Life Time" [Re: skyactiv] #4778275 06/05/18 03:15 PM
skyactiv Offline
Correction: Looking at my maintenance log on the PC, I did change the coolant again at 105K miles when I changed the timing belt.
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778440 06/05/18 06:22 PM
3
3800Series Offline
3
Life time means nothing unless it's specified. You could always call and ask them "whose life time" the life of the car? The life of my pet dog? My life?
You get the point.
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778487 06/05/18 07:28 PM
P
pbm Offline
P
My 2008 Corolla came with Toyota pink which is rated for 10 years/120K on the FF....I changed it out after 7 years and 75K to PGL....I just changed it again at 112K (and 4 years) using PGL (again).....I used distilled water both times so I'll probably go 6 or 7 years or until the car is sold.
So to answer your question....I don't think any coolant is 'LIFETIME" but some, like Toyota pink and PGL can go for 7 to 10 years and over 100K.
PS: I think that changing LL coolant every year or two is a waste and unnecessary...especially with cars with timing belts where the water pump gets changed every 80 or 90K. Every 4 or 5 years is fine with a LL (EL) coolant...IMO..
'Journalism is Dead'
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4779464 06/06/18 06:45 PM
Sayjac Offline
Here's what Peak Old World says the term "Lifetime" means for PGL. First bullet point.
"Provides guaranteed 'lifetime' protection for as long as you own your vehicle when a complete cooling system flush and fill is performed and specified maintenance followed." Seems a reasonable explanation and definition imo.
https://peakauto.com/wp-content/uploads/2017/01/PEAK_Global_FS_spec_sheet_2015_noback_LORES.pdf
It's good for 'at least' as long as the long(est) service interval PHOATs and OATs like Dex, which is a long time. And no 2eha. There isn't a PC application that with a complete flush I wouldn't trust PGL as the AF. Using it now in an older Tacoma originally specing red LL. Almost 5 years interval now and original radiator.
PGL a good AF imo.
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4779882 06/07/18 07:45 AM
W
willbur Offline OP
W
Sayjac-
They're slick with the wording- its "Life Time" if one does the required coolant changes/maintenance specified in the Owner's Manual, most likely 5 years. Big deal- any quality coolant can do this.
Its not a fill and forget coolant like its name suggests/implies (in my opinion).
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4779918 06/07/18 08:33 AM
Sayjac Offline
I'd say it would be "slick" if they didn't give or hid their definition of what Lifetime meant for warranty purposes, imo. That said, I don't get caught up in the semantics of the name. More important, it's a good AF that in my observation is generally well respected in bitog and has been since I joined.
And not just any quality coolant is an extended life OAT AF with no 2eha (found in Dex and Dexclones/Prestone) making it suitable for use many applications.
I'd think anyone with some common sense AND knows how to read would realize the term Lifetime to be taken with a grain of salt.
